Rafale: color codes for this scheem??
My Feedback: (40)
RE: Rafale: color codes for this scheem??
ORIGINAL: Miguel Santana
Guys, give me a hand having the codes for these colors...
MS
BTW...I'm open to other scheem options...
MS
That's one problem with the Rafale......there are very few color scheme variations on the full scale to choose from (assuming you want to paint it scale). Also, the colors seem to have a different hue depending upon which picture you are looking at. I don't know if the French/Europeans have a coloring system similar to the FS numbers used by the USA.
I just picked a good photo from an Air Power book and matched the colors as best I could.
Craig
Hey Miguel.
Unless you are going to compete in scale comps forget about a scale scheme.... I See this so many times where people paint a pretty looking plane in boring colours just because the full size is that way. The Full size is that was so it isnt seen! We try to make our models to be seen and noticed both in the air and on the ground.
Let you imagination loose. Sketch some schemes, or look at other aircraft new and old and see if you can borrow/ Adapt the colour scheme to suit your model. I do this allot with my scale planes. For me it is far more important to have a model that I really like the look of that to have one that is accurate to scale.
A good example....
A good example....
Thanks Graig....Ali's suggestion got me thinking...
Hi Ali...you are right about it...I'll give it a try.
BTW...I heard you're going to have a container loaded with big size jets for an event in Florida next October. I'll pm you about.
Take care,
MS
Found this for you http://www.jpsmodell.de/
but i agree with Ali,i used to fly an Aviation Design Rafale for a guy
and its not good to see in the light blue camo.
regards
brian
regards
brian
Hi Miguel,
I found these pictures from www.airliners.net (use the search engine with keyword Rafale) and via google with words ocean tiger rafale. Via airliners.net you could contact the photographer and ask whether they would have more pics of this "Ocean Tiger Rafale".
Regards,
Joni
Regards,
Joni
Hi Joni, nice to see you here!
That's absolutely the best non-camo - but still scale - color scheme I've ever seen on Rafale.
Thinking of going with this scheme yourself??
Regards,
Janne
Regards,
Janne
Hi Janne!
Well, this latest Tiger Meet scheme indeed looks best so far. How did you guess that I'm thinking of this one?
At least it is scale and has the cool effect. Much better than this current "Aviation Design Demo" scheme which I have.
ORIGINAL: Fullcrum
Now just a little bit of sanding and off you go...6 or 7 yellow/orange -shades, black and grey - easy as 1-2-3. Paint booth is just waiting for your Rafale (don't know if P.M. is reading). Paint guns and other stuff no problem...
Hi
I just finished my AD Rafale upgraded with a BVM landing gear. The camo is approching the real one but not exactly truth color. Because the real camo is a bit difficul to see from the ground.
Empty weight : 14,3 Kg
Ready to take off weight : 17,2 Kg
GTR : Jet Cat P160 SX
The flight is very stable , no trim to set , landings are easy and the gear is "bullet-proof".
Stan
Stan
Bonjour Stan,
Magnifique ton Rafale!A bientôt j'espère sur un meeting de Mach 2.2!
Joyeuses fĂŞtes,très bonne annĂ©e et surtout très bonne santĂ© Ă* toi et tous tes proches!Etienne Bedossa.
Hello Etienne
Carefull, we have to speak english on the forum. Moderators are AWARE !!
I'll be at the " French Riviera jet show" on the 1st of May, then probably Amberieu.
Did you receive your MIG 29 ?
I would like to build a MIBO A10, od you know someone own this in France ?
A+
Stan
A+
Stan
Anton told me the Mig 29 has been shipped yesterday!I don't know any french guy flying the Mibo A10,you will be the first one!A +.Etienne.
Hello Marc.
We met together several times at "LE LUC" and "jet power".
I don't replace any formers, just have to modify them , and after to wrap some carbon or kevlar/carbon between them and the fuse.
See pictures.
In French: " salut Marc, on s'est rencontrĂ© plusieur fois au Luc et au Jet Power . Je suis un copain de Christophe et Arthur. Il n'y a presque rien Ă* changer pour remplacer le train. J'ai renforcĂ© l'accrochage des couples au fuselage par des bandes de carbone et carbone / kevlar. Le train est fantastiquement solide et mĂ©rite vraiment de remplacer le train d'origine : rien Ă* voir !!!."
See you
Don't hesitate for details.
Stan
See pictures.
See you
Stan
