Another...Yellow Twin F-18 build
#176
RE: Another...Yellow Twin F-18 build
Nick,
Not sure what you mean by getting more advantage if the arm was to the rear? I would think it would be the opposite. If you'd screwed yourself, it's probably only in your mind because I wouldn't call this kit 'experimental' at this point...
#180
My Feedback: (12)
Or Nick you could go to one of the short aluminum servo arms and that will be more than enough, but you could definitely go further from the hatch cover form that and you will be fine.
