10X/Spektrum module internally routed
RE: 10X/Spektrum module internally routed
Dave and any other RF experts. Is there and reason that the connector could not be deleated by soldering. The wire appears to be sheilded and if so is it nessary.
Jerry
Jerry
ORIGINAL: Jerry Kirwan
Jerry
Jerry
That I could not answer. I just put it back together the way it came, I doubt any of the reps would tell you its ok to delete that fixture though.
Dave
My Feedback: (12)
Dave,
How did you run the wire from the 2.4 antenna thru the ball base? did you drill a hole thru the aluminum adapter that came with the 2.4 conversion? how difficult is it to remove the 90deg connector from the wire?
do you have pics inside the Ball base antenna on where you routed the wire?
Harold.
Harold.
ORIGINAL: mndbndr3d
Dave,
Harold.
Dave,
Harold.
#31
ORIGINAL: i3dm
Looks great dave !
How do you fit the module into the back of the Tx with the antenna plug sticking from the upper side of the module case?
Looks great dave !
