Another Skymaster Viper
#476
RE: Another Skymaster Viper
G-DAY GUYS
You know one becomes PARANOID with all the talk about the rudder hinges,May be some one else has allready been there but I have seald the hing line with tape as with some of the big 3D planes,Also have found a spot for the smoke tank shall post some shots of both.
REGARDS
JOHN
REGARDS
JOHN
#477
John,
Ditch the tie wraps on your connections and use safety wire. The tie wraps don't apply even pressure and can even cause air leaks sometimes!
Oh, that's a handy spot for the tank - it's where I put my tank all smugly and then realised my wheels will hit it So, you gotta bend those pipes straight up like that!
#478
My Feedback: (39)
Here's a picture of where my buddy BillB put his smoke tanks underneath the intake ducts. The picture only shows the stopper end of the tanks and little of the plumbing but the general idea is there. I think they were 2 - 32 oz dubros but can't remember for sure what he told me they were.
PaulD
PaulD
#481
ORIGINAL: PaulD
PaulD
PaulD
#482
ORIGINAL: schroedm
John,
John,
Shall replace, They were from an old install, Didnt give it a thought ,Good spot for the tank, Did start with a bigger tank but it intruded into the well but this one is better.
REGARDS
JOHN
#483
My Feedback: (39)
ORIGINAL: gooseF22
PD, thats a super install!!!
ORIGINAL: PaulD
PaulD
PaulD
Thanks for the positive comments but please give credit to Bill Broderick who built the jet. [sm=thumbup.gif]
I just took the pictures of how it should be done.
I am still waiting to get my hands on my kit so I can start building.
PaulD
#484
Went to B&Q (model lighting department!!!) today and found some LED's that I think do the job. Some pics for you. I am going to play around with them today and make a box section for the lights. Paul / Bill nice idea putting the smoke tank under there, very neat!
H
H
#486
Beautiful day here, so went to maiden the Viper. Had four flights. All settings as per the manual & CG 235mm. Timer set for five minutes.
Flight one:- Lifted off gently. Tried to retract the gear, but the doors fouled the slow rising gear, so flew with the gear down. Did a few circuits with very little trim required. Tried the flaps. At both take off & full settings the jet pitched up slightly (mental note to add some down mix). Flew mostly around half throttle with some full bursts. Landed a little on the fast side just to be safe.
Flight two:- Added in 3% down elevator to take off flap & 6% to landing flap. Also set landing flap to more than 45 degrees. Filled gear tanks to 6bar pressure. Gear still would not retract properly. Landed slower & very gently.
Flight three:- Noticed a slight gap between the right wing & the fuz, but seemed secure. After take off I went inverted & retracted the gear. One main & the nose went up, the other main fouled with the door. Slowed up more this time for a shorter landing. I checked the wing/fuz gap & it had not opened any further.
Flight four:- Set landing flap for as much as possible, almost like airbrakes. Filled the gear airtanks to 8bar pressure. Took off & retracted the gear inverted. This time all three went up & the doors closed. The jet flys so much better with the gear up. Rolls are very axial. Slowed the jet up even more for landing & with the full flap, it landed at jogging pace.
After landing I noticed the right wing/fuz gap had increased to over eighth of an inch. I stopped flying for the day. When I arrived home, I cut an access into the wing root, just above the wing retaining plate. There was virtually no glue securing the flat plate to the wing. You could see the dimples on the plate where the glue was supposed to be. I consider myself very lucky not to have lost my Viper due to this quality control issue. I have fitted ply supports & hysol. Although the other wing seemed ok, I opened it up & found there was plenty of glue in place. I added some hysol just in case.
I must say the Skymaster Viper is a lovely jet to fly. It just needs Skymaster to fix the quality control issues to make it perfect.
Regards
Jim
Regards
Jim
#487
Also enjoyingnice weather in the northeast U.S.... so taking advantage of it and flying my Viper as well. I have 10 flights on it to date. I have a few smalll issues but nothing major or that would keep me from flying it.
First flight the plane was very tail heavy... had balanced it on the aft CG mark.... rebalanced to the forward CG and all was good. I have been removing weight a little at a time until the jet flys the way I want it to.
Flaps.... I too had thought about adding more down flap. Mine are set at 40 degrees. It's just the sound of the servos at 40 that have stopped me from going further. A longer horn on the flap would have been nicer I'm guessing. But I'll try going to 45 plus.
