If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Page 50 of 63 FirstFirst ... 40484950515260 ... LastLast
Results 1,226 to 1,250 of 1553
  1. #1226
    Join Date
    Dec 2003
    York, UNITED KINGDOM
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Boomerang Nano!!!
    I have fitted lighter (25g) Futaba 9071SB servos to the rudders. After adjusting the mounts to fit i probably ended up saving about 8g per side so maybe not worth it. I usually use 3mm or 4-40 rods but I'm going to use 2-56 here to save weight too.
    I think a light elevator servo might be a good option. I'm going to use Savox 1251MG which is 15g lighter than an 8411. Again, not a massive saving though.
    If your model is ok with the weight I'd probably just leave it as it is.
    www.ukjetshop.com
    www.facebook.com/UKJetShop
    UK Dealer for Bavarian Demon, Emcotec, uniLIGHT and SWB servo arms. Reseller of Ashlock connectors.
  2. #1227
    Join Date
    Apr 2004
    billingshurstsussex, UNITED KINGDOM
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Thanks guys,
    Funnily enough i happen to have a savox 1251 on the bench that was destined for my electra. That could be borrowed until its later required.
    I know what you mean about the lighter rudder servos- i could potentially save 37grams, and reduce the need for double that weight in the front- Is it really worth £45 just for that??
    Again the UAT, i know what you mean, Im using a jetronic clunk which is like a mini UAT inside the main tank anyway!
  3. #1228
    Join Date
    Jun 2002
    Watford, UNITED KINGDOM
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Frank
    Leave it as it is, enjoy it and I'm guessing you will not notice the weight, if you could shift 300grams of drag, then it would be worth it, but that aeroplane/wing area you are just wasting good building/flying time!
    Dave
    Motors & Rotors. JetCat, Powerbox, Intairco, Behotec, CARF-models Rep. JR Propo for ever!, Jet 1A, MAP, Airtech Germany, Jet Tronics.
  4. #1229
    Join Date
    Aug 2007
    christchurch, NEW ZEALAND
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    if you mount your UAT (50 oz dubro) towards the front of the board, this plane does not require any ballast (with wren 70 and x2 5 cell in front of main tank, standard servos for rudders and elevator ecu lipo on top of the main kero tank)
  5. #1230
    rcpete347's Avatar
    Join Date
    Jan 2002
    Bolton, ON, CANADA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    HI Guys, would Robart 520RS retracts work for the nanno, or are they too large.
    Thanks Rcpete
    Wear your sun protection
    Anyday is a great day above ground
  6. #1231
    rcpete347's Avatar
    Join Date
    Jan 2002
    Bolton, ON, CANADA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    HI Guys, also, my clear canopy, is not very clear, really bad, are they all cloudy.
    Rcpete
    Attached Thumbnails Attached Thumbnails Click image for larger version.
ID:	1576736   Click image for larger version.
ID:	1576737   Click image for larger version.
  7. #1232
    Join Date
    Apr 2004
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I think youre right guys- no point spending money to move weight around, or adding complexity such as a UAT that i dont need, or wasting valuable building time. I think Ill leave it as it is.
    All the best
    ( Except for I am going to fit a larger tank- 7 minutes isnt long enough on a 1 litre tank)
  8. #1233
    Join Date
    Jun 2002
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Frank
    Use a 40oz Dubro at 1200cc
    Dave
  9. #1234
    Join Date
    Feb 2008
    Brighton, CO
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: rcpete347
    Rcpete
    Hey Pete,
    The canpoy on my Nano as well as my buddies are both horribly hazy/cloudy.
    At some point, perhaps next winter, I will probably re-cover or glass/paint my Nano at which point I will put a different canopy on it.
    J.P.
  10. #1235
    Join Date
    Aug 2007
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    my nano canopy is really clear, in contrast I have 2 xl canopy's that are cloudy.
    my UAT is a 50 oz dubro, about 5 bucks worth from memory.
  11. #1236
    Xairflyer's Avatar
    Join Date
    Dec 2002
    Co. Donegal, IRELAND
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Might be a stupid suggestion but have you removed any protect film?
    You could also try polishing it, with 1600-2000 wet and dry paper
    www.letterkennymodelflyingclub.com
    www.jmaireland.com
  12. #1237
    Gordon W's Avatar
    Join Date
    Mar 2004
    UK
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: Race21
    J.P.
    I've been thinking about a new canopy shape too. The current shape does the plane no justice.
    Gordon
  13. #1238
    Join Date
    Feb 2008
    Brighton, CO
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I like your idea/drawing Gordon.
    I agree that the stock canopy leaves a bit to be desired, but it's an ARF and I am certainly happy with my little Nano. The LHS near me has a great selection of canopies. I am sure that I will find something to fit it.
