What is the cheapest yet best smoke fluid??
RE: What is the cheapest yet best smoke fluid??
anyone try this stuff? [link=http://oilstore.stores.yahoo.net/aesmoil55gal.html]smoke oil[/link]
Says it's a mineral oil....
I'm trying to work out the optimum flow rate, my pump gets through 33oz/1 litre in around 1min 20secs pumping non stop.
Rob.
Rob.
Yep, good stuff, ground tested it in my Bobcat this afternoon and the results were astounding, it may be expensive but boy does it work, producing mini cumulus clouds which floated off into the blue yonder!!
Rob.
Rob.
#34
I've got about 2 gallons of old kero-turbine oil mixed fuel that I'm not going to use this season in my engines - but I'd like to use it for free smoke oil if it will work. Some guys here have mentioned adding transmission oil to kerosene - what sort of ratio?
#36
ORIGINAL: furloughed ual
Smoke oil IS mineral oil. Call it by whatever name brand you want. Heck, burn baby oil and leave a really fresh scent in the air!
#38
ORIGINAL: Eddie P
Not even with transmission fluid mixed in there?
#39
My Feedback: (85)
Freedom Form Release from Fastenal is about $8/gallon ($41.22 for a 5 gallon pail) and smokes well.... http://www.fastenal.com/web/products...ex?sku=0207288
Kevin
Kevin
#41
My Feedback: (9)
I tried ATF mixed with JP-4 and it did smoke but it wasn't what I thought it would be.
I paid Tower Hobbies 33.00 shipped for 1 Gal. of Super Dri. and it really worked well.
it is just too expensive...
Can someone post a video here to show maybe the form release mix or others.
Are their any water mixes that may work.
