Boomerang Sprint Build Thread!
Reply
Old 03-18-2009, 08:51 PM
  #526
phjoker
phjoker's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Boomerang Sprint Build Thread!
Here is what I did with mine. I had some black screen laying around.... measure,cut and glue.
I don't know if it is realy needed or not but figured it couldn't hurt to have it.
phjoker is offline
Old 03-19-2009, 02:36 AM
  #527
Warwick Laken
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Having flown my Sprint for some time now, I know that with a smoke tank onboard with 1.5lts of smoke fluid inside there are no issues with weight and the fliing capabilities of the aircraft. Hence my question.
One of the issues for me is how easily wing panels and booms are marked when transporting and moving in and out of a car. So for my next Sprint I an considering removing the covering and recover with light woven glass cloth and spraying.
Has anyone else done this, what problems if any were met.
Warwick Laken is offline
Old 03-19-2009, 06:40 AM
  #528
rcguy!
rcguy!'s Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: Warwick Laken
Why not just get wing covers and save alot of work?
Dave
rcguy! is offline
Old 03-22-2009, 02:15 PM
  #529
Dave03B
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Successful maiden yesterday. 3 very solid flights, however will be moving the cg much further back as elevator was too mushy inverted. The prolinks stuck two fingers up to our grass field and dampened very well. P80 pushes this thing along very nicely. Still playing with the flaps, but didn't use any for takeoff. Suspect much shorter takeoff will be possible with a more reward cg and use of takeoff flap. Thanks to Alan for answering some of my queries and for a great 'everyday' sport model that breaks down perfectly to fit in a small car. More photos of the maiden on our club site forum.
ID:	1163413   Click image for larger version
ID:	1163414   Click image for larger version
ID:	1163415   Click image for larger version
ID:	1163416   Click image for larger version
ID:	1163418   Click image for larger version
ID:	1163419   Click image for larger version
ID:	1163420   Click image for larger version
ID:	1163421   Click image for larger version
Dave03B is offline
Old 03-22-2009, 02:27 PM
  #530
georbeckha
georbeckha's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Congrats on the successful Maiden.
Reading thru this full thread makes me more excited to get mine and build it. I have one what is due to be delivered on Tuesday. It's going to be Jet Central Falcon powered.
I also have the retracts from Dreamworks coming to.
Perfect timing actually as my P70 took a disliking to my ShockJet and tried to burn the tail off after a few minutes flying around!
One question for all that have successfully flown theirs... What servo's are you all running on Ailerons, flaps and elevator? Just Curious. I have seen referenced to the JR 8611a's and the like but seriously think they'll be a little much for this airframe.
Anyways, Thanks for all the great ideas and hints in this thread and keep it up for all the newbees coming into Jets.
George
georbeckha is offline
Old 03-22-2009, 02:36 PM
  #531
J.F
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Congrats Dave!
Any chance you could post your throws and CG used?
Rough idea how much strip you used without flap on takeoff?
How was it to fly (especially land) compared to the little L39s?
J
J.F is offline
Old 03-22-2009, 04:00 PM
  #532
Dave03B
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi George, I went with JR 591s for aileron, rudder &nosewheel steering, for Elevator and Flap I've used the 8.3kg torque JR 579. Everything felt nice a crisp so i'm happy with this setup.
Hi James, Thanks. CG and throws as per manual for the first flights. Its easy to fly, really solid and smooth. Takeoff run approx 220ft /70meters ish but I left it on the deck longer than needed to be safe of flying speed. As I said, with a nicer cg and takeoff flap this will be up in a much shorter distance. First landing took a few approaches due to the ballooning effect with full flap, so i had to force the nose down for landing. Second landing much nicer with more down elev trim mix. How long is your strip? Compared to the L39, this is fun and stress free.
Dave03B is offline
Old 03-22-2009, 04:06 PM
  #533
J.F
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Only got 50m.
Seen them (on the vid's) taking off in much less and landing in less too, but don't want to be replacing the undercarriage on first go!
did you need to hold much power on with full flap, or just let it glide in on idle?
J.F is offline
Old 03-22-2009, 04:49 PM
  #534
Dave03B
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I kept it just above idle incase I needed the power. Give me a couple of weeks with it, and I'll come back to you with the shortest takeoff distance I can get.
Dave03B is offline
Old 03-22-2009, 05:43 PM
  #535
DamBo
DamBo's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Excellent, Congrats on the maiden.
Sounds like this jet is going to be fun to fly.
Mine just about ready for its maiden, just have to get with the turbine guys and get my turbine waiver.
Here are a few pictures.