    I want to fly the heck out of it this season and save the modeling and reworking for next winter. I have R/C cabin fever now! When I do go through it I am going to keep it true to its roots but try to make it look a bit more military.
    Anyone have any pics of any redone Nano's?
    J.P.
  14. #1239
    BaldEagel's Avatar
    Join Date
    Oct 2005
    Kent, UNITED KINGDOM
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Post 1206 on page 49 shows a re-profiled Sprint canopy, wich may give you an idea.
    Mike
    My Gast is Flabered.
    No matter what anyone say's 100% is the maximum you can get.
    If you see a deleted post, my Avatar say's it all.
  15. #1240
    Springbok Flyer's Avatar
    Join Date
    Jun 2006
    Gold Coast, Queensland, AUSTRALIA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Hi guys,
    I would like to share an experience that is both an admittion of negligence on my part and also a testiment to the Nano's sound structure.
    From time to time I visit friends in South Africa and decided last year to ask one of them to put a Nano together for me (at my expense) so that I have something to fly when I get over there. He did and I must say the little Navy scheme realy looks good. Fitted with Pro-Links and a standard Wren 54, all was ready to fly. We put it together at RMAC (one of the best fields I have had the honour of flying at) outside Johannesburg - at 5500 feet alitude.
    Manage to have three successful 10 minute flights before heading home - only to find, NO WING TUBE was installed when we put it together, only the four locating pins.
    Wow, sometimes one need a bit of luck and a well engineered model (flown smoothly).
    Thought you might enjoy that (at my expense).
    Cheers
    Jan
    It is always pilot error.
  16. #1241
    gooseF22's Avatar
    Join Date
    Aug 2006
    Fort Wayne, IN
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I moved the CG back from 11 to 10.5 last week. I had to cut down some throw on the elevator, but overall easier to land.. flared sweet!!
    Last year it felt touchy... when I rebuilt the booms it actually flew more solid. I still think it needs stiffer booms, but oh well...
    weather has been crappy here so not many flights.
    Goose
    JetiUSA Flight Team, www.Espritmodel.com www.demonaero.com MKS USA Servos
  17. #1242
    Join Date
    Jun 2002
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    We have had these 2.5ltr Nano tanks made, which are now available for longer flight times on P-60 and other 54 size turbines. In stock now at M&R or Boomerang Jets UK.
    The tests are showing 8 1/2-9 minute flights on a P-60
    Dw
    We can even offer a smoke version!!
  18. #1243
    Join Date
    Dec 2003
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Dave,
    The boomerang jets website has this tank as 2.7 litre. I asked Colin about the possibility of a smoke variant and that extra 0.2 litres could be quite critical! Do you know the fuel/smoke split (and price) of the smoke variant?
    www.ukjetshop.com
  19. #1244
    Join Date
    Jul 2004
    England, , UNITED KINGDOM
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: siclick33
    Dave,
    Smoke makes a real mess on boomers too much for it to hit at the back end
  20. #1245
    Join Date
    Jun 2002
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Darren
    I'll inform him if he does not pick this up. We reduced the height fractionally to give strap clearance. Not done a smoke version yet, I'll work out materials and time addition. Our thought was 1.6ltr and 0.9 ltr.
    I am with Dennis (rare day) as smoke does make such a mess!
    The mould and design may allow a tiny bit more of either.
    Dave
  21. #1246
    Join Date
    Dec 2003
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    That makes sense. Don't worry about a smoke tank quote for me then. I'll probably save the smoke for another model and go with the extra fuel instead. I'm running out of room for the pump anyway!!
    www.ukjetshop.com
  22. #1247
    Join Date
    Jul 2004
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    That tank does look nice and fits a treat............. Is there some way you could incorporate a clear bit so you can see the fuel level or is it possible to see through it enough
    Dennis
  23. #1248
    Join Date
    Jun 2002
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Dennis
    You can see through...but with the top on the fuselage you can't
    With a P-60 type turbine set a timer at 8 mins and then see how much fuel you have left...
    Dave
  24. #1249
    gooseF22's Avatar
    Join Date
    Aug 2006
    Fort Wayne, IN
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    If you point the smoke nozzle slightly downward so that it doesn't hit the tail (no motor runnning), and you pinch the edge of the pipe so it atomizes well, the mess is minimal. I love smoke, I miss it. Im thinking about going back to the elan after this season..
    I love smoke.
    Goose
  25. #1250
    gooseF22's Avatar
    Join Date
    Aug 2006
    Fort Wayne, IN
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I have the big tank too. It flies 8 min with several go arounds. In fact, I dont usually fill it all the way, since all my planes have 6 min timers. you can easily see the fuel
    Goose
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
