If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Page 1 of 4 123 ... LastLast
Results 1 to 25 of 84
  1. #1
    Join Date
    Dec 2002
    Jasper, GA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    The Pilot's Fei Bao SU-27 Build *** Flight *** Report
    I brought home the SU-27 from FIJR two weeks ago and have been building since. I promised Wagner I would share information as I went.
    Keep in mind, this is a prototype and FB has been responsive to suggested changes in the past, so the production kits will probably be a bit different.
    Overall, my impressions are favorable. The kit components totalled only 25 pounds out of the box. By my calculations and allowing for some nose weight, the plane will be right at 40 pounds when completed. I am planning to install two Rabbits, which will provide a 1 to 1 thrust to weight ratio dry. The plane was very simple to build. I worked a few hours here and there, and in just over two weeks, I will have the plane up to the point of engine installation.
    I started with the air systems, which were mounted in the nose. Plenty of room. The little blue unit is a sequencer that will soon be offered by Jet Central as the exclusive US distributor ... it has three completely programmable channels, air and voltage system failsafes, and switches that operate lights in conjunction with gear position. Nifty little unit.
    Attached Thumbnails Attached Thumbnails Click image for larger version.
ID:	1079108   Click image for larger version.
ID:	1079109   Click image for larger version.
    Keith Sievers
  2. #2
    Join Date
    Dec 2002
    Jasper, GA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: FB SU-27 Build
    The nose strut is a piece of art. There is plenty of room to access the gear. I did replace the wood screws with bolts and blind nuts.
ID:	1079114   Click image for larger version.
ID:	1079115   Click image for larger version.
    Keith Sievers
  3. #3
    Join Date
    Dec 2002
    Jasper, GA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: FB SU-27 Build
    The main gears swing nicely into place.
ID:	1079121   Click image for larger version.
ID:	1079122   Click image for larger version.
ID:	1079123   Click image for larger version.
    Keith Sievers
  4. #4
    Join Date
    Dec 2002
    Jasper, GA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: FB SU-27 Build
    The intakes pop off with two bolts providing excellent access to the gear and engines. The intake tubes are already integrated with the fuselage sections. I did reinforce the seam with thin glass cloth and CA.
ID:	1079125   Click image for larger version.
    Keith Sievers
  5. #5
    Join Date
    Dec 2002
    Jasper, GA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: FB SU-27 Build
    The pipe is excellent quality. I opted to skip the bypass, and Carlos of RTI has provided a couple of nice bellmouths for the pipes.
    Plenty of room and access for mounting the Rabbits.
    The fuel capacity on the prototype was limited ... this is one of two tanks of about 1.8 L or 60 ounces of capacity. I am working with Jet Tech to add another 25 to 30 ounces a side.
ID:	1079138   Click image for larger version.
ID:	1079139   Click image for larger version.
    Keith Sievers
  6. #6
    Join Date
    Jan 2002
    Mother Earth, the Sunny side!
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: FB SU-27 Build
    Looking good Keith, keep it coming. I may get the Mig 29 from SM when it is released...
    Regards, E. \" Smoking Sam\"
    The Truth is out there, Seek it!!
  7. #7
    Join Date
    Jun 2007
    bedford, NH
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: FB SU-27 Build
    The Fei Bao SU_27 looks like a great plane with typical fei Bao quality. Nice to hear they will listen to suggestions from an early builder.
  8. #8
    Join Date
    Dec 2002
    Jasper, GA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: FB SU-27 Build
    Here are a few pictures of the initial servo installs. I like the integrated nose steering ... very easy to install and set up.
    The elevator servos dropped into their mounts with no fitting needed. The horizontal stabs slide into the pre installed bearing boxes and have a slot at the end to make sure they don't slip. I cinched down the bearing bolts and then pinned the stab spar for an extra measure of safety. The linkage is short and rigid, not much slop in the install. You can see I used an SWB servo arm on the High Torque Airtronics servo.
    I am at relatives for a few days, but will have the rudders and the wings done by Sunday and will post pictures of these and the assembled kit by the end of the weekend.
ID:	1079207   Click image for larger version.
ID:	1079208   Click image for larger version.
    Keith Sievers
  9. #9
    Join Date
    Jul 2005
    Izmir, TURKEY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: FB SU-27 Build
    What thrust turbine will you use on the SU 27?... Or what brand?
