Reload this Page >
Composite Roo CG
Composite Roo CG
Old 05-18-2003, 02:36 PM
jetflyr
Default Composite Roo CG
I'm triple checking CG before tomorrows maiden flight....and having been burned by mis-printed CG info on other planes.... :
The manual calls for the CG to be 100mm/4 inches in front of the spar.
Anyone have bad experiences there? (Though it does seem "tail-tipsy" while empty there.....
Thanks!
Greg
(Who is worrying over everything at this point)!
Old 05-18-2003, 05:53 PM
Dave Wilshere
Greg
100mm in front of the tube (not Centre line) is a good starting point.
The gear is positioned to give the best take-off rotation ( a problem with the old Roo )
With fuel and the canopy on it will be fine.
Keep the up in after take-off untill the speed builds as the high turbine makes it want to tuck until some speed is reached at high power settings.
Dave Wilshere
UK
Old 05-18-2003, 10:29 PM
Bill_Jehle
Default Roo CG
Right at the screws on the front flange of the main gear. Tail tipsy is normal. Have a great time.
