Boomerang Nano!!!
Reply
Old 04-18-2011, 05:17 PM
  #1251
Xairflyer
Xairflyer's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Boomerang Nano!!!
I have a 50oz (1.4L) dubro in my P60 Intro and timer on 6mins, took off on Sunday and forgot to re-fill the tank flamed out after 3mins so 50oz is 9mins to dry so a 2.5L tank should easily give 10mins unless you are flying it flat out all the time.
Xairflyer is offline
Old 05-06-2011, 07:46 PM
  #1252
Veritech
Veritech's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
What do you guys think about putting a Jet Central Rabbit in the Nano? I am at the point with mine that I need to decide what turbine I want to get. I would de-tune it to around 10-12#'s of course and this is NOT my first turbine. Just looking at the Rabbit since it would be useful in other larger airframes in the future since it can go up to 20# of thrust.
Per the Jet Central Website:
Super Bee II
Diameter: 3.15 inches
Weight: 2.2 pounds
Length: 9.1 in
Rabbit
Diameter: 3.58 inches
Weight: 2 pounds ?
Length: 9.6 inches
-Randy
Veritech is offline
Old 05-06-2011, 10:34 PM
  #1253
bigplumbs
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: Veritech
Super Bee II
Weight: 2.2 pounds
Length: 9.1 in
Rabbit
Weight: 2 pounds ?
Length: 9.6 inches
-Randy
It would fit but more weight of course
Dennis
bigplumbs is offline
Old 05-07-2011, 04:04 AM
  #1254
Xairflyer
Xairflyer's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Better off buying the sprint if you want to fit a bigger turbine.
Old 05-07-2011, 04:28 AM
  #1255
hooker53
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Yep the sprint would be better for that Rabbit. I would like to have a Nano for my 44 though.
hooker53 is offline
Old 05-07-2011, 05:52 PM
  #1256
gooseF22
gooseF22's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I had to grind the mounts on the wren 70, so Im not sure it would fit. the nano can handle the motor just fine. set it up by putting stuff forward as possible. Mine has alot of thrust, and could handle a few more pounds. I was thinking about swapping in a Wren 100 for my wren 70...
I plan to seal the gaps this week with servo tape, to lower chances of flutter. guys have super sports in them with 17-18 lb already. Im running 15lb. Its actually a blast with the extra thrust.. plenty of wing.
Nothing like accelerating going straight up after heavy weight takeoff!!!!..
gooseF22 is offline
Old 05-07-2011, 06:39 PM
  #1257
Veritech
Veritech's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks Guys. I am going to decide on either the Rabbit or the Bee II in a week or so. I downloaded a full size Dimensional Drawing of the Rabbit and it cut it out and placed it in the fuze. It looks like it would take just a little grinding on the mounts and former at the front to get it to fit. Now I wonder about fuel, I was planing on fitting a 64 Oz juice bottle plus a UAT. I am hoping to get 8 minutes if I detune it to 12-14#'s.
Veritech is offline
Old 05-07-2011, 06:51 PM
  #1258
gooseF22
gooseF22's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
you wont get 12-14 unless you use the Jet tech 79. but you will get maybe 10.
gooseF22 is offline
Old 05-08-2011, 01:21 AM
  #1259
Dave Wilshere
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
He was talking lbs!
Dave Wilshere is online now
Old 05-08-2011, 10:40 AM
  #1260
Wap4life
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hey guys just a quick question.  The Nano is my first jet and it went together pretty smooth.  I notice that no one has a powerbox or etc just receiver, am i see correctly.  I have a 14mz and have the receiver w/ the radio and everything just standard hook up.  I looking for a used turbine for it and it will be ready for it's maiden!
Wap4life is offline
Old 05-08-2011, 12:33 PM
  #1261
bigplumbs
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: Wap4life
The Boomerang is supposed to be kept simple and most do this there is no need for a powerbox assuming you are using normal servos
Dennis
Old 05-09-2011, 11:44 AM
  #1262
Wap4life
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks Dennis, i'm actually using your set up from your build thread .  Your build thread was great help.
Wap4life is offline
Old 05-20-2011, 04:36 AM
  #1263
traxxas
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Guys,
I've just starting putting a Nano together and opted for the Dubro 50oz tank.
I'm finding that this is a very tight fit so when I have some straps or cable ties in place the canopy cannot be fitted witout really squashing things down.