    Murat BΓΌkey
    Dealer for TURKEY: JetCat, Wren, EvoJet Booster Turbines, Feibao Jets, Jetlegend, Powerbox Systems, Redwings
  10. #10
    Join Date
    Jul 2005
    Izmir, TURKEY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: FB SU-27 Build
    Sorrry now I see you will use two Rabbits... Is there any possibility to use one turbine with bifurcated pipe?...
    Murat BΓΌkey
  11. #11
    Join Date
    Dec 2002
    Jasper, GA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: FB SU-27 Build
    No possibility. The intakes are very far apart and the fuselage cross section in the middle is very thin. This is probably why you don't see a large number of SU-27 kits on the market today.
    Keith Sievers
  12. #12
    Join Date
    Jul 2003
    Rio Grande, PUERTO RICO (USA)
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: FB SU-27 Build
    Hi Keith,
    Nice work and great plane! Now that you are working with it, what about a possible one engine installation in one nacelle? Who big is the engine bay area to fit a big block?
    Alex
    Team Jet Central
  13. #13
    Join Date
    Jul 2005
    Izmir, TURKEY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: FB SU-27 Build
    It really looks nice to have a twin turbine aircraft...
    Can you post some pics of the turbine fitting areas if possible?...
    Murat BΓΌkey
  14. #14
    Join Date
    Dec 2002
    Jasper, GA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: FB SU-27 Build
    ORIGINAL: avicom
    Hi Keith,
    Alex
    I am on the road, but will check it out when I am back home this weekend. I have a Rhino I can try to fit in the space ... it might go.
    Keith Sievers
  15. #15
    Join Date
    Dec 2002
    Jasper, GA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: FB SU-27 Build
    ORIGINAL: bukeym
    See post 5, middle picture.
    Keith Sievers
  16. #16
    Join Date
    Jul 2008
    Hometown,
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: FB SU-27 Build
    looks like this is going to be a nice kit Keith.
    Cheers,
    Ro
  17. #17
    MESHAL's Avatar
    Join Date
    Sep 2007
    kuwait, KUWAIT
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: FB SU-27 Build
    HI ALL. AND NICE JOB . CAN YOU TELL ME THE PRICE ? PLZ
  18. #18
    RE: FB SU-27 Build
    ORIGINAL: meshal
    You can check the prices here at http://rcjetmodels.com/index.php?_a=...&productId=307
    Wagner Machado
  19. #19
    MESHAL's Avatar
    Join Date
    Sep 2007
    kuwait, KUWAIT
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: FB SU-27 Build
    thanked Keith
  20. #20
    Join Date
    Dec 2002
    Jasper, GA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: FB SU-27 Build
    Finished up most of the construction this weekend. These pictures show the drop in installation of the 3301 rudder servo and the control linkage.
ID:	1082258   Click image for larger version.
    Keith Sievers
  21. #21
    Join Date
    Dec 2002
    Jasper, GA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: FB SU-27 Build
    The Flaperon 8611a servo fits into a ply wing rib. No hatch in the wing ... just cut a slot. Very quick install.
ID:	1082260   Click image for larger version.
    Keith Sievers
  22. #22
    Join Date
    Dec 2002
    Jasper, GA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: FB SU-27 Build
    Wiring to the front of the airplane for servos, and then the install of the Emcotec BIC switch and air systems in the cockpit. Note the JMP fill valves.... love these things.
ID:	1082262   Click image for larger version.
    Keith Sievers
  23. #23
    Join Date
    Dec 2002
    Jasper, GA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: FB SU-27 Build
    A better shot of the nose gear ... also the aft end of the aircraft with the nicely painted tail cones and rear fuse extension in place. It was raining out yesterday so I couldn't get a shot of the entire aircraft, but it is now completed, waiting on engines and extra fuel system components.
    This was one of the easier builds I have done. While I am waiting for the engines, I am going to do some prelimiary weight and balance calculations and do a reestimate of the total weight.
ID:	1082271   Click image for larger version.
    Keith Sievers
  24. #24
    Join Date
    Jan 2002
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: FB SU-27 Build
    Keith, where did you get the emcotec BIC switch? and how much?
  25. #25
    Join Date
    Dec 2002
    Jasper, GA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: FB SU-27 Build
    http://emcotec.e-vendo.de/e-vendo.php?shop=k_emcotec_e
    Cost at the time was around 170 shipped, but that might have dropped by now. I ordered three about the time that the exchange rate was the worst.
    Desert Aircraft used to carry the black units and you might see if they have any in stock. I was looking for colors, so I ordered direct from Germany. I tried to order from HKM at one point but he was unreliable.
    Keith Sievers
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
