Boomerang Nano!!!
#1051
RE: Boomerang Nano!!!
ORIGINAL: BaldEagel
I perfer to not have to strip down and rebuild at all LOL, I prefer to fly rather than fiddle with the turbine every time I go to the field, never had a problem with my JetCat or Merlin and in truth never seen any problems either, when JetCat first brought out the external Kero start they did have problems with early burn outs, but that has been addressed on the latest version that's been out for about 18 months too 2 years now, have not seen one post on this version having any problems.
ORIGINAL: gooseF22
I do like it when a motor allows you to convert it yourself. I have seen a few times when issues with the kero start required a conversion back to propane. I have seen some guys able to do it in the field.
#1052
ORIGINAL: BaldEagel
Also consider the JetMunt Merlin 90 the Merlin is 90mm wide, I have one in a Sprint and its an excellent internal start Kero turbine, service from Gaspar is exemplorary, but its a small but, but a but it is, the EGC and sensor cables are permenatly attached to the turbine, this prevents any quick change to another airframe you may wish to do, I do not know if the Rabbit and Wren are the same, perhaps gooseF22 will confirm.
Mike
Mike
IF you were to want to swap frequently, add extensions, or mount ecu closer to turbine... that would go for any turbine with permanent wires. have done both..
So...Larry, confused enough?... welcome to turbines... The point is to pick something you will enjoy.. remember its a hobby.. have fun and fly.!! see you out there... Its alot of fun to get a gang of turbine guys together and fly, cuss, yell, talk crap, and fly some more and each other thinks they have the best stuff... "definition of a hobby".
#1055
WI
I have a Navy Nano coming but was wondering if the blue on the wing botoms can come off? is there grey underneath or wood?
I just wanna change it up a bit from others at our field. what about the blue pinstripe on the top too?
Ryan
Ryan
#1056
ORIGINAL: BaldEagel
Merry Christmas and a Happy New Year to all.
What say we start the New Year by being a little bit more tolerant with each other.
Mike
Mike
its a hobby..
#1057
ORIGINAL: iflyjets
Ryan
Ryan
dont know about the bottom. Its easier to lay new monokote over what you want. Use Rapidtac lubricant.. the new will lay right over the old. then when dry, just lightly iron it. the rapidtack will take out the bubbles by allowing you to squeegie it out.
done it alot on other planes to spice up an arf..
Blue isn't a bad color on the bottom.. it will always be dark anyway.. the hardest part of the Nano to see is when its just rounding the corner and coming just nose on. You could benefit by putting a light color on leading edges on the navy bird. Im going to add white to the wing of mine. I lost it on a cloudy day for about 5 seconds last summer... was no big deal but got my attention
#1058
WI
Thanks alot Goose,
i was already thinking about chrome leading edge strips but wanted to change out the bootom blue to white stripes- kinda like an old Mustang on the bottom
Ryan
Ryan
#1059
ORIGINAL: iflyjets
Thanks alot Goose,
Ryan
Thanks alot Goose,
Ryan
#1060
Hello gentlemen!
I have a Nano on the way. It will be powered with a JC P-60SE, and as such will the Dubro tank be too small? Also does anyone have any experiene with the TamJets gear for the Nano?
Thanks!
Thanks!
#1061
1_hellover...
The 50oz dubro tank is fine for the P60Se. We have that setup in one of our display models and it gives a very safe 6 mins flight time. In the same model we have the Tamjets gear fitted and it fits and works fine.
Regards
Colin
Boomerang Jets
Regards
Colin
Boomerang Jets
#1062
Just picked up my Nano today at Motors and Rotors, I will be using a P60se, I also have the 50oz Dubro tank (1.5l)
Dave said it is slightly larger then 1.5l so will do over 6mins, I Have seen a demo model fly for 6.30 no problem, if you fit a hoper tank
You can run the main tank dry, can't wait to get it up in the air, had a few mins on a demo model couple of weeks ago.
#1063
Yep! Like Paul said, I have it in my mind that checking the 1500cc Dubro tanks showed it a good bit bigger! I'll grab one and check it again. Either way the Dubro tank and MAP/UAT give six and a half minutes of mixed flying.
Dw
Dw
#1064
Have fun, its a great little flyer.. I did shift the CG a little more forward than the book to get it to track smoother. about 1/2 inch or 12mm more forward.. It also makes it stick when you land it better. Started out with 10 inches, then 10.5, then 11 and settled on 11..
Another option on Gas is the kevlar tank that is available.. its 79 oz.. I have that and its really nice. I usually fill it most way and not use the taxi tank, so its about 70oz at takeoff. good six minutes with a couple go arounds, and a bit to spare.. but thats alot of fuel weight for the P60.. I would stick with the 50oz, and a 8 ounce hopper. I flew mine with the wren 70 on the 50oz tank at 5 minutes though, with little issues, but it didn't leave alot of margin.. the good news is on this bird... just drop the gear/flaps and chop it and land it like you do with your U Can Do or pattern bird.. its a breeze to land..
the flap has alot of drag, so watch getting slow.. I backed off the throw to about 45 degrees to get rid of the pitch change and sensitivity..
#1070
ORIGINAL: Dave Wilshere
Quality price...So not really!
Quality metal and this gear set-up uses Jet 1A (the original) gear.
Dw
Dw
#1073
Really tidy looking gear install Dave. Nicely ironed openings too - Ive got a pile of shirts here that need ironing if you can
#1075
ORIGINAL: gruntled
Gents:
I ripped the nose gear and buggered the very front of my Nano on a bad landing.
I have decided thatrather than repair, I am going to part out the Nano, and give a different airframe a go just to try something new.
So . . . I have the following parts for sale from my Navy scheme Nano. I will send pictures and details upon request. Prices include shipping within CONUS - insurance at buyers option and expense:
1) Left and right outer wing panels including ball link linkages and reflectix wing bags for each.$110 for the pair
2) Elevator with ball link linkages andreflectix bag. $60
3) Jettech fuel tank $105 SOLD
4) I have the booms with reflectix bags that include a built-in wing tube holder (and the wing tube). I am not sure if these are cost effective to ship or not as they are kinda long, but I am open to discussion on these.
5) top hatch / canopy/ cockpitwith pilot. $60
I have to inspect the retracts before I decide whether they are suitable for sale.
Gents:
