clear + aeroloft dry transfer questions..
My Feedback: (23)
I've searched w/ no luck, so decided to ask. I just installed some aeroloft Dry Transfers to my big F-18. Its now ready to be clear coated but in the info sheet w/ the dry transfers it says "Do not user lacquer or alcohol based products" to clear coat over them.
I'm planning to us PPG Flexed-N-Flat clear on the jet. w/ DCX61 hardener and DT-870 reducer in a 4:1:10 ratio. Will this be ok to use and not ruin my graphics?
thomas
thomas
IL
RE: clear + aeroloft dry transfer questions..
You should be fine. ppg 2060 flexed and flat is not lacquer or alchohal based.The ratio you have seems to be different,I thought it was 6-1-1.
My Feedback: (23)
ORIGINAL: flyexperimental
i'm up for suggestions on ratio's.. what info i found on the DC2060 i thought most were using a 4:1:10 ratio... to get a thinner clear coat to save weight (which i could use on a plane this big, as 2 turbines + everything else adds up).
IL
I would at least keep the clear/hardened ratio as per ppg directions.If ppg says 6-1. I would do that.Too much hardener if you do the 4-1 will give you more shine and it may not dry very well.Too much hardener leaves excess hardener that will have no clear to cross link with and it will stay sticky.Putting 10 parts reducer verses 1 seems like it is getting way to thin.I would think 6-1-1.5 would be more than enough reducer.When mixed 6-1-1 flexed and flat is not very thick to start with.If you choose to change the reduction over the directions I would test it on some type of test panel first.
My Feedback: (23)
I would at least keep the clear/hardened ratio as per ppg directions.If ppg says 6-1. I would do that.Too much hardener if you do the 4-1 will give you more shine and it may not dry very well.Too much hardener leaves excess hardener that will have no clear to cross link with and it will stay sticky.Putting 10 parts reducer verses 1 seems like it is getting way to thin.I would think 6-1-2 would be more than enough reducer.If you choose to change the reduction over the directions I would test it on some type of test panel first.
understandable.. and makes sense to me.
My Feedback: (23)
oops. went back over the thread i was looking at and one guy was recommending a 150-200% reduction rate.. which i believe comes out to a 6:1:10 ratio?
http://www.rcuniverse.com/forum/m_56...tm.htm#5618772
Does an enamal spray paint fall under the category of "laquor or alcohol" based?
No It's what it says it is Enamal based.
They don't make Laquor based paints any more.
PPG is either Enamal based or Acrylic based paint depending on if it's base coat /clear coat or single stage
I have never heard of an Alcohol based paint before.
So you should be fine with using the valspar if that's your choice. Just do it in light coats and it should work.
