UT-160 turbine? Feedback please?
Old 01-30-2012, 07:12 AM
  #151
chrigui
chrigui's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: UT-160 turbine? Feedback please?
compressor is chinese made...
close tolerance between compressor and cover intake, lubrication oil in front of each bearing, diffuser with air hole for lubrication flow,
injector ring in the rear of combustion chamber.., exaust cone 1,5mm diamenter bigger than original draw
need improvement for lower the egt at higt rpm
chrigui is offline
Old 01-30-2012, 07:57 AM
  #152
basimpsn
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
That's interesting any pictures. I'm planning to purchase a UT-160 kit for my RHINO.
basimpsn is offline
Old 07-18-2012, 10:03 PM
  #153
chrigui
chrigui's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
after long time engine sleep the problems come back!!! [:@][:@][:@][:@]
chrigui is offline
Old 10-03-2012, 04:07 AM
  #154
chrigui
chrigui's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
pdr... please check the gap compressor / diffuser
chrigui is offline
Old 10-03-2012, 04:48 AM
  #155
basimpsn
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: chrigui
That's a big ***** gap
basimpsn is offline
Old 10-03-2012, 05:02 AM
  #156
chrigui
chrigui's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
in origin 1mm diameter .. 0,5 radius
chrigui is offline
Old 10-04-2012, 04:32 AM
  #157
chrigui
chrigui's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
control cc alignement
13 diffuser vane
12 hole row..
then 2 row are behind wedge diffuser....
ID:	1807710   Click image for larger version
chrigui is offline
Old 10-04-2012, 04:57 AM
  #158
frema
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
what is your problem?
do you have the same problems as Gerald Rutten has?
Surge?
i am a friend of him
i designd so many engines
for big companies , nothing is new for me
let me have a good video , not one you post here, because i can not hear anything on that
and show me what is your problem
do not think its the compressor or diffusor or feulrings
dont listen to those people who tells you they know everything about turbines, but never build one
do like i tell you
and toghether we get the engine running like a dream
well first of all
i want to know what is your problem
if its surge
then its easy
but first let me know oke?
frema is offline
Old 10-04-2012, 05:16 AM
  #159
chrigui
chrigui's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
hi frema..come in modelbowforum..
2 ut160 build... same hot spot in same zone
rebuild all parts..but in the hot spot zone the hole row are behind the diffuser wedge
chrigui is offline
Old 10-04-2012, 05:43 AM
  #160
frema
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
its not good
there is more
but i will come
regards,
Martin.
frema is offline
Old 12-10-2012, 06:09 AM
  #161
chrigui
chrigui's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
after some time spent to servicing another engine i give some improvements
in ut160 project (2 engines)
new diffuser design (thx martin)
new CC design
then.. no hot spot , low egt temperature and 0,8-1kg more trust than UT160 chart
before
[youtube]http://www.youtube.com/watch?v=gn3li_cQVrY[/youtube]
after
[youtube]http://www.youtube.com/watch?v=lM8Gm10_GPw[/youtube]
trust at 35.000
chrigui is offline
Old 12-16-2012, 04:05 AM
  #162
salibaj
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi,
I am building one of these UT160. Is there any chance that you publish the changes please?
Regards
Joseph
salibaj is offline
Old 12-16-2012, 11:54 PM
  #163
chrigui
chrigui's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
same modify on second engine built
[youtube]http://www.youtube.com/watch?v=tccqPOTJgqU[/youtube]
100k rpm chart comparison
[youtube]http://www.youtube.com/watch?v=Ftjwy42VrQo[/youtube]
chrigui is offline
Old 12-18-2012, 11:25 AM
  #164
salibaj
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Chrigui,
I would like to know the modification you did if it is possible.
Thank you
Kind regards
Joseph
salibaj is offline
Old 10-24-2016, 02:55 AM
  #165
rupesh rupak
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Guys, I am resurrecting this thread cause I know you guys have good experience in turbine. I have few questions:
1. 81 mm Borg&Warner compressor wheel is used by GR 220. Here 81 mm is exuder or inducer dia?
2. Have Rutten released GR220 plans yet?
3. Is there any correlation between compressor wheel design and diffuser angle in GR 180 design. I am asking this because I am not able to find
Schwitzer compressor wheel. Any other automobile turbocharger of same inducer/exuder dia will do? or I will have to modify the diffuser angle?
4. How did you guys machined the diffuser cover inner curves which remains very close to inducer & almost follows its contour?
Thank you. I hope you guys are reading this and will reply.
rupesh rupak is offline
Old 10-24-2016, 03:55 AM
  #166
chrigui
chrigui's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
this is my engine with schwitzer..i used old ut160 intake cone adding half new one
ID:	2187396   Click image for larger version
ID:	2187397   Click image for larger version
ID:	2187398   Click image for larger version
chrigui is offline
Old 10-24-2016, 04:08 AM
  #167
rupesh rupak
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Chrigui, I read this thread n times..you are here from the beginning. I really admire you. Great work really. Can you share your experience a bit. Do you have page like GR? Any online repository from where I can see your design or pics. I am a leaner and intend to build one turbine. Its been 4 year since the last post here, you must have improved your design a lot. Hope that You would share it.
Old 10-24-2016, 04:41 AM
  #168
chrigui
chrigui's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
the design is the same of gerald web page..
only exhaust cone is different because with long cone (jetcat style)
there was less trust than short cone as frank turbine design..
Combustion chamber is ut 160 design
chrigui is offline
Old 10-24-2016, 05:03 AM
  #169
rupesh rupak
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Great, can you answer Q 3&4.
Old 10-24-2016, 05:15 AM
  #170
chrigui
chrigui's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
3 - s ... necessario per controllare l'angolo e lo spazio scommessa
4 - CNC
chrigui is offline
Old 10-24-2016, 06:31 AM
  #171
rupesh rupak
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
schwitzer compressor is now hard to find..can I use garret GT3782
http://www.ebay.com/itm/Garrett-GT37...hUjPjC&vxp=mtr
in GR 180 design? This one is used in UT160 I guess. It has same inducer dia..the exuder will have to me turned & then balance it.
Old 10-24-2016, 06:46 AM
  #172
chrigui
chrigui's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
in ut160 it's used a garret 409179-0024
chrigui is offline
Old 10-26-2016, 10:55 AM
  #173
rupesh rupak
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
what is the relation between the diameter of tubine engine(or say thrust capacity) and its CC length? Cause I think the length of CC of a p120 is almost same as p180. Is it true? I didn't find any such relation in kamps book but I think the length of CC should increase with higher turbine diameter or say higher thrust capacity but I don't find any mathematically relation so far. Any help guys !!!
Old 11-08-2016, 04:04 PM
  #174
njleroux
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi All
I am looking at building the UT160-ZA turbine. Really struggling to purchase the plans for the UT160, have send a request off to Ulrich (the designer) at www.ut160.de.tl as I am interested in purchasing the plans.
Have not had any luck with procuring them yet.
Do you know where I can buy the plans for the UT160?
Nico
njleroux is offline
Old 11-08-2016, 10:30 PM
  #175
chrigui
chrigui's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Originally Posted by njleroux View Post
Hi All
Nico
http://www.ebay.de/itm/Bauanleitung-...2ReN1c4fdgwkHQ
chrigui is offline
Copyright 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
