If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Page 70 of 87 FirstFirst ... 2060686970717280 ... LastLast
Results 1,726 to 1,750 of 2174
  1. #1726
    Colin Gontier's Avatar
    Join Date
    Apr 2008
    Aylesbury, , UNITED KINGDOM
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Boomerang Sprint Build Thread!
    Equipment board given a top coat. Turbine and air system ancillaries going in - all very straightforward..
    Attached Thumbnails Attached Thumbnails Click image for larger version.
ID:	1589632   Click image for larger version.
ID:	1589633   Click image for larger version.
ID:	1589634   Click image for larger version.
    www.boomerang-jets.com
    Boomerang Jets - CARF Models - Jets Munt - Jetcat - Powerbox - Jet 1A - Jet Tronic - JR Propo - Bavarian Demon - ZN Line - RedWings - Electron
  2. #1727
    Join Date
    Apr 2008
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    And now the finished product !
ID:	1589636   Click image for larger version.
ID:	1589637   Click image for larger version.
ID:	1589638   Click image for larger version.
ID:	1589639   Click image for larger version.
ID:	1589641   Click image for larger version.
  3. #1728
    Join Date
    Jun 2002
    Watford, UNITED KINGDOM
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: Aviator-No
    Hi,
    I have a few questions....?
    My Sprint fly hands of straight at half throttle.
    If I increase the speed it rises it's nose a bit, and lower the nose when decreasing the speed.
    I have the Elevator trimmed a bit down to make it fly straight at half speed.
    Upside down it dives a lot.
    CG is almost spot on (5 mm aft of carbon rod)
    The turbine is is raised in front a few mm.
    Do I have thrustline problem or wing and stabilizer incidence issue?
    Brgds
    Svein-Roe
    What turbine do you use? The Boomerang set up means on turbines with higher exhaust velocity, the faster moving air under the tail produces lift on the underside of the tail, drawing it down and making it pitch up.
    Changing the turbine angle (down at the back) gets the exhaust away from the tail surface. Do this and re trim at 2/3rds power. Then try inverted also at 2/3rds power.
    The high tail you will always get at least a small trim change, you can mix it (throttle to Elevator) but normally a good compromise is possible.
    Dw
    Motors & Rotors. JetCat, Powerbox, Intairco, Behotec, CARF-models Rep. JR Propo for ever!, Jet 1A, MAP, Airtech Germany, Jet Tronics.
  4. #1729
    Join Date
    Apr 2004
    Lake Havasu City, AZ
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Dave, thanks for that explanation. I never knew why, but all of my Boomerangs have needed at least a thick washer under the front of the turbine mount. My new Sprint needed a bit more (see picture). Plus, I have about 3 mm of down trim on the elevator. Maybe because I'm using a P-120 turned down.
    Jack Needham
  5. #1730
    Join Date
    Apr 2006
    Senja, NORWAY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Hi Dave,
    Im running a Simjet 2250 pushing 10 kg on my fishweight :-)
    I have a small washer under the front. I have did try to ad another, but it's not possible since the starter is touching the bar under the canopy/hatch. I need to modify it or remove it.
    Svein-Roe
  6. #1731
    Xairflyer's Avatar
    Join Date
    Dec 2002
    Co. Donegal, IRELAND
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: gontflyer
    Not finished yet it has no pilot, and will never look finished until it has one!
    www.letterkennymodelflyingclub.com
    www.jmaireland.com
  7. #1732
    Join Date
    Mar 2007
    Dungarvan, IRELAND
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Pilots crash airplanes....
  8. #1733
    BaldEagel's Avatar
    Join Date
    Oct 2005
    Kent, UNITED KINGDOM
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: Xairflyer
    ORIGINAL: gontflyer
    And a full scale cockpit, pitot tube, anti stall warning tab and a drain point for the fuel tanks to check for water, where do you stop. All of our models are drones so they don't need a pilot unless they are trying to be something they are not, Oh hang on they are.
    Mike
    My Gast is Flabered.
    No matter what anyone say's 100% is the maximum you can get.
    If you see a deleted post, my Avatar say's it all.
  9. #1734
    Xairflyer's Avatar
    Join Date
    Dec 2002
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Why have a canopy then, the very fact it is there is because it is meant to be the cockpit of the aeroplane where the pilot fly's it from.
    If you are not going to actually make it what it is there for, then better to not have one at all and black it out like you done on your recover, much better looking than a blank cockpit which just looks bad and unfinished!
    www.jmaireland.com
  10. #1735
    BaldEagel's Avatar
    Join Date
    Oct 2005
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    We will have to agree to disagree on this I think, IMO it make no difference at all, I just think sprayed out glazing looks better, unless you want to show off the workmanship inside.
    Mike
  11. #1736
    VF84sluggo's Avatar
    Join Date
    Nov 2007
    Gulf Breeze, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Interesting side discussion here: For me, on my 'warbirds' - jets and props - I have pilots and cockpits. On sport airplanes, scale or not, they are either pilotless or the canopy is 'silvered' out. Don't really have an explanation for it...seems to just have evolved that way over time.
    “The FAA is nothing more than a carbuncle on the ass of progress and has set aviation back at least 20 years.” -- Bill Lear, inventor/creator of the Lear Jet, the first private jet aircraft.
  12. #1737
    chris1971's Avatar
    Join Date
    Feb 2006
    catoosa, OK
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I was talking to a friend of mine that has a lot more turbine exp. than I do about my issue with the engine being flooded and having a hot start that I posted about on previous page. He told me what I did wrong because it has happened to him before. I started the engine on propane and had the manual shut off valve for the fuel in the closed position. When it was switching over to fuel I could tell that it wasn't sounding right. I reached down and opened the valve and all heck broke loose!
