Boomerang Nano!!!
#1277
RE: Boomerang Nano!!!
anyone had any issues with booms on the nano,not flown mine yet due to crap weather but watched a mate fly his in strong crosswinds and i swear you could see the booms flexing in flight,also heard of a few booms cracking on just a bumpy landing.had a look at mine and the balsa the booms are made of does feel very soft,as i said not flown mine yet guess time will tell.
#1278
Mick
No, eight Nano's in the PMFC club and no issues, very much doubt they flex! I have been doing negative snaps and tight square loops with mine and no issues. Yes the booms are light balsa, if they are not squeezed they will be fine. The booms are very deep in section and as if the wings are pushed up tight against the booms the "box" made with the tail bolted on will keep things tight.
Dave
Dave
#1279
Ok guys, I decided on getting the Rabbit KS for my Nano, picked it up today from Andy Low at Electrodynamics. I have it all fitted without too much fuss but now I am wondering how far back to mount the motor. I know I should mount it as far forward as possible for CG but if I do that the tail pipe does not stick out the back end and I am a little worried about heat back there being this is all balsa on the back end.
So should I slide it back so the tail pipe sticks out a little bit or should I slide it in as far forward as I can for CG and not worry about the radiant heat?
ORIGINAL: Veritech
Thanks Guys. I am going to decide on either the Rabbit or the Bee II in a week or so. I downloaded a full size Dimensional Drawing of the Rabbit and it cut it out and placed it in the fuze. It looks like it would take just a little grinding on the mounts and former at the front to get it to fit. Now I wonder about fuel, I was planing on fitting a 64 Oz juice bottle plus a UAT. I am hoping to get 8 minutes if I detune it to 12-14#'s.
#1280
My Feedback: (251)
HI, I have a p-60 in my Nano, every thing, including the turbine is as far forward as possible, batteries in the forward compartment. No lead was used to balance, just made it.
Your Rabbit is 5 1/4 Oz's. heavier than the P-60, That's ugly, maybe a lb. of lead in the nose. But you do need a larger battery for kero start, that will be a tight fit.
Should have bought a Sprint.
Rcpete
Rcpete
#1281
Thanks RCPete, yeah I know the Rabbit is a bit heavy for the Nano but I bought that before the Rabbit and had a hard time just getting a Bee II since the Rabbit was only a little more money and gives 5 more pounds of thrust so I can use it in other airframes after I tire of the Nano.
Speaking of batteries, this Rabbit came new from Jet Central as a KS engine and with a 3 cell A123 so unfortunately the batteries are kind of light to begin with.
Guess I will mount it as far forward as I can and just add an additional coat of BVM Heat shield to the back end.
-Randy
-Randy
#1284
ORIGINAL: Veritech
ORIGINAL: Veritech
I have a wren 70 mounted as far forward as possible(the starter nearly touches the dubro tank) my uat(made from a small glow tank) is about 250 ml, this is towards the front of the component board, this set up requires no ballast to ballance the plane perfectly.
#1285
ORIGINAL: traxxas
Nothing under the tank.
Without straps fitted, the edges of the tank just touch the 'stringers' in the canopy, and as you say I can easily trim a bit off the wood. I was just curious if I have tank that was slightly oversize.
I have thought about fitting that Kevlar one I see listed on your site if its a better fit.
Looking at the photo, maybe the top has a slight dip there, my Nano has the same tank at the moment and it fits fine. The Kevlar tank does fit well, it's designed around the whole space. With the 50oz Dubro and mixed flying on a P-60 we get 6-6.30 mins, on the Kevlar 8-9minutes of mad and 10 plus mixed
Dave
#1286
Thanks cavandish. I ended up mounting the Rabbit as far forward as I thought practical and the starter is about 1/4" from the rear fuel tank former. I also moved everything I could forward and only had to add about 3 oz of lead under the nose gear to balance. I maidened it yesterday and after 2 successful flights I think it is slightly nose heavy so the additional weight might come out before it's next flight
There also didnt seem to be any heat issues, the canopy was just slightly warm after the flights.
Thanks to everyone who contributed to this thread, my Nano came out great and is a blast to fly. I will post some pictures as soon as I get a chance to take some.
-Randy
[/quote]
[/quote]
-Randy
[/quote]
[/quote]
#1287
Are you guys that are fitting the Dreamworks Pro-Link struts set managing to get the nose retract to lock in the up position when bolted on to the existing mount? Or are you raising the retract with packing?
#1288
Just doing the final assembly of my nano, a few things to check like the CofG and set the throws. However, I've noticed that the Carbon Wing Spar is very loose and its actually 0.4mm smaller in diameter than the tube in the wing sections.
Anyone else had this issue?
I was wondering if I have an undersize carbon spar, however its seems to be exactly 3/4 inch diameter, so the tube inserted in the wing had too large Inside diameter?
#1289
Lots of things you can do to improve the fit, spray the tube with a two pack paint if its way out or just a normal rattle can paint if its only a little bit undersize, or even wrap the tube in tape or heat shrink, all will work.
Mike
Mike
#1290
#1293
ORIGINAL: Veritech
ORIGINAL: Veritech
#1294
Haha, thanks Goose but a little late, I have been flying it for the past month. Even got 8 flights on it at Winamac
Also I didn't have to add weight, have the UAT and batteries all the way forward and CG came out ok.
You going to Kentucky Jets? If so I will be down there with Andy on Wednesday evening, I will have it in the Electrodynamics booth which I think is in one of the big tents this year.
-Randy
-Randy
#1295
Anybody in the UK got a spare silver (if possible) Nano servo cover or know where i can get one. I need the one for the elevator (when looking at the cover with the servo pushrod opening facing away from you the fairing in on the right hand side.
ORIGINAL: kwb
http://www.rcworld.co.uk/acatalog/Ge...cessories.html
#1298
ORIGINAL: traxxas
#1299
ORIGINAL: BaldEagel
Are the Nano covers the same size as those on the Sprint, if so I think I have some in the workshop somewhere, let me know.
Mike
Mike
call patricia for spares if in US. in UK, I would assume call BJets..
#1300
We put a bunch of flights on the Wren 70 Nano this weekend. I have Todds gear. I need a stronger servo in the nose gear thats for sure.. I am flying the aircraft with a little more nose weight than it calls for in the book. my CG is about 1/4 inch in front of the book. I added a couple ounces to get there. I did that because it sticks when it hits alot better. the nose gear is soft, and it can be short field landed and no bouncy.. and it gets pitch sensitive otherwise...
I can pull some nose weight out simply by using a lighter turbine battery, I have a couple to choose from.. but I like the way it flies a little nose heavy...
the exact opposite from the Elan.. funny.. I liked it a little AFt, so it would wheelie..
