Y/A f-18 single air retract valve
My Feedback: (10)
WI
ok here's my question? it's been awhile but I'm having a brain fart on this. i have a yellow aircraft f-18 single. the retract valve is from yellow aircraft it has 2 nipples on one side and 3 nipples on the other. what is the correct way to hook up the air lines for all three gear?
My Feedback: (23)
RE: Y/A f-18 single air retract valve
The side w/ the 3 nipples, the center nipple is for the air from your air tank.
the other forward 2 nipples (1 on each side) are for either gear up/down. the aft 2 nipples are for gear down/up.
Doesn't matter which pair of nipples you use for up or down, as long as they all go up/down. lol
