Yellow F-16 turbine conversion from DF
My Feedback: (106)
PA
Considering converting Yellow F-16C (latest version) from Df to turbine power (JetCat P-60). Is conversion realistic for a Yellow F-16 that is already built for DF? As the DF ducting leaves very little room for fuel tanks - are conformal tanks, or any tanks for that matter, available for this configuration? Is a bypass necessary or advised? Single or double wall pipe? Any help or advice, especially photos would be much appreciated.
RE: Yellow F-16 turbine conversion from DF
Hi,
Fuel capacity will be your biggest problem. Gary Mueller makes conformal tanks for the F-16 (older version prior to the turbine inlet). It'll be a pain to get them in, but you don't have much in the way of options now that the fan inlet is installed. You don't need a bypass, and the P-60 will be a wonderful combo in that plane.
My Feedback: (106)
PA
Shawn, thanks for your advice - can you post the contact info. for Gary Mueller.
Dumb question but, since a bypass is not needed, I assume there is no need for double wall pipe? Where can I get single wall pipe?
Any trouble flying off grass with a P60SE? What kind of performance can be expected? Not interested in speed, only want to be able to perform scale demo-flight maneuvers.
Hi,
Give me a call on your questions: 619-944-7574. As for the pipe, no you still need a double-walled pipe. You probably couldn't find a single-walled pipe in use these days....