    I guess the pump being under pressure and suddenly being released must have filled the engine full of fuel and caused all the trouble. Has anybody else ever pulled this dumb stunt besides me?
    Chris
  13. #1738
    Join Date
    Dec 2001
    Slidell, LA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Oh he'll yes. I burned the a_s off an Isobar once doing that!!!!
  14. #1739
    chris1971's Avatar
    Join Date
    Feb 2006
    catoosa, OK
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Good, I'm glad that I am not the only one that has happened to! Sorry about your airplane though! I guarantee that I will not do that again! It was pretty scarry watching all those flames shoot out and up!
    Chris
  15. #1740
    BaldEagel's Avatar
    Join Date
    Oct 2005
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Another advantage of Kero start, that whole senario can not happen, tap not on it can't start at all therefore no flames if you forget to turn it on.
    Mike
  16. #1741
    Join Date
    Nov 2003
    West Chicago, IL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Hello Everyone,
    I'm looking for information on the depth of the holes in the center section which receive the aluminum dowels. I found the same question back on page 18, but I did not see a response. On my kit the wing dowels only go in about 10mm and that just doesn't seem like enough depth.
    Jaime
  17. #1742
    chris1971's Avatar
    Join Date
    Feb 2006
    catoosa, OK
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    They have to at least go deep enough in the center section that the screws can tighten down on them to hold the wing on. There are four screws in the top of the wing that you have to cut out the hole openings in the monocoat and then install the screws from the top. They will hold the wing in place during flight after you tighten the screws down on the aluminum rods. The aluminum rods screw into each of the wing panels.
    Chris
  18. #1743
    chris1971's Avatar
    Join Date
    Feb 2006
    catoosa, OK
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Also I had to sand down all the aluminum rods to make them slide into the holes. My carbon fibre tube also wouldn't fit so I had to take a dowel with sandpaper glued to it and sand the inside of the center section until the tube would slide in the center section.
    Chris
  19. #1744
    Join Date
    Nov 2003
    West Chicago, IL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Chris,
    I meant the other dowels; the two dowels that you're suppose to glue to the front of the center section.
    Jaime
  20. #1745
    Join Date
    Apr 2008
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Jaime
    You might want to drill deeper holes for the front wing dowels. A good guide for the depth is to make sure the notched part of the dowel is contained inside the wing section (to take the epoxy used to secure it). Make sure you use the same size drill as the dowel.
    Also ensure you leave enough of the dowels outside of the wing so they fit well in the plastic sleeves. Do a dry fit to the fuselage before you glue it all up to make sure you are satisfied that it's all good.
    Regards
    Colin
  21. #1746
    Join Date
    Apr 2006
    Senja, NORWAY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: Jaime_Arenas
    Chris,
    Jaime
    Is this something that is on the latest kits? I have't any dowels on my sprint....
  22. #1747
    Join Date
    Apr 2002
    London, UNITED KINGDOM
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    If you strip the covering properly on wing and fuselage wingseat and follow the instructions re gluing the wing on, once the initial epoxy glue has set, you can get inside the fuselage and add plenty more glue between the wing leading edge and the former it butts up against, and one or two small balsa fillets (1/4" square or so) along the each side of the fuselage if you want to be extra sure. This is how I have all our demo planes built.
    I felt that the alloy pins were not necessary so I instructed the factory to delete them some time back, but it looks as though they have decided unilaterally to leave them in.
    Bearing that in mind, 10 mm is plenty if they are well glued in place. As I said, I personally don't use them at all and it has caused no problems so far!
    Do not use them to make the centre wing removable. That would require a re-think altogether considering the aerobatic tricks and allied stresses associated with high G manoeuvres, particularly negative, so that is an absolutely definite no-no!
    Alan Cardash,
    Boomerang Jets Designer
  23. #1748
    jblloyd's Avatar
    Join Date
    Aug 2004
    Brandon, MS
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I have a set of DreamworksRC trailing link Sprint struts for sale at a good price, if anyone is looking for some:
    http://www.rcuniverse.com/market/item.cfm?itemID=738289
  24. #1749
    Join Date
    May 2011
    Methven, NEW ZEALAND
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Hi guys, Im new here
    I just ordered a Boomerang Sprint with a Jetcat P-80SE from Als Hobbies while I was over in the UK on holiday which will be sent back to NZ.
    I'm 15 years old and been flying since I was about 9. While I was in the UK I went to Paul Heckles school of model flying and had a few good hours flying some of their aircraft. Unfortunately all of their Boomerangs were getting overhauled so I just had to spend the day flying their aerobatic machines. I learnt a lot while I was with them and they fully recommended the Boomerang Sprint as a first jet because of how it flys so here I am.
    At the moment Als Hobbies are waiting for the Jetcat which will take 2 days to arrive and also the retracts which will take 10 days.
    I will take time to build it (yea right) to make sure this plane doesn't go up in flames on the first flight. I've looked through this forum and picked up many helpful tips since this is my first turbine. Ive also got my father and a friend (who has a degree in engineering of some sort) who is fascinated by RC aircraft and surely will help me assemble the model.
    I'll update you guys when she arrives. By the way it is in the red sports scheme, The P-80 is using kero start and I'm using jettronic valves for retracts and brakes since these are my first retracts. Yes I know!! First turbine and retracts and I'm 15 years old!!
    Regards
    FlyingFlyer
    Boomerang Sprint powered by a Jetcat P-80SE
    Skymaster Large Hawk powered by a Kingtech K-180G
    Spektrum DX18
    George Jackson
  25. #1750
    Xairflyer's Avatar
    Join Date
    Dec 2002
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Good luck with it, and don't be afraid to ask questions even if you think it is something minor, we all have to start somewhere.
    www.jmaireland.com
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