Anyone else with a dubro fitted finding this?
traxxas is offline
Old 05-20-2011, 06:07 AM
  #1264
toto_sal
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I would high recommend the Jet Tech 79 oz tank from Dreamworks... Perfect fit, and no tie downs required. I have managed to hold mine down with industrial grade velcro... fits just perfect! I am running a Wren 75 on mine and I am getting 8 minutes of flight with fuel to spare for a few go arounds...
Best of luck!!!
toto_sal is offline
Old 05-20-2011, 11:40 AM
  #1265
Dave Bugz
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Mike
I put the 50 oz Dubro in mine and did not find any issues with fit, HOWEVER the canopy does need a little jigging and filing out the holes to get it to fit. Some one also suggested a small amount of vaseline on the fastereners [metal bits on canopy] and can vouch that this made slipping on and off a lot easier. I did have to remove a small amount of former from the front of the canopy where the overflow pipe comes out? but as for the actual tank fit no issues.
If you check out post 1080 pg 44 it shows DW install and mine is virtually the same [i think he copied me]
Dave Bugz is offline
Old 05-20-2011, 12:36 PM
  #1266
traxxas
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Canopy actually fits fine without the tank, its like the tank couyld do with being 2mm lower.
traxxas is offline
Old 05-20-2011, 12:56 PM
  #1267
Dave Wilshere
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Mike
No problem on 6 or 7 I know of. If it's the strap, you can trim the wooden stringers where the straps are. You have anything under the fuel tank between the mounting strips?
Dave
Old 05-20-2011, 01:45 PM
  #1268
traxxas
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Nothing under the tank.
Without straps fitted, the edges of the tank just touch the 'stringers' in the canopy, and as you say I can easily trim a bit off the wood. I was just curious if I have tank that was slightly oversize.
I have thought about fitting that Kevlar one I see listed on your site if its a better fit.
traxxas is offline
Old 05-22-2011, 06:31 AM
  #1269
Chris kerby
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Chris kerby is offline
Old 05-22-2011, 09:26 AM
  #1270
Chris kerby
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Sorry about the above post, i have a 2ltr round tank in my Nano with little adjustment made to the canopy, but just about fits, i am amazed at how they managed to fit the 2.5ltr kevler tank in this model,running a wren 54 mk3 in mine and get about 7 minutes run time.
will post picture later.
Chris
Old 05-22-2011, 11:37 PM
  #1271
Chris kerby
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Pictures of my 2ltr tank in my Nano, canopy fits just nice.
[img]C:\Users\Chris\Downloads\nano 2.JPG[/img]    [img]C:\Users\Chris\Downloads\nano 1.JPG[/img]  [img]C:\Users\Chris\Downloads\nano 3.JPG[/img]
Old 05-25-2011, 08:48 PM
  #1272
rcpete347
rcpete347's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Pics of my finished Nano
http://www.rcuniverse.com/market/item.cfm?itemId=749765
Rcpete
ID:	1614655   Click image for larger version
ID:	1614656   Click image for larger version
ID:	1614657   Click image for larger version
ID:	1614658   Click image for larger version
ID:	1614660   Click image for larger version
ID:	1614661   Click image for larger version
ID:	1614662   Click image for larger version
ID:	1614663   Click image for larger version
ID:	1614665   Click image for larger version
rcpete347 is offline
Old 05-25-2011, 08:53 PM
  #1273
rcpete347
rcpete347's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
More pics
Rcpete
ID:	1614667   Click image for larger version
ID:	1614668   Click image for larger version
ID:	1614669   Click image for larger version
ID:	1614670   Click image for larger version
ID:	1614672   Click image for larger version
ID:	1614673   Click image for larger version
ID:	1614674   Click image for larger version
ID:	1614675   Click image for larger version
ID:	1614677   Click image for larger version
Old 05-26-2011, 02:21 AM
  #1274
Xairflyer
Xairflyer's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Love the pilot and cockpit
Old 05-26-2011, 05:21 AM
  #1275
rcpete347
rcpete347's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
More pics
Rcpete
ID:	1614737   Click image for larger version
ID:	1614738   Click image for larger version
ID:	1614739   Click image for larger version
ID:	1614740   Click image for larger version
ID:	1614742   Click image for larger version
ID:	1614743   Click image for larger version
Reply
Display Modes
