Composite ARF Mig29
Reply
Old 11-08-2018, 06:49 AM
  #476
hemi
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Craig
two migs has got to be better than one. I’d love it.
John
hemi is offline
Old 11-08-2018, 09:24 PM
  #477
spaceman 01
My Feedback: (44)
spaceman 01's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
OK guys I just got my CG to be 25 mm forward of the front main spar but now I have another issue my nose gear is collapsing completely practically my nose of the airplane is touching the ground how can I get the nose Strut to be more stiff. Levi can you please check the picture and tell me if my CG is good
spaceman 01 is offline
Old 11-08-2018, 09:30 PM
  #478
spaceman 01
My Feedback: (44)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I had to install all my batteries in the nose cone so I can get this CG,by the way my Mig is weighing in to 25 kg/55 pounds dry does that sound OK.
Old 11-09-2018, 02:26 AM
  #479
Levi Wags
Levi Wags's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Nick your cg is ok. Mine is 5 mil further back but yours should be ok for maiden. I had the same issue with my nose leg. If you try to fly it like that TO will be ok as the weight is at the rear but it will collapse on landing. With the Mig 29 there is a massive amount of weight on the nose leg as itís very far back. Is your strut compressing or is the leg actually retracting on its own?
i pulled my strut apart and added some tygon inside the spring to stiffen it up. If the leg itself is starting to fold back Iím guessing you must only have one ram on the nose gear. Mine would not work with just the one ram. I needed the upper and lower rams to have enough holding and retraction power, as did Graig.
Dont fly it if itís borderline mate.
PS You weight is on the heavy side of ok. Mine is 24.5kg dry with all the options.
Levi Wags is offline
Old 11-09-2018, 04:26 AM
  #480
spaceman 01
My Feedback: (44)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Levi thanks for the response, both things are happening as you mentioned what do you mean by the upper and lower ram can you let me know thank you Nick.
Old 11-09-2018, 05:16 AM
  #481
hemi
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Nick
You’ve done some fine work so take your time and get it right. The weather probably won’t cooperate anyway.
John
hemi is offline
Old 11-09-2018, 05:58 AM
  #482
spaceman 01
My Feedback: (44)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thank you John I just saw what you meant there is snow on the ground as Iím taking my kids to school .
Old 11-09-2018, 05:59 AM
  #483
spaceman 01
My Feedback: (44)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Chicago weather !
Old 11-09-2018, 06:08 AM
  #484
hemi
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
We are getting it today as well. Have a great weekend
hemi is offline
Old 11-09-2018, 06:10 AM
  #485
spaceman 01
My Feedback: (44)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
You too John
Old 11-09-2018, 06:46 AM
  #486
Craig B.
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi Nick,
the later version of the nose gear had a modified upper frame that allowed for connection of a separate hydraulic ram that ran along the floor of the fuse under the cockpit area. If you look carefully at my fit out picture you may see it. Levi and I are using both rams on our nose legs. That is why our nose legs move with authority (check out my vid above). The upper ram has better geometry for fully retracting the nose gear; the original scale ram that attaches to the front of the nose leg has better power for holding the nose leg in the down position.
I inserted a delrin spacer inside my nose leg to compress the spring inside the strut. This made it feel stiffer and also limited the compression that could take place by providing a hard stop that limited the compression. Levi stiffened his nose leg up by putting tygon fuel tubing inside his spring.
Hope that helps.
Craig B. is offline
Old 11-09-2018, 07:01 AM
  #487
spaceman 01
My Feedback: (44)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thank you Craig are you referring to two different cylinders I have the big one the main one which is a lucking type in there,I cannot see where you have install the second one in your picture .
Old 11-09-2018, 07:13 AM
  #488
Craig B.
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi Nick,
the cylinder is housed within the wooden box in the centre of the picture....do you have that cylinder?
Craig B. is offline
Old 11-09-2018, 07:19 AM
  #489
Craig B.
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Nick,
see attached pic.....
Craig B. is offline
  #490
spaceman 01
My Feedback: (44)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Yes Craig,thatís the one that I have and from my understanding when it travels to the down position it locks but still I have lots of play with in the whole system. Thank you Nick
Old 11-09-2018, 07:24 AM
  #491
Craig B.
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Yeah ok, that ram does not lock the nose gear in the down position very well. It is good on the retraction end but not so great on the down lock end. We are also using the scale cylinder that runs down to the front of the nose leg that you can see in my youtube vid posted above....that one really helps lock the nose leg in the down position well....better geometry than the top ram. Are you using that ram?
Craig B. is offline
Old 11-09-2018, 07:30 AM
  #492
spaceman 01
My Feedback: (44)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Mine is set up with a static type one just for looks. Where can I get a cylinder that travelers that long ?
Old 11-09-2018, 07:31 AM
  #493
spaceman 01
My Feedback: (44)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Tonight I will post how mine looks.
Old 11-09-2018, 07:37 AM
  #494
Craig B.
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I thought that might be the case. I would take some measurements and speak to Peter Hausl...he used to be able to make locking cylinders of custom length. Tell him what it is for. Gotta have that nose leg reliable...don't want to dig that nose into the dirt on landing!
Let us know how you get on.
Craig B. is offline
Old 11-09-2018, 07:41 AM
  #495
spaceman 01
My Feedback: (44)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Craig is this the same Peter that makes that hydraulic system for it. thank you Nick
Old 11-09-2018, 07:53 AM
  #496
Craig B.
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Yes Nick
Craig B. is offline
Old 11-09-2018, 08:30 AM
  #497
spaceman 01
My Feedback: (44)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
thank you, Craig
Old 11-09-2018, 04:37 PM
  #498
spaceman 01
My Feedback: (44)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Here is my setup for the nose gear, I just saw where the problem is I need to incorporate one more cylinder or something to hold the strut from backing up under force.
Old 11-09-2018, 05:01 PM
  #499
spaceman 01
My Feedback: (44)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Also I needed to put all the batteries and most of the controls right in the cone of the Mig
Old 11-10-2018, 02:59 AM
  #500
Levi Wags
Levi Wags's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Nick Craig covered it. That bottom 45 deg ram needs to be active. It’s the only thing stopping you from eating dirt
