Boomerang Sprint Pro-Link Gear Sets
My Feedback: (24)
Dreamworks Model Products is pleased to introduce the newest offering in the Pro-Link Lineup:
The Pro-Link Sprint Combo has been developed from the ground up specifically for the Sprint. Our Sprint main Trailing Link struts offer a unique proprietary shoulder bolt pivot to eliminate any possibility of wear in the pivot joint. Our Sprint nose strut was developed to provide the perfect aircraft stance without the need for spacer blocks. Our Machined T6 aluminum retracts will provide reliable, durable, leak free operation and take all the abuse you can throw at them.
Our Boomerang Sprint gear are offered in several combo packages;
Boomerang Sprint Pro-Link Strut Package
The Pro-Link Sprint Strut Package includes the following components:
* Pro-Link Sprint Trailing Link Main Struts
* Pro-Link Sprint Trailing Link Nose Strut
Boomerang Sprint Pro-Link Basic Combo
The Pro-Link Boomerang Sprint Basic Combo includes the following components:
* Pro-Link Sprint T6 Machined Retract Set
* CNC Main Retract Cover Plates
Boomerang Sprint Pro-Link Gear Combo
The Pro-Link Boomerang Sprint Gear Combo includes the following components:
* Pro-Link Sprint Machined Retract Set
* 2 Retract Cover Plates
* 2 Standard Air Tanks
* 2 Air Fill Valves
* Intairco 2 5/8" Main Wheels and Brakes
* Intairco 2 1/4" Nose Wheel
* 3 Packs Heavy Duty Airline Tubing
* Brake Line Tubing
* 4 Airline Tee Fittings
* 2 Air Gauges
* Adjustable Rate Retract Valve
* Ultra Precision UP-6 Brake Valve
Boomerang Sprint Pro-Link Gear Combo Deluxe
The Pro-Link Boomerang Sprint Gear Combo Deluxe includes the following components:
* 2 Air Fill Valves
* Brake Line Tubing
* 2 Air Gauges
* Jettronic Dual Action Retract Valve
* Jettronic Proportional Brake Valve
Boomerang Sprint Pro-Link gear packages are available through Dreamworks Model Products, Boomerang Jets and Motors and Rotors.
* 2 Air Fill Valves
* Brake Line Tubing
* 2 Air Gauges
* 2 Air Fill Valves
* Brake Line Tubing
* 2 Air Gauges
My Feedback: (36)
AR
RE: Boomerang Sprint Pro-Link Gear Sets
Hello Todd
Just a question, I thought after the elan ajustable main struts the sprint struts would be the same design, ie straight design so you could utilize a larger main wheel. Looks like their is enough room to do it, is there a reason for the design being like the baby boomer or just designer preference? Again not a gripe just a question.
Thanks, Neal
Thanks, Neal
Good news for the US customers & Sprint fans, the Dreamworks Pro-link retracts that Todd makes for the Sprint are ready now. Patricia will be selling them in a package deal with the kits, as we also do for the XL and Elan.
By simply removing the small curved shape part of the former (it was added by the factory without my say so), each side behind the short nose gear rails and which is now designed out, you can fit the Pro-link gear without any pads lifting the nosegear off the rails. The steering arms drop right in behind the rails, as I intended.
Well done, Todd, I can't wait to fit them to my own Sprint.
Alan
Alan
My Feedback: (24)
ORIGINAL: Undecided
Hello Todd
Thanks, Neal
Hello Todd
Thanks, Neal
The Sprint was designed with trailing link gear in mind and the pocket was already offset for these type of gear. A straight leg strut will not allow for a larger wheel since th pocket has already been offset.
