12X RTRM question
My Feedback: (24)
12X RTRM question
OK, so I can't find it in the manual, the applications guide, or here on RCU using a search, so I'll ask here.
I'm programming a 12X and I have the nose wheel steering on Aux 7. Its mixed with rudder using a Pmix. Now I want to use the right hand eyebrow trimmer to trim the nose wheel steering (Aux 7). How do I do that?
I setup a second Pmix from RTRM-> Aux7, but no matter what values I put into the mix, moving the right eyebrow switch doesn't move the nose wheel steering. What am I doing wrong?
Any help would be appreciated...
Thanks!
Bob
Thanks!
Bob
RE: 12X RTRM question
Bob,
I did the same thing only used the left trimmer for one of my planes, I don't have the radio in front of me right now but I think I did a mix rudder to aux whatever, then assigned that switch to the aux whatever channel. I will be in my shop tomorrow and will look for sure at what I did.
DR
DR
NM
It's pretty easy... Go into Device Select and change the control of Aux7 from AUX7 KB to the Right Trimmer by scrolling until the Right Trimmer is displayed. Now you can move the steering with the trimmer and a progrm mix of Rudder to Aux 7 will drive the steering with the rudder.
Len
Len
My Feedback: (24)
Joe,
I do have the updated firmware and I had done that, but in code 83, I thought that the "Aux Trim" "Moment" setting to OFF did both trim levers - and I wasn't sure that the "Flap Trim" setting was. However, when I set the "Flap Trim" "Moment" to OFF, *that* did it for the RTRM. I guess that's probably buried in the manual somewhere, but darned if I saw it... [&:]
Thanks guys! As always, the guys on here are a fantastic source of knowledge!
Bob
Bob
You couldn't find it because the updated software is described in an addendum that is not included in the original manual. Sorry Bob. You can see it here.
http://www.jrradios.com/ProdInfo/Fil...l_Addendum.pdf
BTW for anyone who needs them, JR has compiled manuals and parts explosions for equipment here.
http://www.jrradios.com/Support/manuals.aspx
TN
do all the 12X's have this upgrade....I have two ...one 12x being one of the first batch sent out ....how do I determine if this one is capable of the trim momentary functions or is this something that was just not included or written up in the manual to begin with..
Steve
Steve
My Feedback: (24)
Steve,
Look in the manual addendum that Joe posted above. If you go to screen 83 and you see a column for the trimmers labeled "moment" then you have the new firmware that allows the trimmers to be setup as momentary switches (see the picture of screen 83 in the manual addendum).
Bob
Bob
