Boomerang Nano!!!
Reply
Old 02-20-2012, 06:42 AM
  #1351
kev-o
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Boomerang Nano!!!
Dave's supplement works great I'm almost done my install just getting some adapters made for my main struts with brakes then I'll post some pics.
kev-o is offline
Old 02-20-2012, 04:45 PM
  #1352
raptor30se
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Question on servos, are the JR DS821 suitable all the way around or should I put some higher torque servos on elevator and flap? What about nose gear steering do I need a metal gear on that one? I plane on keeping it fixed gear for at least awhile.
David
raptor30se is offline
Old 02-20-2012, 06:00 PM
  #1353
kev-o
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
821s are fine everywhere if ya like maybe a beefier on stab and flap but not that big a deal.
Enjoy it
kev-o is offline
Old 02-21-2012, 02:28 AM
  #1354
Dave Wilshere
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
We are flying serveral on the 821 servo. OK on the single flap, as there is leverage. A servo with more precision would be better on the elevator (I have a JR 8231 on mine) but 821 would be OK again.
Nose steering...MG is good, but the Nano has little trail on the nose leg, so little feed back through the servo means plastic geared servos are OK...
Dave W
Dave Wilshere is online now
Old 02-21-2012, 05:19 AM
  #1355
raptor30se
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks for the validation on the servo's, I am planning on running either a A123 or Lipo for receiver power without regulator and going with the DS821HV versions and using Hitech HS-5685MH on the elevator and flap. The 5685 has plently of torque, not sure about resolution.
Old 02-21-2012, 06:02 PM
  #1356
kev-o
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
FYI Dave nose linkage is a slick setup once you have enough clearance thanks for the info again.......
What would we do without you
Thanks from this side of the pond.
kev-o is offline
Old 02-21-2012, 11:53 PM
  #1357
Dave Wilshere
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: raptor30se
Don't know the Hitech numbers as I'm not a fan of their servos. I know quite a few guys feel they are OK though.
The E Flight retracts have proven to be very reliable in all models we have tried them.
Dw
Old 02-22-2012, 02:53 AM
  #1358
Xairflyer
Xairflyer's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Just make sure that the wheels are totally free when retracted or they will just sit there
Xairflyer is offline
Old 02-25-2012, 05:25 PM
  #1359
raptor30se
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Are most of you drilling a wicking hole for the CA hinges and cutting back the covering surround the hinges?
Old 02-25-2012, 11:25 PM
  #1360
LittleBob
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
No not necessary. Thin Cyno with a long thin applicator will do the trick
LittleBob is offline
Old 02-26-2012, 05:10 AM
  #1361
hooker53
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I always cut back the covering a small bit and drill a wicking hole. I also use the small noodle thread tubes on my CA bottle to pin point the glue. I'v never had one of the CA hinges to come loose.
hooker53 is offline
Old 03-19-2012, 03:17 PM
  #1362
hooker53
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hey Guys. Any of you have any Prolink Nano Struts you are not thinking to much of out there right now? PM me if you have some you would shed. Thanks Roy
hooker53 is offline
Old 03-27-2012, 04:44 PM
  #1363
raptor30se
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
For those running stock fixed gear are you replacing the front with a longer length to get the wing at lest level? Mine too low without a longer front wire strut. Gonna have to make one abit longer to get the nose up I guess.
David
Old 03-27-2012, 04:49 PM
  #1364
hooker53
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
David. YesI Act put the front nose strut off my shock jet with the brake on it to bring the nose up a bit.
hooker53 is offline
Old 04-15-2012, 08:00 AM
  #1365
kev-o
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
one nano ready to roll finally eflite retracts, pst600 powered and jr 12x guided
Kevin
kev-o is offline
Old 04-15-2012, 09:20 AM
  #1366
TimWatson
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: kev-o
one nano ready to roll finally elite retracts, pst600 powered and jr 12x guided
Kevin
What is the thing on the starboard wing tip ?
TimWatson is offline
Old 04-15-2012, 11:11 AM
  #1367
hooker53
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: TimWatson
Quote:
ORIGINAL: kev-o
Kevin
it's a incidence meter on that wing tip. Looking good Kev. Gets us Nano lovers some good footage of that maiden and good luck.
hooker53 is offline
Old 04-16-2012, 10:31 AM
  #1368
raptor30se
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Do you think I am going to have heat issues with the short exhaust on the VT80 turbine?
ID:	1751170   Click image for larger version
ID:	1751171   Click image for larger version
ID:	1751172   Click image for larger version
ID:	1751173   Click image for larger version
ID:	1751175   Click image for larger version
ID:	1751176   Click image for larger version
Old 04-16-2012, 10:43 AM
  #1369
siclick33
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Has anyone else tried flick rolls with theirs? Also, what is your elevator feel like?
I'm wondering if mine is nose heavy. The elevator is quite soft, even with quite a bit of movement on it (and not much expo). Also, it is very hard to flick roll. Full pro spin in forward flight results in a tight corkscrew rather than a flick. Is this normal behaviour for the Nano?
siclick33 is offline
Old 04-16-2012, 11:45 AM
  #1370
Dave Wilshere
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Darren
Mine ties itself in knots snapping. Balance is infront of instruction position (probably somewhere on this thread) My movements are quite large though.
Dave
Old 04-16-2012, 12:12 PM
  #1371
siclick33
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks Dave,
If my measurements are correct then mine is on the recommended position so I won't move it back yet. I'll have a look and see if I can get some more control surface movement first.
Old 04-16-2012, 12:45 PM
  #1372
Dave Wilshere
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
if you email me I'll remember to get mine down and check movements tomorrow...I have enough aileron movement to need 55% expo!
Dave
Old 05-22-2012, 10:40 AM
  #1373
TryHarder
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi,
I built my Nano back in 2010 (theres a couple of pictures on pages 31/34 of this thread) I have never flown it, always too busy with work or family, so its been an ornament, I have run it a couple of times but thats all, seems a bit of a waste but I'm never going to get around to it, in fact its been a while since I flew anything.
Anyway getting to the point I just wondered if there was anyone on here that might be interested in it or knows anyone at a club etc thats looking for one. I'd like it to go to someone who's going to fly it or use it for parts in thier own project, just thought I'd ask in this thread first instead of just generally advertising it.
I'm in the UK.
Thanks.
TryHarder is offline
Old 05-28-2012, 08:48 AM
  #1374
GIOMBO
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
hi guys.................jesterday I've maiden my nano with P60, when I apply full trust the model pull up the nose......... how I can change this problem?
GIOMBO is offline
Old 05-28-2012, 05:33 PM
  #1375
kev-o
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Check elev incidence to wing and or shim front of turbine up a smidge.
kev-o is offline
Reply
Display Modes
