Another Skymaster Viper
#1303
RE: Another Skymaster Viper
ORIGINAL: Springbok Flyer
Gonzalo,
A work-of-art mate! Well done!
What is the total weight of your Viper?
Cheers
Jan
Gonzalo,
Cheers
Jan
Regards,
Gonzalo
#1304
Stig,
Any chance you could share your setup with me yet?
Cheers
Jan
Stig,
Cheers
Jan
Of course.
The throws are still the same as per manual except for the rudder, which now has 40 mm.
I found that 40 % Expo was perfect for elevator, allthough I nomally don't go further than 25%.
I moved the CG a bit forward. I think I'm at 225 mm now.
#1305
Nice one Sverrir !!!! i take it, that everything worked as it should of done? what did you think of it?
Any issues with the gears doors trying to open in flight? After opening the right main door another 3mm, mine worked flawlessly yesterday, with none of the doors or gear trying to come down, in any of the manouvers we tried
Jan for what it's worth my set up, as done by Ali is
Elevator as per book
Rudder 65mm
ailerons as much as possible (5mm more than book, if i remember correctly, measured from the outer part of the aileron)
flaps as per book
10% expo max on all surfaces
Duncan
Rudder 65mm
flaps as per book
Duncan
#1306
Yes, to say it was good would be an understatement, it was fantastic! Smooth and hardly needed any correction, two clicks on the trim and even though it was blowing about 14 knots and gusting 18-20 she didn't notice that up in the air.
I'm seeing the gear doors opening like so many others, I'll probably need to do the "Duncan mod" to get them to behave properly.
#1307
I'll take some pictures tonight of the new pick up point for the rams and if possible the new position where they mount off the former. It's made a hell of a difference to mine. The doors are solid as is the gear.
I haven't used 4mm tubing, but swapped out the chinese air line for BVM stuff and running 120psi through the airpower unit. Cycling the gear uses 10psi out of the 3 large air tanks. I have 2 air tanks for the brakes, which work really well, they held the model on the tarmac at almost full throttle yesterday, when Ali did a launch control styley take off
Duncan
Duncan
#1308
That was full 160 sx power it was holding ( For at least 5 seconds before I released ) The VJ has some of the best brakes of any jet. They hold the plane back against all that power and bring it to a stop even after a hot landing without flat spotting the tyres.
We should all follow Duncan's retract/ door set up as its the best I have seen to date. It cleans up perfectly on take off ( no slowing down required ) cleans up perfectly in flight even under load and speed!
Yeti... You need to be making use of those flaps. Both take off and landings with the VJ are so much nicer with flap!
Regards Al
Just to let you guys know.. We now have the full Viper jet vinyl sets in stock.
Regards Al
#1312
Today I made first three flights with my VJ with slotted flaps und crow setting.
Slotted flaps 60° down (for landing), Aileron 10 mm up at the end, Elevator neutral. At my first flight I have Aileron 3 mm down during crow. Thats not good, nose goes tu much down, so I correct the elevator to neutral.
I'm absolute happy with this configuration. At the 3. flight I made a steep final approach of about 30°, without speed increase.
Conclusion; this modifications are worth to do - first impression was I fly another jet, not compare as before.
I recommend this upgrade.
Brg
Fritz
Brg
Fritz
#1314
ORIGINAL: R_Belluomini
Can I order online the 2M Viper decal set? Do you have a link you can post?
Bob
Bob
Ali has then in stock, just email him at [email protected] and he'll sort you out
cheers
Duncan
#1315
Hi All, I am in the process of building the Large Viper. Below is a photo of the control horns that came with the kit. All the instructions show the large horns for the control surfaces. Did I get the wrong ones or has there been a change in the instructions.
thanks
thanks
#1316
My Feedback: (39)
CA
Thinking of putting together a Viper. Noticed a lot of talk on the gear door cylinders and would like to know what the ideal way to go would be. I,m thinking of getting a bare kit and doing my own gear and gear door install. My question is: what gear door rams would you all use and gear valve?
Thanks for the help, great thread.
Steve
Steve
#1317
My Feedback: (39)
Steve,
Finding gear door rams would be relatively easy. Finding gear would be something different. Tom Cook retracts with Digitec struts would get you part way but I'm not sure what to use for brakes. I bought the bare kit and have been piecing it together. I did buy the gear with it. It's nicely made stuff and as long as it stands up, I think it was worth getting.
Nice jet though, overall you won't be dissapointed with the airframe. Just be prepared to fix a few things to get it right.
PaulD
PaulD
#1318
Hi Dunc, did you post any pics of your flights? notice you haven't been on the other forum lately, did they rumble you?[sm=lol.gif]
I've been pushing H to get on with his one, he's softening
#1319
Steve,
after I changed the tubing to 4 mm to the gears, I have had no problems retracting them (but do remember to slow down when retracting, otherwise they won't lock!)
The doors seems to be closed on mine in flight, and that is even after I cut the rectangles in the airbrakes to get rid of the vacuum inside the fuselage
I'm pretty sure that Skymaster changed the "attack" point for the door cyllinders, on the "older" Vipers we have here, they were placed at a less than optimum position than they are on the "newer" ones we have
#1320
Hi Vince
There are some flying pics a page or two back, near the top of the page i think. Yes you need to get Henry to finish his viper, he had it 3 months before i did !!!! oh yea jiveturkey was killed off, but he'll be back with another ip addy
Carsten
mine has no problems locking the gear, without coming off the throttle after take off and that was with standard BMV airline. I did however treat all the air cylinders to a bit of BVM thin O lube to make sure all the seals where seated and sealing properly.
Carsten
#1321
Here are the pics of my gear door mod. I tried to make it look like part of the original former, i did have a pic of the brack et i made, but must of deleted it, so i have attached a really bad sketch of what it basically looks like.
Duncan
Duncan
#1322
My Feedback: (39)
CA
ORIGINAL: PaulD
Steve,
PaulD
Steve,
PaulD
Steve
#1323
ORIGINAL: Duncan
Duncan
Duncan
Duncan, Fantastic!!! what RAMS are you using?
Many thanks,
Gonzalo
#1324
My Feedback: (39)
Back to the collapsing canopy thing.
Has anyone ever looked at the intake ducts. I was staring at mine last night while doing some work on the plane. There is a significant reduction in area from the intakes on either side of the cockpit to the point where the two ducts merge. At that point the 2 airstreams are hitting each other at almost 180 deg and the cross section area looks to be reduced to about half. Even with a bypass, there could still be a problem getting enough airflow esp at low airspeeds and sudden increase in turbine speed.
There is a small NACA duct on the right side of the forward fuse. Has anyone opened this one up to provide some airflow to the canopy area? It's not very big but might make a difference.
PaulD
PaulD
#1325
ORIGINAL: gonzalom
Many thanks,
Gonzalo
Many thanks,
Gonzalo
Duncan
