THE GENERAL'S Fei Bao 1/7th F-15 Build,Test Results, and Video
#251
RE: Fei-Bao 1/7th F-15 Build
ORIGINAL: rbean2
Who is the dealer for FeiBao now?
I have a new Fei Bao 1/7 F15 -Israeli Camo scheme- that I just received 2-3 weeks ago. Just waiting on some minor build material to get to me so I can begin build. Even if Mike's QC team misses something, he is usually hard at work getting it for you the next day.
Cant say enough. Regardless, happy buying and flying.
Cheers
Shaz
#253
MD
ORIGINAL: sskianpour
RBean2, Mike Lin owner of Global Jet Club is US contact for Fei Bao and also does a GREAT job of helping buyers communicate with Fei Bao should you need parts or have a concern. Mike is hands-on, friendly, and very competent and has a great support staff in Anaheim, California AND in China that oversee QC and give the plane a full look-over in their GJC China factory before shipping to clients. They also provide you with a discount to get the ARF-PRO so you actually save money buying more...I know that sounds weird, but its true.
Cheers
Shaz
ORIGINAL: rbean2
Cheers
Shaz
#257
FL
Just got mine today!!!
I am so excited for this jet. I got the USA aggressor scheme and it is awesome !
Any pointers are a huge help, I will be checking in as much as possible!
#261
FL
What valorous be a good gear valve / sequencer to get my gear down then bay doors close actn?
The 15 has 3 separate doors for mains and I think I want to have the 2 doors close after the gear drops.
Any feed back?
Mike
Any feed back?
Mike
#262
michaelsarysz,
you can install 3 double action Jet tronics valves and 1 Jet tronics sequencer to make this setup work, or you can use the mechanical UP valves (UP3 and UP2 or UP4 i am not quite sure) which will also give same result.
Hope this helps,
Hope this helps,
#263
FL
Thanks extra!
I went with the up 3 valve! Dors and gear work great!
Are you a single set up or twin?
If single set up, did you have to cut the intake cowling to fit the turbine? I have the mammoth and with the pipe from tam it is a bit far forward and hitting where the intake meets and goes into a single tube to ram air at the turbine. The starter is what hits.
We were thinking of cutting a hole in it so the starter motor can go forth about 1.5 - 2 inches. This should put it where it needs to sit.
Any pics from anyone who had this problem?
Thanks guys,
Mike
Thanks guys,
Mike
#265
Some more video of mine after it's winter repaint. Sorry you will have to plough through the T Bird first.
m
http://youtu.be/WNIJgOrgFZ8
m
#267
Hello Michael,
Here are my numbers... I've haven't changed a thing in going on 4 years. I also set my friend's Fly Eagle F-15 the same way...Flew just like mine.
Aileron-1 3/8 up and down
Elevator-2 inches up and down
Rudder1 1/4 left and right
Flap-takeoff-12 degrees
Landing-20 degrees
CG 235 mm from leading edge (at the root)
Good luckon themaiden.
Lewis
Landing-20 degrees
Lewis
#268
ORIGINAL: mick15
Here you are then some pichers!
Before and after the repaint.
m
m
Hey Mick thats looking good, some close ups of the real one I took last year
USAF Lakenheath 06.05.2011 by lauriehughes, on Flickr
This ones got your behind, me like a big kid in the candy store
Um i want one - having a grand day out by lauriehughes, on Flickr
lozza
#271
I maidened my Japanese coloured F15E, at Wroughton, yesterday. CG set at 240mm behind the leading edge, it is powered by two P120 engines and I was carrying fuel in the saddle tanks only (6lts). The model weighed in at 24.5kgs dry so is going through the mandatory large model scheme. It flew very easily and required no trimming. Landing was also very easy. The only problem was I could not retract the undercarriage. It works fine static. Has anyone had success with the twist and turn undercarriage using air? 2nd flight the nose wheel came off after lift off but I managed to land her without damage.
John
John
#272
johnls,
Congratulations on your maiden!! Is your kit the Feibao or Fly Eagle F-15E? If it's the FB, are you using the upgraded main retracts and nose oleo?
Would love to see photos of your setup with 2 P-120s, this is exactly how i intend to build mine.
I might also be looking at converting my air retracts to electric including gear Doors, airbrake and canopy actuators...
Regards,
Regards,
#273
It's FB. My U/C is the upgraded, with an aluminum shoulder to give more support to the mains. I also added a ply support, as recommended else where by Mick Burrell. I have used the standard exhausts and added bell mouths, and have not used the bypass because of the difficulty in getting it to fit. The nose is detachable and I am using S-bus with powerbox SRS.
John
John
#275
My Feedback: (37)
I am about to maiden my f-15 e from flyeagle next month , I have 2 jetcat p-140 Rx , I have the upgrade main and nose rectract , I just test the turbine inside the plane and averything going well so far , guys I was reading something about static discharge , I am using tigon 3/16 for fuel hose but I was thinking to change them for antic static black hose , do I really need to make this change ? Any recommendation about to change my fuel hose setup wel be a good help thank you guys
Best regard
Best regard
