THE GENERAL'S Fei Bao 1/7th F-15 Build,Test Results, and Video
Reply
Old 04-22-2012, 05:36 AM
  #301
Countryboy
Countryboy's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Fei-Bao 1/7th F-15 Build
Quote:
ORIGINAL: dos007
Lewis and other F-15 builders, I am just starting my Fei Bao F-15E, the kit is one of the earlier models that I bought from Wagner when he was in business. After much delay I am finally get this thing built. I just wanted to know if there are any issues I should be aware of before the maiden flight. I had heard of the UC issue so I got new main retracts and a nose strut from GJC.
I have read this thread and some others just trying to make the build a success. Recently on another thread, that was very old, someone stated a problem with the main wheels and brakes...is this something to be concerned with?
Thanks for any help you can offer.
dos007,
I was there for the maiden of Lewis's F-15 and saw some of his subsequent flights. The initial problems that I remember that Lewis encountered were the retracts not wanting to rotate. I think he resolved to having a non rotating gear, and still flies it that way to this day. Second, was that he had a wheel bearing sieze up. The bearings in the earlier versions were simply not up to the task for the weight. Lastly, after several flights, I recall he had an H-stab pivot mechanism work loose. Seems the bolts were not loctited. These are the only problems that I recall, and I'm sure Lewis will eventually chime in and correct me if I missed something. I also believe that Lewis used 8711 servos on the H-stabs and 8611A on all other surfaces.
Countryboy is offline
Old 04-22-2012, 06:13 AM
  #302
dos007
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I orderd the e-rams this morning and will use those on the canopy and speed brake.
Does anyone have pictures of their rudder servo install? Is a JR 9411 enough on the rudder?
dos007 is online now
Old 04-23-2012, 07:34 PM
  #303
jeteye
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: dos007
I am going with a single setup...AMT OLY. I hope lewis chimes in with some sugeestions. I wanted to maiden this plane at the MAB meet in two weeks.
Where did you get the electric rams?
The single setup will work just fine. I now have the Jet Central Mammoth, and it's phenomenal! I can attain vertical just after takeoff straight up (200 ounces fuel)! Iuse the Tam Pipe which is far more efficient for the Mammoth. I never use full power unless taking off, or going vertical. With the right pipe, you should be fine.
Lewis
jeteye is offline
Old 04-23-2012, 07:40 PM
  #304
jeteye
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: dos007
What servos are you guys using for the rudders. I was going with 8411's but they don't fit, at least not with out a lot of cutting.
I use the JR 3421's on the rudder. The F-15 is going on 4 years old, and no problems.
I also use non rotating gear, J & R Hobby Supply wheels and brakes, and Robart 635 retracts. I now just go out and have fun! Before leaving Feibao productsI helped them with the new gear, and it appears to be working fine.
jeteye is offline
Old 04-24-2012, 04:49 AM
  #305
dos007
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Gemeral. thanks for the feedback...I look forward to meeting you at Kentucky Jets.
  #306
kevinthoele
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Has anyone tried converting the rotating retracts to electric? Results? I have one and the retracts wont go up. Nose does but not the mains. I have already thrown away the wheels and brakes and I guess now the retracts will have to meet the same fate. Pretty much crap from a manufacturer that will not test and perfect expensive gear before selling to the public.
kevinthoele is offline
Old 04-24-2012, 05:05 AM
  #307
extra 300
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Kevin,
Is it possible for you to tell us where did you convert your retracts to electric. Please send me a PM if necesary, would not want to fall in the same trap.
extra 300 is offline
Old 04-24-2012, 05:12 AM
  #308
kevinthoele
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Extra
I am trying to find best place as mine wont retract in flight. I have a call into Down and Locked
Old 04-24-2012, 05:16 AM
  #309
extra 300
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Kevin,
I am currently studying possibility to send them over to http://www.e-retract.com/en/ for e conversion.
Regards,
Old 04-24-2012, 06:14 AM
  #310
michaelsarysz
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I have this jet and I love it. GO OVER EACH SCREW FOR THE ELE MOUNTS, WING MOUNTS AND FIN MOUNTS. I GUARANTEE YOU THEY ARE LOOSE.
ALSO WITH THE GEAR. IF YOU HAVE A NEW ROTATION GEAR, IT DOES WORK FINE, HOWEVER YOU NEED TO GO AND TIGHTEN AND POSSIBLE BLUE LOCK TIGHT THE SET SCREWS THAT HOLD ON THE AXLES.
AND ANY OF THE WHITE SCREWS. IT WILL TAKE YOU ABOUT 6 FLIGHTS BEFORE YOUR WHEEL WILL FLY OFF DURING TAKE OFF. BEEN THERE DONE THAT.
IF YOU GO AND TAKE THE AXLES OFF AND DREMEL A FLAT SPOT WHERE THE SET SCREW TIGHTNS AND LOK TIGHT IT. YOU WILL NOE LOOSE YOUR WHEELS.
