Presto Film on Aggr II fuse
I was told that this film can be removed and the remaining tackiness left from the film can be remove with aceton - is this true? - Thanks, steve
you might have better luck removing the adhesive with Laquer thinner. then clean up with acetone. another product that works pretty good on that kine of adhesive is called goo gone. It is yellow and has the cirtrus smell. It is somewhat oily to the touch, but it really seems to work pretty well.
good luck,
Joe
good luck,
Joe
