Smoke system not smoking
Old 03-01-2009, 01:31 AM
MattyC-130
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Smoke system not smoking
I have a smoke system on my Falcon 120 and it smokes fine on the ground but not in flight. I know the pump is working in flight but it seams the air/exhaust is dispersing the fluid before it ignites. I have the same smoke system on my formost and it does fine. The Formost does have a short thrust tube that may be helping. My next step is to drill a hole in the exaust tube to inject the fluid in right behind the turbine blade. Any suggestions/help?
Matty
MattyC-130 is offline
Old 03-01-2009, 01:43 AM
Randy M.
My Feedback: (38)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Smoke system not smoking
Matty,
The smoke injector tube should be a couple inches behind the exhuast nozzel.
A pic of your setup may help.
Randy M. is offline
Old 03-01-2009, 01:44 AM
KC36330
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
if it's actually pumping out a sufficient quantity of fluid you're just not injecting it into the proper part of the jet blast, too deep in and it burns the oil and produces low/no smoke, too far out and it's too cool to vaporize and low/no smoke, you need it in the outer edge of the jet blast so it completely vaporizes the fluid without burning it.
KC36330 is offline
Old 03-01-2009, 07:19 AM
CraigG
My Feedback: (40)
CraigG's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I wouldn't think the exact placement of the tubes would be critical but here's a pic of mine showing a location that definately works.
Craig
CraigG is offline
Old 03-01-2009, 08:43 AM
KC36330
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
could just be the pic but from the looks of it, the right stick is too deep into the jet blast for optimal smoke.
KC36330 is offline
Copyright 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