OTHER THAN THAT, THE JET IS SOLID.
LOVE THIS THING
MIKE
michaelsarysz is offline
Old 04-24-2012, 06:18 AM
  #311
michaelsarysz
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
HI TEC 5421 I THINK..
RUDDER SERVOS THAT I USED ARE DEFFINATELY HITEC - 5421
Old 04-24-2012, 11:47 AM
  #312
johnls
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
A lot of truth in what has been said in the later threads. I now have 6 flights on mine. I lost the nose wheel on the second flight. I have bolts with nuts now keeping the wheels on and have changed the wheel bearings to sintered bronze after the originals disintegrated. Although my undercarriage (twist and turn) works fine on the stand, it will not budge in flight and I am presently converting to hydraulic. I am flying with the CG at 240 mm behind the leading edge and I feel it would fly better if I move it slightly forward. My wing mounting bolts have needed tightening and the stabs were aligned at different heights and needed the formers removing, and remaking with the stabs mounted correctly.
On a positive it fly's and lands fine.
John
johnls is offline
Old 04-25-2012, 07:44 AM
  #313
dos007
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
OK this is the build that just keeps on giving...but from what everyone says is that it flies great!
I have installed my elevators and after tightning the bolts I still have a little play in the surface. the pin is not quite the same width as the notch in the elevator rod. It is not much play but I am just wondering if you guys had this and did you leave it alone or is there a fix?
Also my pipe is too long so it looks like I will cut it down some and then cut the inlet ducting as well. The big old OLY takes a lot of room!
Old 04-25-2012, 05:59 PM
  #314
kevinthoele
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Got email on the Down and Locked electric mains. $400 I am going to try once more before speeding the money to convert the mains.
Old 04-25-2012, 10:02 PM
  #315
sskianpour
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: dos007
I took one look at the pipe and decided to call Tam. His pipe is VASTLY superior. With an Oly for blow, you may consider not risking your considerable investment due to a pipe failure. Tam charged me $450 and delivered a masterpiece. With a P200SX I will likely not have 4 foot flames shoot out the back as I have with other brands, but pipe malfunction was still a serious concern for me... just a thought.
Shaz
sskianpour is offline
Old 04-26-2012, 04:09 AM
  #316
michaelsarysz
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
i agree, i have the tam pipe as well.
i get serious power with my mammoth. go with the tam pipe. tell fei bao to keep theirs.
Old 05-17-2012, 12:03 AM
  #317
mick15
mick15's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Some video taken at the recent Raydon jets meet.
m
http://www.youtube.com/watch?v=dIfvzfLCNQQ
mick15 is offline
Old 05-17-2012, 01:00 AM
  #318
extra 300
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Mike,
Your F-15 looks better than ever!! I love your flying style, it brings out this jet's Majestic capabilities!!
Simply Awesome!!!
Old 05-18-2012, 12:34 AM
  #319
mick15
mick15's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks for the compliment, it's a great model to fly.
m
mick15 is offline
Old 01-05-2013, 08:35 AM
  #320
michaelsarysz
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Has anyone gone with down and lock yet?
My gear is acting up bad, I have a good amount of slop as well, in the clockwise and counter clockwise rotation of my mains.
i think its the top piece that has the ball on it, also holds the gear in the jet.
Any feed back ?
Old 01-05-2013, 09:57 AM
  #321
jeteye
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: michaelsarysz
Any feed back ?
I had to do away with the rotating system; Lock the struts in place, and go with Robart 635 retracts. Going on 5 years and still going strong. I fought the same battle with that gear for about a year. I'm lucky that I did not destroy a very good airplane!
Lewis
jeteye is offline
Old 10-29-2014, 08:30 PM
  #322
Paul Buckrell
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi Lewis
I'm considering a FB F-15E with twin P120SE. I'm curious about your problem with the rotating retracts. Do you apply mainwheel brakes when you initiate retraction to stop the gyroscopic effect of the mainwheels spinning at takeoff rpm? I found that using brakes on my Avonds F-15C cleared up the retraction issue I first experienced with that model. All worked on the ground correctly, but the struts always snagged the gear doors on retraction until I mixed brakes ON.
Regards
Paul
Paul Buckrell is offline
Old 10-30-2014, 07:00 AM
  #323
jeteye
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi Paul, Never tried that. Made the switch to Robart 635,s about mid season the first year. It's still flying great, and presently getting the Mammoth Pro upgrade.
Lewis
Quote:
Originally Posted by Paul Buckrell View Post
Hi Lewis
Regards
Paul
jeteye is offline
Old 10-30-2014, 09:05 AM
  #324
EDFJim
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Great idea , I'm going to program that with my gear also .. I know they do it on full scale
EDFJim is online now
Old 10-30-2014, 10:47 AM
  #325
FenderBean
FenderBean's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
hmmm never thought of that, going to do that on my jets as well lol
FenderBean is offline
Reply
Display Modes
