Jet Legend (1/8) F-16 Rookie Build
#54
My Feedback: (10)
RE: Jet Legend (1/8) F-16 Rookie Build
Ok, so to understand this correctly.
1. you install the fill checkvalve directly to the gas solenoid instead of going to the small tank
2. You then turn the propane on 1/8 turn and let the ECU start the plane.
So I assume after the start you then turn off the propane and unplug from the checkvalve. How would that work if I'm using the Dreamworks powermax can adaptor. I don't think it has a turn you can do.
#55
My Feedback: (23)
ORIGINAL: sweetpea01
ahhh.. powermax is different than a propane setup.. that i dont know about..
#57
My Feedback: (10)
Wow........its been awhile since I worked on this plane. I had several things come up.
Built a 30% PAU Su-26 ARF and broke my 3W55 in for this plane.
My TF P-47 in Captured German Scheme that took me 2 yrs to complete
Then I recovered this 37% PAU Ultimate and got it ready to fly
Finally after 3+ yrs my 35% Aerotech Edge was repaired and flown from a prior crash.
The F-16 is back on the table and I'm itching to work on it.
#65
My Feedback: (57)
I used three small hardwood plates underneath each servo mount (3 total). The hardwood plates are then glued to the servo access cover, and use three small wood screws to fasten the servo to the plates on the cover. If Yyou use the new JR thin wing servo (higher torque!!) th hardwood plates would be slightly different, but the inent is the same. Servo stays witht he access cover.