Aileron deflection.... I set my throw to manual specs..... It's fine for flying arround.... but not too good for multipul vertical rolls. Any body out there have a higher setting for throwing the Viper around a bit that seem to work well?
The last thing that is still bugging me is my gear. about 50% of the time when I turn ON, the gear doors open...the gear retracts, then extends and the doors close. Doesnt always happen. If I plug a servo into the RX where the sequesncer is plugged... it blips when you turn ON... tried another RX...same. Thought it may be a voltage issue with fresh charge.... seems not to be. Maybe reducing the ATV (end pionts) Who knows. Its not a binding issue. Anyway... I simply hold the nose up when I turn on and let it do it's thing. kind of silly for a 10k jet!
This is my first jet and I'm still really liking this thing!
Thanks for any input.
#488
Matt. If you are using 2.4, it could be a failsafe setting issue. Try binding again, making sure the gear switch is in the down position. Other than that, not sure what the problem would be.
#489
My Feedback: (10)
ORIGINAL: Matt Chapman
do you have the up and down valve reversed? (airlines and programming)
a jettronic has a backup failsafe
or like our flying scottmans says maybe you need to rebind?
#490
ORIGINAL: Jascat100
Regards
Jim
Regards
Jim
Idid not trust the LITTLE TAB to hold the wing on so added a bolt in to the wing about 70mm in from the root rib through and into the wing tube Also added a piece of basswood
into the tube at the spot of the bolt so it is tapped into it.
#491
ORIGINAL: Jascat100
Regards
Jim
Regards
Jim
Chris filled me in on all your escapades at Ladies Mile, luck b****rds some people were stuck behind the office all day... Also it seems the viper due to its size attracted some attention at the field from the RAF
So now confident enough to bring it to ST.Barbs on Saturday
On with the panther now
#492
ORIGINAL: DENTO
HEY JIM
ORIGINAL: Jascat100
Regards
Jim
Regards
Jim
#493
ORIGINAL: loukos
Congrats Jim,
ORIGINAL: Jascat100
Regards
Jim
Regards
Jim
#494
@Jascat: "Noticed a slight gap between the right wing & the fuz"
Same was by mine Viperjet and also by a friend of me.
@ DENTO: I fix my wing with a M4 screw at the end of the tube in wing ( 1" from the end-at his point is wood built in from factory). Your solution isn't good, because your screw is in wing-stress area.
Regards
Fritz
Regards
Fritz
#495
ORIGINAL: Heer
@Jascat: ''Noticed a slight gap between the right wing & the fuz''
@ DENTO: I fix my wing with a M4 screw at the end of the tube in wing ( 1'' from the end-at his point is wood built in from factory). Your solution isn't good, because your screw is in wing-stress area.
Regards
Fritz
Regards
Fritz
Done the numbers with the internal brace extruded in the tube add basswood takes care of any stress no problems been doing it this way for yonks never failed.
REGARDS
DENTO
#496
I made an additional wing fixing in the tube. Used hardwood quadrant same as Dento, but epoxied it in the wing tube at each end. Drilled holes as per Fritz, one inch from the end of the wing tube & used 4mm bolts. the wing is rock solid with just this, but I will also use the original fixings as well.
#497
Guys,
I had a few questions and request sent to me regarding the LED units from B&Q. I have taken some pics for you of the units to show their size. The major downside to these is the cost from B&Q, they come complete with a transfomer and junction box and cost £40 for three units. So I have paid for a lot of parts I dont need!! I was hoping to be able to source the LED's with casings on their own. I wonder if anyone can help? The LED's should be easy enough to find, its the casings and lenses that might be an issue.....any thoughts? Apart from dont buy them their too expensive!
Sorry about the photos!
H
H
#498
ORIGINAL: hangarman
Guys,
H
Guys,
H
DID you see the link on page15 just down from the top for DETAILS 4 SCALE
REGARDS JOHN
#499
My Feedback: (39)
ORIGINAL: Heer
Regards
Fritz
Regards
Fritz
For those of you who noticed the extra gap between the wing and fuse - check to make sure the wing tube is not bent.
PaulD
#500
My Feedback: (10)
ORIGINAL: hangarman
Guys,
H
Guys,
H
these are just STANDARD luxeon emitters right?
if there is interest i could make body,s for those , will cost less then those units
