Intairco tire change?
My Feedback: (27)
Hi guys,
I have quite nicely burned thru a set of Intairco tires and have a new set of rubber to replace them with...but how the heck do you do it? I have 2 and 5/8 wheels and the rims seem solid...so how do you get the old tires off and the new tires mounted on the rims?
Beave
Beave
RE: Intairco tire change?
Hey Beave,
Similar tire/ wheel combo on my F-15.
Sounds silly, but, I have found much sucess with putting the new tires into a small pot of boilling water for about 5 minutes to soften the rubber a bit. Gettin the old tire off the rim is simple. I must assume they have flat-spots or some other reason for replaceing them? Therefor, take your box cutter blade and slice right thru them to discard. The hot water will make the new tire rubber pliable and easier to stretch over the rim.
This has worked for me on three sets of tires now, and I'm sure to use this process again early this season as I burn thru the rubber with many flights.
Frank.
Frank.
Cut the old tyre of using a band saw up to the rim and then a sharp blade to finish off, wet knife blade with water to make cutting easier.
Warm the new tyres in boiling water to make then super soft, apply a little washing up detergent to the inner part of the tyre and stretch over the rim
(intairco instruction)
Christian
www.webalice.it/jetflydemoteam
Christian
OK guys, I have new set of tires that are harder than Superman's head....heated with a heat gun to the point of needing gloves to touch it....NOPE.......5 minutes in boiling water....NOPE......the old tires were the consistency of bubble gum and wore out in less than 20 flights.....the new ones are made of Krypotonite....I'm getting P/O'd caus I want to bust some laps tomorrow and I cant get the tires on the rim.....my lathe chuck isnt big enough to build a taper like BVM uses....any other ideas so I can burn some kero tomorrow....
AHHHHH, a spinner....was looking around for something that might work.....been a long time since I actually used a small plastic spinner....down to the hole to give it a whirl.....Thanks....
jkeze, thanks....the spinner worked, even thought it broke....I had to literally jump on it to get the tires on.....220lbs.....they sure as h*** wont spin off the hubs.....
FL
Buddies, I am getting problems with Intairco 83mm wheels. On the second takeoff the tire left the wheel........
Any way to solve it, or change to BVM wheels?
Regards.
Rick.
Regards.
Rick.
My Feedback: (24)
How old are the wheels/tires?... there was a short period where intairco changed tire manufacturers and tires where made of the wrong durometer rubber. Most likely what you have....
Replacement rubber will solve the problem if this is the case. Only other reason to be loosing a tire on these wheels is if you are carrying really excessive ground speed.
As far as I'm aware of the ones I have and these are Intairco rims they are split rims. Once all the screws are undone completely the rim falls of and you take the tire out.
No need to be trying to stretch the tire over the rim.
My Feedback: (80)
CA
ORIGINAL: bevar
Hi guys,
Beave
Hi guys,
Beave
My Feedback: (80)
CA
ORIGINAL: Justflying1
ORIGINAL: luv2flyrc
I've had the tires depart from my Intarico wheels on a hot landing. I now glue them on with Locktite Black Max. It's a black coloured, rubberized CA made for gluing rubber. So far never had an issue since. Very expensive stuff though.
Mike
Mike
Mike
My Feedback: (12)
ORIGINAL: furloughed ual
