ATJ Turbines
#102
RE: ATJ Turbines
MRDJ, there is a very good chance Iactually saw your package at Joseph's place, they had a couple of boxes right where we spun up my engine before Ibrought it home only a few weeks ago
Ididn't get a servicing box though, as I went there to pick it up with a trolley suitcase
If I may give you a suggestion, before you test it check the glow plug settings, because the factory ones, if you connect the engine to a fully charged 2s lipo, might very easily blow it right away, no big deal I know, but if it can save your plug, why not
#103
MD
RE: ATJ Turbines
Maurya, my Man
So you're the one who tried to steal my Ti from Joseph - right Just messin' with ya... Yeah, I like the new addition to my engine family. I'm like a Foster Parent with kids of all Races: ATJ, AMT, Evo with more coming. Give me a couple of days and I'll show you where my ATJ will be livin'. I will do a thread of them both as usual. I made a short video of my ATJ yesterday; you may check it out or not, no problema: http://vimeo.com/19230109
Bob, Hotspot, what up, Gents. You like my new son; I call him: Ti
Mr DJ
Mr DJ
#104
RE: ATJ Turbines
Ahah I didn't try to steal it and mine is a 120, but Joseph and I tried very hard to BURN it, lol. These boxes were dangerously close to the exhaust of my engine
Your video owns btw!
Now you've got to make her sing for us
#107
MD
RE: ATJ Turbines
Perche,
Sweet FEJ bird you got there. I never paid attention to the Hawk; I'll give it a closer look. My Ti's home is this one-of-a-kind Mr DJ Special FEJ T-33; I'm Lovin' It!
Mr DJ
Mr DJ
#109
RE: ATJ Turbines
ORIGINAL: hotspot 01
It's gone quiet on the Atj thread so a little info just completed 124 flights on a two year old 120-ti and it's performing well.
I finally got to fly mine (3 times for now) after a couple of issues (kerostart failed after 5 cycles, exhaust cone leaked flame, main cover still leaks over the diffuser...).
This is the graph of a flight on a graupner hotspot:
and this is the flight
[youtube]http://www.youtube.com/watch?v=PUPE7WVEXgg[/youtube]
I think it's running quite hot and the acceleration time is still quite slow, but other than that it seems fine.
We'll see after a few runs, too early to say!
#110
RE: ATJ Turbines
The only issue I've had is with the igniter but you can access it and replace it yourself which is a handy feature. All the other issues you talk about I have never had and the engine has just over 22 hours on it.
#111
RE: ATJ Turbines
Tried with a diesel engine heater, but the heating part of the element was too short I think, could only get smoke.
Also, what are your current settings for accel / decel delay?
RE: ATJ Turbines
He sent me 3 new igniters for 50 dollars they are an off the shelf pre heater for Diesel engines should be easy to find. Would have to look at the figures but I've backed it off a little from the factory settings and it accelerates faster enough.
#114
RE: ATJ Turbines
Hi
The new ATJ-turbines have a new ceramic burner fitted. The ceramic burner is located inside the turbine, like the Jetcat burner. This cant be replaced by yourself. You can ship the old turbines to the factory, to fit the new burner. I have just ordered two 140Se, and they will come with the new burmer, and ECU V.10. I have allso shipped two of my 170ti for having the new burner installed. Will post comment on the new burner when tested.
Christian
Norwegian ATJ dealer.
Christian
#116
RE: ATJ Turbines
ORIGINAL: Mr DJ
Perche,
Mr DJ
Perche,
Mr DJ
How does that baby fly my brother?
Andy
#117
RE: ATJ Turbines
ORIGINAL: Bob Toilet
Hi
Christian
Hi
Christian
Sure as hell I wouldn't buy one which is not replaceable if not by the factory, Joseph has become entirely unresponsive and if the quality of these "new" burners is anywhere close to the one he fitted on mine then I don't wanna have anything to do with it.
#118
RE: ATJ Turbines
The temperature is a little high I don't see more then 650.
RE: ATJ Turbines
I am using a xicoy one (external) right now and it ignites right away at 6,7v. Whole different story.
#120
RE: ATJ Turbines
Hi mauryr
It is new this year. I will soon test the turbines with this burner, and post some comments in this thread.
Christian
Christian
ORIGINAL: mauryr
Hi Bob, how ''new'' is this burner? Mine was installed last summer, and it looks like a hacked diesel heater plug, which is replaceable from under the cover.
Sure as hell I wouldn't buy one which is not replaceable if not by the factory, Joseph has become entirely unresponsive and if the quality of these ''new'' burners is anywhere close to the one he fitted on mine then I don't wanna have anything to do with it.
Hi
Christian
Hi
Christian
#122
RE: ATJ Turbines
Be careful with the voltages was told not to go above 6.9v don't know if that's a restriction on the ecu or the igniter.
#124
RE: ATJ Turbines
Hi
I have now tested the new burner on a brand new ATJ-140SE, and on one of my old ATJ-170Ti wich had the old burner, but i shipped to ATJ for fitting the new ceramic burner. And what a difference! I tested them on a meeting on a frozen lake with temperatures at minus 7 degrees celcius. The burner works perfect, but in this cold weather i had to do some minor adjustments. I had to give both the pump and starter motor more power in the start menu. Other then that it worked great! The new 140SE was delivered with the new Zicoy ECU, V10. So the GSU is connected to the ECU with a JR plug, and not the "telephone cable".
So if anyone have problem with the old style burner, i would reccomend to ship the turbine to ATJ for fitting the new ceramic burner.
Christian
ATJ-dealer Norway
Christian
ATJ-dealer Norway
#125
RE: ATJ Turbines
Hi
Christian
ATJ-dealer Norway
Hi
Christian
ATJ-dealer Norway
Thanks for the heads up Christian!
