Fei Bao / RC Jet Models Rafale Build Thread by RCISFUN
#176
RE: Fei Bao / RC Jet Models Rafale Build Thread by RCISFUN
Guys... Went to 140mm c.g. And its not so brutal on rotation anymore..
Does anyone know if the skymaster and the feibao kits are identical? I am looking to get a new pipe for it. My stock pipe looks iffy.
What should i lookout for in a pipe if its suspect?
Thanks!
#177
My Feedback: (44)
If your going to replace it I would contact Tam at Tam Jets, his pipes are first class
Do you have a photo of your pipe?
You want to check all of the spot welds (especially where the pipe splits into the y section) and make sure they are holding, also check for warping and discoloration of the metal.
#178
Thanks Rich,
Forgot to mention, i chopped 15mm off the mains and moved them 15mm also to improve the rotation.
I pulled put the pipe and just have some copper colored areas, no blue/purple areas on it so it seems fine. Some concern on the pipe exhaust as its a bit mashed at the double wall support, but seems ok. Will obaerve it. Cant really say it is warping
Thanks for this thread Rich, was really helpful ehen i was building the kit. I think the fb retracts leave alot to be desired so thats probably the next upgrade.
Regards
Rob
#180
OK
actualy the way u had the model with no doors is alot more user freindly, but once there installed (right) they work rather well just besure u get a valve that u can adjust the speed of the gear n doors movment i used a u.p.3 retract valve with automatic door control n a good Simple brake unit like jettronics, actually i bought this FEI BOA RAFALE used turbine and all but i find myself cleaning up somones mess some what lol the jet is good condition but im having to basically remeove everything and reinstall everything even though it all worked it wouldve came down n a fire ball if was continued flown like it was, especially the fuel tanks lol ive never seen anything like that! people like this guy r gonna get turbines banned, has anyone got the stock or blow molded tanks for this model because i need em n the tanks that r installed dont hold as much fuel as the stock ones n they r death traps, down right scary, most of the model looks pretty good till u look a the tanks themselves lol looks like somone dipped them n epoxy which makes me wonder *** was going on here that made them decide to do this lol, probly leaking and we all know how the turbine needs to have a extra fuel supply just dripping down its throat as its screaming at 125,000rpm lol can u say BOOOM anyones got those stock tanks or knows of somthing better give me a call plz 405-598-0132 my names Terry, Yanks
#181
OK
i wondered if u guys carryed any tanks for the rafale stock ones or maybe somthing better as in more fuel, i need the stock ones,
#183
Hi, I flight the XEJ Rafale (same shape) for 3 years and it is really excellent.!!
Here is a short inbord video of the last flights:
http://www.youtube.com/watch?v=C5ufVyVFSnM
Full of fun with yours!
Laurent
Laurent
#184
My Feedback: (13)
Guys,
Will start putting together a NIB Tamjets/Fei Bao rafale. This thread is extremely helpful.
I need to buy the seven (7) gear doors cylinders. Anyone knows the stroke length? Are they all the same stroke? Thinking of using Ultra Precision ones.
Thanks!
Thanks!
#187
My Feedback: (44)
OK here ya go...
The stock cylinders as measured from the mounting hole in the cylinder base to the hole in the ball link linkage is 3 3/4" (95.25mm) extended.
The cylinder body is 2" (50.8mm) long.
It appears that they are all the same.
I hope this helps.
I hope this helps.
#188
My Feedback: (13)
ORIGINAL: RCISFUN
OK here ya go...
The stock cylinders as measured from the mounting hole in the cylinder base to the hole in the ball link linkage is 3 3/4'' (95.25mm) extended.
The cylinder body is 2'' (50.8mm) long.
I hope this helps.
OK here ya go...
I hope this helps.
#189
My Feedback: (44)
Edgar,
The second one down in the table would be correct (5/16" x 1" cylinder) as I measured with the Ball end fitting attached, so if you add a 1/2" for that it works out to 3.73" which is very close to what I measured.
#190
My Feedback: (44)
Hobby King has these units for $4.58 ea, a bit less expensive than $25 each for the UP cylinders
http://www.hobbyking.com/hobbyking/s...ator_20mm.html
#193
if it makes a difference, i already bought all the available sizes from HK and occasionally replaced a couple of original air cylinders in a jet and they seem to work (i would dare to say) better than the originals...
regards,
regards,
#194
My Feedback: (44)
ORIGINAL: extra 300
regards,
regards,
#195
Hi,
I have just bought one of these jets and it just arrived as you mentioned the structure sure needs a bit of strengthening,is it possible to get the cad drawings ,it would be a great help.
P.s. would a 20 lbs thrust engine be enough.....
#196
Fb jets RAFALE CoG
Hi,
I am back for some serious help,I have not been able to get my RAFALE off the ground as yet it just refuses to get airborne when I checked the CoG, it is perfect when the fuel tanks are full but as the tanks get empty it shifts back a lot making the model tail heavy ..
I am at my wits end and have damaged the landing gear on two occasion trying to get airborne ,,the nose won't budge ...please let me know what I can do to set this right the CoG is at 140 with fuel tanks full
thanks
prahlad
please help if you have any suggestions
thanks
prahlad
#197
My Feedback: (13)
Prahlad,
1) Move the equipment inside and any weight you may have added so that the CG is established with the tanks empty.
2) Add an 20-30 degrees offset to the canards in the UP position (lift the nose) for takeoff. You can use the same retract swith to activate if you desire.
3) Ensure you have max travel for Elevator function of the Elevon. Use dual rate if needed to avoid havnig too much elevator for cruise flying.
4) In a previous thread or port someone wrote : Shortening the main Oleos by 20mm. This then allowed me to re-position the retracts 20mm further forward whilst still allowing the wheel to occupy the same space in the fus.(retracts go up forwards). She sits a little low on the mains now but It's a necessary compromise as rotation weight still really too heavy on the nose. At least the lift off is more scale nowS.
5) For takeoff, you can have some elevator applied as the airplane accelerates. Then you can continue to push the elevator once takeoff speed is achieved. This may help in keeping the less pressure on the nose.
Good luck,
Good luck,
#198
Hi,
that's the problem Edgar the COG is correct when the tanks are full but as they empty the CG moves back drastically,if I set the CG with the tanks empty, than with the fuel the nose will never get of the ground.
i have done the whole removing the 15 mm from the main gear and adding 15 mm to the nose ..but not able to get my head around the cg problem...
in your setup how does it work...
if I do leave the cg correct with the fuel filled then trim it as the fuel finishes will I run out of elevon and canard ????
#199
My Feedback: (13)
Not sure I completely understand your problem. The manufacturer quotes a CG location assuming this is measured with the tanks empty. You then distribute or add weight to have the plane balanced at that point. If you balance the plane with the fuel tanks full, then the number that the manufacturer quoted will not be appropriate.
You should be able to get off the ground with the CG in the manufacturer location, or aft of that (say 140mm).
I flew a Skymaster Rafale and now about to maiden my Tamjet Rafale.
Good luck.
#200
I will try what the manufacturer says, let's see how it goes but the design of the fuel tank placement is very poor as the utilisation of fuel causes a lot of shifting of weight .....not good....
thanks is for the advice.
regards
prahlad
regards
prahlad
