Boomerang Nano!!!
#1151
RE: Boomerang Nano!!!
i am fitting robart 520 tri gear spring air retracts to my nano. the question is do i fit the supplied control valve via a servo or do i save space and fit a jet tronic single valve??
#1152
Either work, I have a JT-M valve in mine, but do you have a spare servo for the valve? If so it's a free set up rather than buy a valve!
Dave
Dave
#1153
im also thinking the jet-tronics m valve. i dont have a spare servo or linkage, so for the sake of maybe an extra £30 i may go for the m valve.
also does anyone know if i can buy a spare ecu lead to my reciever??, or can i convert a jr lead
#1155
great!, many thanks for all your help dave!, you seem to be the only person to be advising me on my build!, i would want to spend my money with you from now on!!
#1158
That sounds like fun.. Our Nano had a Super sport in it and was really fast. A bit overpowered I think...
What flight time do you get with the Wren 75?
Regards Al
Regards Al
#1160
ORIGINAL: R_Belluomini
My exact thoughts.
Bob
My exact thoughts.
Bob
ORIGINAL: toto_sal
Nano with a Wren 75 is just awesome! Perfect combo!
Ali, we were getting 5 min with the 50oz and 7 with the jet tech. but that wasn't full throttle all the time, that was cruise on back side and fast on the front, with some vertical.. I set the timer for 4.5 and then landed quickly. The 79 oz is actually almost too much fuel, so I dont fill it all the way. just close.. about 70oz and go.
#1161
My Feedback: (20)
CO
Hey guys,
Anyone know the ultracote/oracote # for the yellow that is on the sport scheme? Same scheme as Mr. Dave Wilshere's Nano is post #1084 (page 44).
I am not happy with my rudders and would like to recover them.
Thanks in advance!
R21
Thanks in advance!
R21
#1164
For what its worth "Tamiya" make an aerosol in that yellow, thought I would need to change the colour of my wheel wells, but Alan sent me a pair in Cub Yellow to use and a full set of CA hinges for nothing, just because I asked, I have thanked him before, but just in case he comes on here: Thanks again Alan, I have nearly finnished the re-cover, I will post photographs on the Sprint thread when finnished.
Mike
Mike
#1165
ORIGINAL: Dave Wilshere
Hopefully Colin or Alan could chip in. I think it's also Cub yellow?
Dw
Dw
#1167
I had been told in the past that the covering used was profilm/oracover and I have used cub yellow profilm with a perfect match and also when I recovered my Intro I used white profilm to match the existing white and again it matched perfect.
#1170
I have a Wren 70 with the 50 oz tank, 8min timer including taxi, not much fuel to spare ! but have not deadsticked yet ! nice combo and the best service out there from Ron Wren USA
#1171
here are some pictures of my nano navy build. its now coming towards the end and is the first jet that i have actually built!. running a jetcat p60 turbine, robart spring air retracts with wire legs,
i am just waiting for my jet-tronics valve and dubro 50oz fuel tank to arrive from motors and rotors. then all that is left to go is the reciever and some gas fittings. i have an onboard gas tank set at an angle inder the board. also going to fit a air pressure guage for the retracts.
#1174
Your welcome.. Can I ask?
Is the wood coated in thinned resin? If so, does it come out smooth enough to paint on top of ( Without any prep work? ) I have a couple of builds lined up in the next week or so and was wondering if I should give this a try for a rather large radio tray that I have to do. My worry was that while it may look good in resin, I wondered if it would look not so good when a top coat goes on.
Regards Al
Regards Al
#1175
its covered in 50/50 thinned zpoxy finishing resin, pretty good finish and is sandable. would think it would need sanding over if painting for the smooth finish.
