Spektrum 2.4 Did You know? UPDATE Finally
RE: Spectrum 2.4 Did You know? I didn't!
The flashing lights are merely an indication that the system has suffered a power failure , which you created in this instance by switching off the Rx then on agian. It has NO effect on system operation. (Source: Dave Ribbe of Horizon) The way to clear the lights flashing is switch off BOTH rx and tx and then restart.
Switching on the tx and then the Rx immediately, within a second or less, has no effect on the connection of my Spektrum systems.
Spektrum 2.4 works to perfection in three jets for me, including aSavex L39 where EVERYTHING is in very close proximity, except for one remote which is mounted in the wing. That remote always gives the lowest fade count.
Regards, David Gladwin.
My Feedback: (18)
MO
I can't say without a doubt this is a true problem. I am just saying I noticed this happen just after going into a hold. The reason I think something is going on is if I turn the receiver on right after turning the transmitter on I have problems. For instance with the jet on it's back if the retracts are extended and I turn the transmitter on and then wait 4 or 5 seconds and then turn the receiver on nothing happens unusual.
However, if I turn the transmitter on and then right away turn the receiver on my retracts...retract and then pop back into the extended position. Plus, when I turn on the receiver too quickly both interior receiver lights don't light up. When I had the lock out and then noticed I may have turned the receiver on too quickly and the lights failed I now wait a few seconds and have not any trouble at all with the system.
To me it seems like the system has to "arm" itself within just a few seconds after the transmitter is switched on.
I could be all wet but for me I think that is what it is doing.
Don
Don
My Feedback: (18)
MO
David,
I'm not saying your wrong of course but why then does my retract system activate all on it's own when I immediately switch the receiver on but does not when I wait just a few seconds? I know there's a cause but not sure why?
Don
Don
#31
ORIGINAL: Synthetic
David,
Don
David,
Don
it does that because its bound that way. IF the receiver is turned on without a signal it goes into whatever failsafe you programmed. It takes a couple seconds for the transmitter to begin transmitting and for the rx to recognize guid.
So you bound it correctly with the gear down and its working as it supposed to.
#32
My Feedback: (18)
MO
Thanks Goose..
I've got to say though it kind of freaks me out when the receiver lights don't come on. I know how to reset it but I wonder what would happen if instead of resetting it I took off and flew it.
Don
Don
#33
dont ever fly unless the rx lights are on steady
just wait 5 seconds btween tx and rx turn on.
If it happens when you turn on tx then turn rx on and it doesn't link in about 10 seconds. Move the transmitter 10 feet away, and re power the rx.
Just remember they do not actually exchange information. the transmitter sniffs then transmits, the receiver scans for programmed guid, then locks on two freqs. nothing more nothing less
IF the receiver doesn't have a link, it sends NO signal to the servo, and Low throttle, and whatever was bound with gear channel. If it loses a signal, it just freezes the last servo signal given, goes to gear bound and low throttle.
You are ok. go fly bro!!!!
#36
ORIGINAL: gooseF22
I am not saying your wrong, just interested to find out more.
Regards
Paul
#37
#38
FWIW
If you have electronics with there own built in failsafe, You can have a situation where when you turn on the RX, voltage is sent to everything in the system, but it takes a few seconds for the RX to get booted up and locked into the TX.
This can cause some on board electronics to not get a signal while booting up and go into there own form of failsafe.
We first noticed this on helies with a 401 gyro. When the power comes on, the gyro is looking for a signal on the gain channel to tell it to lock in whatever the rudder signal is as the neutral point. If the correct signals are not there within the first 3 seconds after power up the gyro will go into a default mode as indicated by a flashing LED. If start up was correct the LED will be solid on.
We now have informed all of the heli fliers running spectrum to check the LED status at every power up.
If the LED is flashing then cycle RX power to get it to reboot.
There could be similar things happening in a jet with gear failsafe or gyros on board or other electronics that have a built in failsafe mode.
#39
The gear cycling is an interesting comment. A month ago at MS Afterburner I helped a guy with his Electra. He was having the same issue but not on every startup. I had him re bind the reciever and the problem went away. Just make sure that when you re bind that you have the gear in the down position, throttle at idle, and low trim. In other words make sure that every control function is where you want it for failsafe, and startup.
I have not seen the gyro issue that flyingfool1 has seen I have a 401 on a TREX 450SE and 611's on all the rest of my helis. The gyro takes a second to initialize after the 2.4 "boots up" but I have always seen the gyros do that.
#40
My fault.
I did not mean to imply that 401 boot up with Spectrum was an always thing.
Not all of the Spectrum's at our field did this, and the ones that did do it, did not do it every time.
It is just something to be conscious of and make a part of your preflight if you have other electronics that have there own electronic failsafe system.
#41
Jeff Holsinger of horizon told me @ SEFF 08, that once a model is setup as desired with a transmitter that you should rebind it with everything where you would like it for the boot up process. He also told me that any lockout is default hold last command and low throttle (a total seperate condition) the Rebinding process after setup is for the positions desired during the time it takes to initialize. But when Quique crashed his prototype Toucan bipe at SEFF08 with his 12x 2.4g it looked like a down elevator command bug of Shulman/NALL 10X era,
I have on RARE occassion only with other 2.4 Spektrums in the area that after what appears to be a complete Spektrum AR7000 initialize that the servos do not track the stick movement properly without stepping noticably, I've tried to find anyone else with this problem and it seems I'm the only one so I'll just us use it in foamies and keep building trust in 2.4G FASST same TX, JR9303
FWIW
I found on a TREX 600 and the 401 that I did the final rebind after setup with gyro in the normal rate mode, the light works everytime solid, then I switch to Heading hold,
Judging on the PM's this may be of interest to some,
FWIW
#43
ORIGINAL: Gordon Mc
You seem to be ignoring all of the other differences between Spektrum and the 'regular' JR systems. The freq is not the only difference.
e.g. the problems previously reported with certain electronic sequencers etc had nothing to do with the freq either, but were instead caused by the different operating voltage at the RX.
ORIGINAL: Helijet
How can 2.4 G be blamed for this??? My understanding of the technology is that the 2.4 is the link between the transmitter and the receiver. Once the processor in the receiver acquires and decodes the data it is sent to the servos. How can a lead amplified or not be influenced by a 2.4 wavelength??
#44
ORIGINAL: paulflys4fun
I have tried to split my xl down the middle. Two rx two switches, batterys ect. I tried to bind an ar9000, and ar7000. It would not work. If i bind two ar7000 its fine. If as you are saying above is right that the receivers do not exchange information, how can you explain why it wont work with differnt receivers?
Regards
Paul
ORIGINAL: gooseF22
Regards
Paul
So you can not use dual recievers of different types.
Steven
#45
Steven....
A friend of mine ran into the same problem with binding multiple receivers to a TX. The solution isn't having both receivers the same, it's having both receivers the same protocol. From what I understand, the 7000 RX and the 6 channel RXs (6100,6200) share the same protocol, so they can be used together. The 9 and 12 channel RXs (9000, 921, 9100, 1221, etc) share the same protocol, so you can mix and match them. Haven't tried it myself, but that's what I'm hearing. Hope it helps.
KMac
KMac
#46
ORIGINAL: Gary Jefferson
After I had my AR9000 receivers upgraded for the brownout protection I noticed the same thing with the lights flashing on the receivers when turning the receiver off and then back on...I have no idea what affect this has on range (or anything else) because everything still worked, but the solution is to turn the receiver off then turn off the transmitetr as well. Then turn them back on one more time. If you don't turn off the transmitter as well they stay flashing for some reason...Gary
#47
My Feedback: (18)
MO
My question about this "flashing" light thing is this..
If you turn on your transmitter and then very quickly turn on the receiver and the receiver lights are flashing....what happens if you take off and fly with it in this condition?
Don
Don
#48
As I understand it, Spektrum uses the onboard lights to identify variuos conditions, with them now having multiple software upgrade patches they have also altered the meanings of the lights as a visual troubleshoot code. I believe latest variation can indicate a low voltage and reboot occurence, With Spektrum having multiple variations of software revisions I think it would be hard to be definitive on light meanings unless one knew for certain the version software of that particular RX. I think I still have the 10 second rebooters....... It so confusing I can only get straight answers from Jeff H or John A when I see them in person..........
FWIW,
Has anyone got any 9100 free receivers from the promo? I've had two due me since 4/1/08
FWIW,
#49
ORIGINAL: AnthonyW
I may be mistaken, but I believe Shulman @ Nall 07' was still on 72mhz, not Spektrum.
As has been said, David Shulman now fly’s FASST.
Synthetic
See David Gladwin's post above re: flashing LED's
