Reload this Page >
TBM Shock Jet
TBM Shock Jet
Old 09-10-2018, 03:12 PM
  #1451
limeybob
limeybob's Avatar
Originally Posted by motorhead540
Went to a Jet event over the weekend . very impressed would like to find a shok jet to build up and learn jets with where to look or get started ..??
Check out the Jetmach 60, this the one the the Shokjet was copied from
http://store.laser-design-services.com/index.php?main_page=product_info&cPath=1&products_id=23
Bob
Old 09-10-2018, 03:54 PM
  #1452
gjhinshaw
My Feedback: (303)
gjhinshaw's Avatar
Old 09-10-2018, 04:11 PM
  #1453
redtail
My Feedback: (15)
redtail's Avatar
Or the Reaction 54 ………. Chic
Old 02-08-2019, 06:14 AM
  #1454
dr.tom
Here's mine Shocky
youtu.be/IKAthdnyq_8
Old 02-18-2019, 03:55 AM
  #1455
dr.tom
Old 02-19-2019, 07:21 PM
  #1456
junkjet
My Feedback: (55)
junkjet's Avatar
Looks great Tom. I still have mine. I will get it out sometime this season. Changing from Spektrum to JR DMSS. For control for now.
Old 02-20-2019, 06:07 PM
  #1457
junkjet
My Feedback: (55)
junkjet's Avatar
Installed a jr 1131 today. Any bad I need to know about this receiver. Searched the web and found lots of buy and sell but nothing negative.
Old 02-21-2019, 06:16 AM
  #1458
dr.tom
Hope all will go well with yours too, junkjet, don't know anything about 1131,
I am using Aurora 9 for last like 8-9 years and all OK.
Old 04-18-2019, 07:30 AM
  #1459
RCFlyerDan
My Feedback: (54)
RCFlyerDan's Avatar
Default Wanted
Does anyone have a NIB SJ for sale? Looking for a student of mine. Thanks
Old 08-20-2019, 04:17 AM
  #1460
dr.tom
​https://www.youtube.com/watch?v=Bqk8zZVXbpY
Old 08-20-2019, 07:44 AM
  #1461
gjhinshaw
My Feedback: (303)
gjhinshaw's Avatar
Hey Tom...
Does your SJ NOT have flaps??? That thing does NOT need to land that fast! Also do you not have throttle control either?? Looks as if you are full throttle ALL the time.
Just wondering......
Originally Posted by dr.tom
Old 08-20-2019, 09:23 AM
  #1462
dr.tom
Hi,
Thanks for the info,
Being only jet in my country (sad I know...) I dont have someone beside me to look into it.
I have some CG issue obviously but manual does not cover it completely.
SJ is around 12.5-13kg AUW.
My turbine could not fit as back as I would like, a forme beam stands above it, and starter motor in front prevents tank to go further back...
So my whole tank is in front of CG, not on it.
If I balance the plane spot on with batteries, dry tank, with filled UAT, when i fill 2.7-3liters of fuel it is nose heavy.
I land with around 1liter left in main tank and full UAT.
Do you suggest to balance it with that landing fuel level,
nose heavy/full on takeoff is tolerable, but landing with New setting could be slower?
As now the elevator can not hold nose up to bleed it off before touchdown.
Thanks for any info
Old 08-21-2019, 12:10 AM
  #1463
dr.tom
I took some photos to visualize setup. Do you think tank and turbine should go further back? I would have to cut one beam that is limiting the turbine. Hope that mod is not needed...
Will try to set CG with wing on and compare to Manual(fuselage point) since gear position does not seem same from photos and could be misleading when setting CG from its position rather than wing itself.
Old 08-21-2019, 05:21 AM
  #1464
john491
My Feedback: (13)
My K-70 mounted behind that rear former that your turbine is butted up against. Plenty of room for it there, That entire bay where you have your turbine and tank I used for a large fuel tank, which ends up exactly on CG that way. Half the turbine is visible from the exterior in this position. It also made it easier to achieve the indicated CG. Your CG looks about correct. The CG instructions available when I put mine together called for 1-3/4# ( from memory) nose weight on the nose gear- I had no dimension to work from.
Flaps make a big difference. Mine will stop in 100 feet of touchdown easily. I also discovered that too much flaps will almost stop the plane in mid air, I was using 70 deg full, 35 deg at half. I had to cut that down to maintain a smooth landing.
Good luck with yours, they are fun.
John
Old 08-21-2019, 11:38 AM
  #1465
dr.tom
Thanks for the help,
that landing was with full flaps as pictured below,
but cg is too much forward,
now I have printed lighter front wheel which is around 120grams lighter, and cg should be much better with landing fuel level.
the suggested CG based on distance from main gear (1 1/2 inch) with wings on is not ok on this one,
it calls for 3 inches (double) based on measurements of wing, body, gear placement...
if it does not help, I will have to take turbine out and rethink clamp mechanism to fit it a bit lower and further back.
Old 08-21-2019, 01:37 PM
  #1466
gjhinshaw
My Feedback: (303)
gjhinshaw's Avatar
Move that turbine back!! WAY BACK!! here is a picture of mine...
Old 08-21-2019, 01:39 PM
  #1467
gjhinshaw
My Feedback: (303)
gjhinshaw's Avatar
I also use a A9 radio... My flaps are set-up on the right slider, not a switch.
Old 08-22-2019, 01:01 PM
  #1468
dr.tom
Thnx for all suggestions, things are getting better now with new CG
just have to watch out for intruders on the runway (2:00)
Old 08-22-2019, 05:19 PM
  #1469
gjhinshaw
My Feedback: (303)
gjhinshaw's Avatar
Check my video out....
No flaps on take off.... But slow landing...
https://www.youtube.com/watch?v=zh6iNZV7TD4
Old 08-22-2019, 10:46 PM
  #1470
dr.tom
Your antenna is longer, thats why
Nice flying, bravo!
What happened later, that is 8yrs old?
Old 08-23-2019, 06:20 PM
  #1471
gjhinshaw
My Feedback: (303)
gjhinshaw's Avatar
I was using 72mhz back than. This was the prototype. Still have.
Nice flying, bravo!
Old 08-27-2019, 12:57 AM
  #1472
dr.tom
Nice,
I was thinking about Shocky, do you still have it?
Can you measure CG on your wing, not fuselage like in Manual, please.
I posted wing dimensions 2-3 posts up, so would like to compare them with yours if no problem(wingspan, root and chord dimensions)
Currently i have CG fluctuation of 4 cm from empty/full main tank and still tuning the best one for slower landing yet not too tailheavy when tank is used up at end of the flight...
Thanks a lot.
​​https://www.youtube.com/watch?v=j3iXewfOU9s
Pic from weekend flying:
Old 08-27-2019, 11:22 AM
  #1473
junkjet
My Feedback: (55)
junkjet's Avatar
Just some pics
Old 08-28-2019, 03:13 AM
  #1474
dr.tom
Where could one buy a nose gear like this one?
Old 08-28-2019, 06:09 AM
  #1475
junkjet
My Feedback: (55)
junkjet's Avatar
I see them pop up on Ebay sometimes
