Fly Eagle Jet 1/7 F-15 - The Movie
My Feedback: (10)
FL
Well, it is finally posted. . .thanks to Scott at SKS Video, this video has been made possible. Note, at the point of filming, the landing gear was still an issue. This has since been solved with a totally re-engineered retract unit which functions well with just 70psi of pressure. Yes, they rotate when they go in the wells !
Enjoy, and remember, you can get your own copy of this as well as all of Florida Jets 09 from Scott at SKS.
http://www.youtube.com/watch?v=e5PT_kh3gTA
Best regards,
Eric Clapp
Best regards,
Eric Clapp
RE: Fly Eagle Jet 1/7 F-15 - The Movie
Awsome vid! I want the one with the thrust vectoring system. What Turbine was in it Eric? looked like a Rhino...
ORIGINAL: BluFox
Best regards,
Eric Clapp
Best regards,
Eric Clapp
I need working gear because the plane is actually going into the garage from the inside cause there is no way I can get even a partially assembled version out of the house.
My Feedback: (86)
Eric,
Great video and awesome plane. A very superior plane to the Fei Bao for sure. Cannot wait to get the new gear...I am sure James is happy to have this solved and he can move on to another project. Even with the gear down...this plane beats the other one hands down.
Rex
Rex
ORIGINAL: David Jackson
According to an email received from James, 4/9/09, the new gear has been mailed via postal service and should take approximately 7 days to get to everyone. I am looking forward to getting my twin assembled and test flown.
I didn't get that email.
I have to say the Israeli Camo paint scheme looks spectacular.
My Feedback: (10)
FL
In response to the questions posted:
1. jf 170 Rhino was installed. Distance from nozzle to pipe entrance 1.5 inches. this really made this turbine come alive! Video shows flight passes in various stick positions.
2. The third set of main retracts received from FEJ are of a complete new design. Gone is the bellcrank assembly which I believe is/was the cause of the system not retracting fully during rotation.
To be clear, the second set of retracts had the same mechanics but larger cylinders. Also, the nose gear as designed has worked perfectly since flight 1. We now have a total of 9 flights on this jet.
3. I have been informed by James, all customers have been shipped the latest set of retracts. If you own this jet and are not the first owner, I suggest you contact the first owner to see if they have been received.
4. We moved the balance point from 190mm to 204mm. While not flown yet, this should eliminate the longer TO, allow a slower approach to landing and eliminate the use of down elevator input while inverted.
That's the latest. Winds here (90degree) X wind are keeping us grounded this weekend.
Regards,
Eric
Regards,
Eric
My Feedback: (10)
FL
t3dm:
The factory recommended setting of 195 is too nose heavy. This is where it was set in the video. Later flights finally placed the CG @ 235 which is about as perfect as it can be. At the 195 setting, it is easy to run out of elevator and as well, the approach speed is much higher.
All F-15's fly great. . .this is the case with this one as well. 235 is the correct CG. Now, if only we has a set of landing gear we could rely on ! Matrix is the answer.
Last, the supplied main tires and wheels are at best short lived. The tire will easily spin off the wheel. Just about everything one could think of to retain the air inflated tires was in vain. This has been the case with many FEJ F-15's. My friend Andy Kane installed a pair of BVM Rafale tires, wheels and brakes which work perfectly. . .now for retracts.
Regards,
Eric
Regards,
Eric
Did you have problems with the gear on that flight? looked like you couldn't get them up then you just put them back down and left them? Love that jet though. I have always loved the F-15 done in green with all the bombs on it, just looks mean.
Someone sent me a pm and said it was old gear before they updated no reply needed. I love that color scheme
