Wheels for Kavan electric brakes
The smallest wheels I can find that work with the Kavan electric brakes are 4 inches. Has anyone used these with smaller wheels, 3 to 3.5 inches? If so, part numbers please.
Later;
D.W.
Later;
D.W.
NM
RE: Wheels for Kavan electric brakes
In essence, the Kavan brake is the same thing, just a larger diameter winding. Instead of pulling in a plunger or piston, it pulls in the brake disc.
That is, unless you mean something entirely different ? []
... zak
... zak
ORIGINAL: starzak
... zak
... zak
AB, CANADA
http://www.hobby-lobby.com/wheels.htm
Scroll down to the bottom of the page...
Bruce Tharpe has a lot of info on these brakes in one of his updates. I believe you can buy the Kavan brake from Bruce (http://www.btemodels.com/r54.html) as well.
http://www.btemodels.com/Downloads/R54Updt6.doc
They work okay, not as powerful as a good o ring brake system, but a fraction of the price, and no airleaks to worry about!
NM
Hobby Lobby wants about $65 for it. SIG gets $40.
You make the call.
... zak
Here yer go ............ > http://www.sigmfg.com/cgi-bin/dpsmar...m_02KAV0263_01
You make the call.
... zak
Hanger 9 Prolite 3".
The Hangar 9 wheels also have a recess in the size of the rim that suits the disc perfectly. - John.
NM
I'm using a plain jane 2 3/4" wheel with no problem. Just drill small holes to accept the two tabs on the brake disc, and them ShoeGoo it squarely in place. Space it out from the brake drum 1/64", and make sure to use a full 9 volt transistor battery on it. Anything less and you're cheating yourself. The 9v. transistor batteries are cheap and easy to replace using the button connector, and they don't impact your important on-board radio, and ECU battery. Works like a champ !
... zak
... zak
