Electric smoke system - Smokewinder
My Feedback: (26)
With the new powerful and lightweight batteries on the market, would it be possible to generate wingtip smoke generators (smokeWinders) that would generate similar smoke as what our turbines generate?
I'm thinking a solution with a coil heater fed by a smoke pump. This solution could also be used for electric jets. A centrally mounted smoke tank feeds a red hot coil in each wing tip, or a central coil in the electric jet exhaust. The coil would be sitting inside an aluminum tube, open in both ends so the airstream can push the smoke out.
I found this company http://www.nphheaters.com/quote/coil...ng_heaters.htm and they seem to have coils in all sizes.
HI
RE: Electric smoke system - Smokewinder
Hi John
Been thinking about that too. I was also looking into using a catalytic burner like the ones used in the butane soldering irons to heat a smoke manifold. I haven't found out how to make one yet.
However with the ama regs it might be easier to make a electric one. Sort of like a Lionel train smoke system on ultra high.
My Feedback: (10)
CT
Smokewinders would be the awesome. I was thinking of ways to make this work a few months back. i was thinking of coils as well as something like the kero start plug that jet cat uses. im not sure how long something like the plug would last though. Would definitely be cool if they existed though.
Rich
Rich
I have been thinking about doing thesame thing on my BIG F16. What about these smoke cartridges put them in a hollow tube with openning at the front to push the smoke out.
http://www.regin.com/rcsmoke.html
My Feedback: (21)
the cruising speed for jets will dissipate the smoke too quickly on the park flyer cartridges. Tower used to sell smoke cartridges (not sure if they still do) i used 'em a few years ago on my Yellow A4 DF and they worked great.
airborne ignition via a 9 volt batt, micro switch and rocket igniter glued into fuse worked fine, pretty dense smoke for a few minutes
yup, looks like they still sell it.
FEATURES: Produces approx. 3 minutes of dense grey/white smoke No need for plumbing to exhaust, messy fluids, or residue clean-up Mount to fuselage by using a clamp (not included) in marked locations Only. Light fuse to begin smoke reaction.
INCLUDES: One Smoke-Riter Cartridge w/Ignition Fuse
SPECS: Length: 6" Weight: 6 oz (including light blue wrapper) Diameter: 1-1/2" Fuse length: 2-1/2"
COMMENTS: Smoke release holes must face ground. Smoke is TOXIC. Avoid Prolonged Exposure. Clamps to hold cartridge to the fuselage (try a hardware store).
ORIGINAL: -JC-
I've being toying with the idea of Smokewinders too. Unfortunately, I don't think these coils have enough capacity to do the trick. The manufacturer's web page is missing a couple of critical pieces of info (voltage, max amps) but doing a few calculations......
The amount of energy it takes to vaporize diesel fuel [close enough chemically to "smoke juice"] = 3340 BTU/gal = 27530 Joules/oz
The Tamjets smoke pump in my Gripen empties the 22oz tanks in about 2-1/2 minutes at the low setting -> Flowrate = .15oz/sec
Therefore the coil would have to accept 27530 x .15 = 4130 Joules/sec = 4130 Watts to vaporize the smoke juice.
Assuming that the coil happens to use the typical voltage from an ECU battery (11.1 Volts).....The coil would have to be rated for 4130/11.1 = 372 Amps (which I doubt it is).
Still, it's a fantastic idea. Keep dreaming, technology will eventually catch up. Now where did I leave those dilithium crystals????
Regards,
Jim
Why not try and reproduce the full-size smokewinders principle? They use a burner where the smoke oil is injected at the nozzle-end, same as we do at the turbine end. In our case we could make a burner up to smokewinder diameter (ie, 1/6.8 scale F16 = 25mm), feed it by a gas canister which is lit before flight and will have just enough fuel for a complete flight and pump the smoke oil on command at the aft end of the burner nozzle. I think this is the only way of having an on/off system with enough energy to make sufficient smoke?
See here the Sanders smokewinder with below the page a downloadable manual:
http://www.sandersaircraft.com/gener...mokewinder.asp
Rgds,
Gerald
Rgds,
Gerald
In RCAIR gallery from Jim Brown videos, there's one from Michigan Jets with a 339
with smokewinders. The name of the pilot is there.
Go to the site and see it.
Hector
Hector
any news about the MB339 smoker?!
yesterday my hot air gun died so I took the system inside and fired it up with 12S Lipo (50A@ 1,5A) and gave oil on it. It works but i think not in the air.....
regards Martin
regards Martin
I have been thinking about how I could make my Mibo A10 have smoke come out of the gun in the front. And this has got me thinking. I wonder if I could rig a very small fan with some duct work to blow it out the front? It won't have to be on for any more than 5 seconds at a time so a giant battery is not necessary. Any ideas?
ORIGINAL: hyrumflyer84
The problem is, once you light the fuse, the smoke cannot be shut off. The fan would have to be very powerful to overcome the ram-air into the blades.
AZ
If you guys read RC Jet International and can read German, then on page 39 of the Dec/Jan issue is an blurb about an electric smoke system. I went there but could not make sense out of the language.
www.smokeel-shop.com
