Check out the speed brakes FJ
My Feedback: (85)
RE: Check out the speed brakes FJ
ORIGINAL: WhoDaMan
Check out the boards on this puppy
You would also have finer throttle control to adjust the rate of descent...
Am I correct???
Kevin
I flew the F-94C and it had 4 speed brake doors also. As stated you needed more power on final with the doors out and we always landed with full doors. If I remember correctly it took about 75% power on final with full flaps, full doors and gear down.
For go around your left hand was on the throttle, so full power and close the speed brakes simultaeneously, then reach for the gear handle and gear up if your descent was zero or climbing. Then full flap retraction.
My Feedback: (164)
CA
ORIGINAL: sidgates
My Feedback: (61)
Its a good feeling to be way up on the throttle on final. When i deploy this mess it requires 70% stick to get me in the slot on final. Most times i touch down with 25% throttle still on. You don`t need and SE motor to do a smooth go around and landings can be very predictable once the throttle starts coming back.
V..
V..
My Feedback: (164)
CA
Hi Marty:
Good question, You know I like the F-86 a lot, but I think this plane is so much prettier than the F-86, I have ask Anton and or Fly Eagle to do the plane and know one does it, There are as many color schemes for this plane as the F-86, And the wing shape is awesome
