Gyro questions
TX
RE: Gyro questions
i was wondering if somone could help me with my jr g500t gyro on my e325 mini titan i love the gyro it works well but i having a problem with it just wandering wherever it wants to go i bought this gyro so i could have the tail lock setting maybe i am doing somthing wrong?? i am using a dx6 transmitter please somone help
RE: Gyro questions
Wondering if anyone has tried a Futaba 190 gyro. I have one on my TREX 450 and i've upgraded it to another gyro. So this Futaba one is laying around, just looking at me to put it in something.
I was thinking of using it on my Jet Legend F-16.
If anyone has tried this gyro on a jet, appreciate some comments on it.
Regards,
Orlando
Regards,
Orlando
RE: Gyro questions
Hi Orlando,
Since you cannot switch this one off or decrease the sensitivity in flight, I would not be using it for a jet, except perhaps for the nose wheel steering. There it could be of good use.
Nicolas.
Nicolas.
RE: Gyro questions
Hi all
At the risk of thread creep...
Which control surface do most people stabilze with a gyro..I am guessing rudder or aileron?
Toying with the idea of putting one in my Bobcat.
Regards.
Phil.
Regards.
Phil.
#31
RE: Gyro questions
I'm looking at putting one for the ailerons. I'll do some high speed taxi and see how the steering is. Guess I can always install the 190 for the steering as mentioned by SpiderJets.
I'd like to get a little less wing rocking while landing at higher wind speed. Hopefully it will maintain a better approach without all the corrections.
Orlando
Orlando
#32
RE: Gyro questions
I do not understand your post very well.
The Futaba GY190 should be put in between the RX and the nose wheel servo.
It will track your plane straight during take-off, and has even more advantage when you apply wheel brakes (unvoluntary differential in braking between left and right wheel would cause your plane to turn)
The manual can be found on the Futaba website : http://manuals.hobbico.com/fut/g190-manual.pdf
Nicolas.
Nicolas.
#33
RE: Gyro questions
ORIGINAL: BIGBARPER
Hi all
Regards.
Phil.
Hi all
Regards.
Phil.
#34
RE: Gyro questions
Lately I have seen guys do smoking low passes down the runway... later I was told all these aircrafts were equipped with gyros. I would certainly consider using a gyro on the roll and pitch axis so even I could do those extremely high speed 2 inches over the tarmac passes...
#36
RE: Gyro questions
Try one of the ACT's, you'll love it.
PS. I believe my friend cairoman still has his Futaba's GY351 and GY352 (which were in the JL L-39 which I sold him, he took them out. PM him whoever is interested ?)
#37
TX
RE: Gyro questions
Gents.. just in case someone was looking the GY611+S9256 is available for $287,- (incl. shipping) at www.hobbypit.com
#38
My Feedback: (18)
RE: Gyro questions
Question on Gyros and mixers
If you want to mix your servos and use a gyro do you have to do the following:
Have the $40 gyro after the RX and then the $12 mixer and next your servo.
Or can you use, lets say a $2200 14MZ with your mixes with in the 14MZ radio- condictions 1,2,3,etc and use a $150 to $250 Futaba Gyro GY351,or GY352 and then your servos.
I am setting up a SU-34 Jet to do high Alpha and I need a lot of mixing
