Tamjets Servo Mounts
I recently bought a pair of Tamjets servo mounts and the fittings on one appears to be no 2 screws and the other is 4/40 bolts.
Has anyone used these mounts? Is one version stronger than the other?
Would you be happy to mount primary control servos to them (JR 8321s on Grumania SU27 Tailerons)?
RE: Tamjets Servo Mounts
I've used a lot of the Tamjets servo mounts.
My personal opinion is that in the mounts I had, the hole for the #2s is perhaps just a bit too big for that screw to get a really good bite. Given the manufacturing tolerances, some actually seemed OK and some just seemed to thread a little too easy for my liking. they would probably have been OK, but it just made me a tad uneasy.
Since I'm anal about that kinda stuff, I threw the #2 screws away, and used button-head 4-40 cap screws in all of them. It was a trivial change to make since the cap screws just self-thread into the plastic anyway.
Gordon
Gordon
FL
I have been using them since they were first introduced by their designer, Rob Janiger of Sherman Oaks Ca.
He sold them under the "RJRC" brand name, but are now sold by Tam.
They are well engineered, and are a quality product.
My Feedback: (12)
ORIGINAL: KC36330
both my Tam A-4s used them on every flight surface, as long as you securely glue them down they work great.
ORIGINAL: ianober
Just dont epoxy them down, they WILL fail, use CA!!
My Feedback: (12)
I did scuff mine up and still lost a plane over it. Went through the wreckage and grabbed one of the other mounts and peeled it right back, the glue stayed on the plane, nothing on the mount. After that I haven't really used them anymore.
FL
If a servo mount like these comes loose in flight, it may have had a poor and improperly prepared bond.
It is difficult to bond certain dissimilar materials, so a few things should be kept in mind.
1. Choose the correct adhesive.
2. Thoroughly scuff the faying surfaces to be bonded.
3. Clean the surfaces to be bonded.
4. Avoid skin oil contamination.
5. Avoid using excessive amounts of adhesive. Excess glue is excess weight, and contributes nothing to the strength of the bond.
By drilling a pattern of #10 holes through the faying surface of the servo mount, the adhesive will flow through and act as rivets. The mount faying surface should then be scuffed with 80 grit and cleaned with alcohol or another suitable solvent prior to bonding.
Keep your fingers off the cleaned surface to avoid skin oil contamination.
Apply a film of adhesive to the faying surface of the mount, and install. Allow the adhesive to flow through the holes forming "adhesive rivets".
After the adhesive has cured, alter the "adhesive rivets" height as required to mount the servo to fit correctly.
These few steps are very simple and very easy to accomplish, and will promote an improvement in shear and peel strength of the bond.
Gordon,
Some of the mounts come with #3 screws instead of #2's. I like the the #3's myself.
Gordon,
My Feedback: (12)
TN
Ive used them on numerous planes-both turbine and props. I always prepare the bonding surfaces and wipe them with acetone. I swear by them and have never experienced any problems. If Hysol is used correctly, it wil not fail. I swear by them-
My Feedback: (12)
Mine was prepped and bonded as well, I wiped with alcohol and keyed the surface as I do with all fiberglass bonding. Could have been substandard adhesive, that's all I can figure. I have had success with them using CA, it actually melts the plastic and fuses it with the wood/plastic. But that issues coupled with the screws not fitting kind of turned me off. If the screw issue has been resolved then I might revisit them.
ORIGINAL: Harley Condra
He sold them under the ''RJRC'' brand name, but are now sold by Tam.
Simple and quick way install the servos.
ORIGINAL: ianober
If you had it peel off. I better check your mechanical way of how you install your servo linkage.
Only high stress from flutter can peel it off.
ORIGINAL: ianober
Harley, those are really good tips, thanks for listing them out like that, I'm sure it will come in handy for someone building right about now
Hi siclick
As your in the UK check out GBR jets servo docks...they are absolutely superb and Marc is great to deal with
Regards
Mark
Regards
Mark
My Feedback: (12)
ORIGINAL: tamjets
Never had one come off and use all different way to glue it.
ORIGINAL: ianober
Come on now Tam. CA worked fine, will never use them with epoxy. Have you fixed the screw hole issue? I still have 3-4 of these hanging on my wall after 4 years that I wont use cause the screws dont bite.
ORIGINAL: ianober
ORIGINAL: tamjets
ORIGINAL: ianober
What screw hole are you talking about.
It either 4-40 or # 2 screw.
Never had one screw come off or peel off.
CA or Epoxy was use.
Once again... only flutter stress can peel if off or rip of the skin. Which one come first it still end up with the crash.
What need to revise when is working fine from begining.
Remember how great products is....if someone don't do it right is still end up flutter and that cause the crash. Not because it peel off.
I hate to said this...
There still alot guys out there don't know how to install servo linkage for maximum mechaincal advantage to reduce slop play in the servo that can lead to flutter.
ORIGINAL: tamjets
that's been my experience with them as well, i use CA in the center to hold them down while the epoxy/hysol around the outer edges dries. can't even rip them off to reuse them later without destroying the mount.