ID:	1163569   Click image for larger version
ID:	1163570   Click image for larger version
ID:	1163571   Click image for larger version
ID:	1163572   Click image for larger version
DamBo is offline
Old 03-22-2009, 05:45 PM
  #536
ricardinho
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
i am landing mine with full speed brake with crow. the thing is slow and stable all the way to the ground. i to keep just a little over idle power with nose slightly down pointed at runway. once i get about 10 feet from the ground i cut power completly and glide in for a smooth landing. this thing really does land like a trainer. for take off our runway is a 200 foot paved runway. i use all of it before i rotate. i land in the grass and you dont need to use brakes...awesome plane!!!!
ricardinho is offline
Old 03-22-2009, 05:47 PM
  #537
ricardinho
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
hey thats just like mine!!! same color. good choice hahah.... pat
Old 03-22-2009, 05:53 PM
  #538
ricardinho
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
i took you advice and did mine like this. worked perfect. had to send my p 70 in for new starter and compressor wheel. i think this will help protect from junk comming in the from intakes...they should make some covers for those front intakes. i alumium screen material would look cool..
Old 03-22-2009, 05:56 PM
  #539
DamBo
DamBo's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Cool[8D]
What powerplant are you putting in yours?
I decided on a Rabbit. I could not tell how much thrust it had on the bench runs but, when I ran it up in the sprint and held it back it pushes hard.
DamBo is offline
Old 03-22-2009, 06:10 PM
  #540
Dave03B
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: ricardinho
I did this on mine. Cut up an 89p sieve, took a profile drawing of the internal duct (which I have somewhere) then cut the mesh to shape. I then did the same in the intake cutouts around the turbine bay, similarly to that shown in post 526.
Dave03B is offline
Old 03-22-2009, 06:31 PM
  #541
ricardinho
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
i am using the jetcat p70. the power to weight is perfect.. i wouldnt go with less thrust. try to stay 17+ thrust. i do believe the rabbit is a little more thrust then the p70.. i would go with who ever has the best service. from what i here jet cat service is legendary...
Old 03-22-2009, 07:38 PM
  #542
Doc...
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi Dave,
Congrats on your maiden. Great pictures. Just hocked all the wires to the Turbine and it looks like if the weather holds up, I will be doing my maiden right after the Toledo show which is the 1st weekend in April. One question, When you went inverted, did you notice much of difference? Have fun and enjoy.
Doc...
Doc... is offline
Old 03-23-2009, 03:28 AM
  #543
Dave03B
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: Doc...
Thanks Doc. As for inverted, it needed almost full down elevator deflection to sustain level flight.......nose heavy trait.
Dave03B is offline
Old 03-23-2009, 06:17 AM
  #544
Doc...
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi,
That's what I was looking for. The positive thing is nose heavy, (in moderation) is usually better than tail heavy on tri gear. We were playing around a little over the weekend and with both wings off, all tanks totally dry and the turdle deck off, we lifted it by the center spar and it wanted to just slightly go tail heavy, and I mean slightly so I know were close. I have many pictures I need to post showing all the custom graphics I made and the 3 air inlets I installed. I will post them when I get back from The Toledo show. Who ever took your pictures while you were flying, hopefully it wasn't you, (hahahahaha) did a super job of the ship flying. You mentioned there were more pictures on your club forum. What is the address so we can see more.
C-ya,
Doc...
Doc... is offline
Old 03-23-2009, 11:26 AM
  #545
Dave03B
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
More photos:[link=http://wimbornemac.lefora.com/2009/03/18/boomerang-sprint/page1/]Click Here[/link]
[link=http://wimbornemac.lefora.com/2009/03/22/saturday-21st-march-2009/page1/]More here also[/link]
Dave03B is offline
Old 03-23-2009, 07:14 PM
  #546
ricardinho
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
hello took some photos of my boomer. how in the world do you get them on here.. have been trying cant figure it out..can you help.. thanks pat
Old 03-23-2009, 07:20 PM
  #547
ricardinho
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
here are the pics of my boomer.. itook a picture of the full flap view and hope you can see the crow in the aireons. motor is at jetcat . neat plane... this thing slows down very very slow for landing with the full flap with crow..
ID:	1164624   Click image for larger version
ID:	1164625   Click image for larger version
ID:	1164626   Click image for larger version
ID:	1164627   Click image for larger version
  #548
DamBo
DamBo's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
At the bottom of the message reply, click here to up load images, must be less than 6000k
DamBo is offline
Old 03-23-2009, 07:22 PM
  #549
ricardinho
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
figured it out . let my wife download them.
Old 03-23-2009, 07:24 PM
  #550
DamBo
DamBo's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hey that looks like mine...
DamBo is offline
Reply
Display Modes
