Another Skymaster Viper
Reply
Old 01-16-2011, 07:17 AM
  #1626
i3dm
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Another Skymaster Viper
I did setup triple rates ont he Tx and yes, rudder was maxed out - forgot to mention that.
i3dm is offline
Old 01-16-2011, 04:18 PM
  #1627
3DAV8R
3DAV8R's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Have a few questions: First, what kind of oil are you using in the struts ? Second, what air pressure for the struts ? Third, what is a good pressure for the main tires and nose ? Thanks for the help
3DAV8R is offline
Old 01-16-2011, 04:43 PM
  #1628
Selleri
Selleri's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: i3dm
Im about to maiden my buddy's large SM viper with 160SX. throws are per the manual and CG at about 225mm.
Any special tips or do's and dont's for the maiden ?
Thanks.
Keep the approach relatively flat, don't forget the flaps, crow makes a difference too. Otherwise just enjoy it, one sweet plane!
Selleri is offline
Old 01-16-2011, 04:48 PM
  #1629
i3dm
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
how can i reach Shaz to order a stronger canopy ?
i3dm is offline
Old 01-24-2011, 01:00 PM
  #1630
3DAV8R
3DAV8R's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Finally ready for the maiden. All taxi test and engine runs went well, just have to get down to Buttonwillow for the test flight.
Steve
ID:	1552349   Click image for larger version
3DAV8R is offline
Old 01-24-2011, 01:06 PM
  #1631
i3dm
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Maiden flight went without a hitch - here is a video of the maiden:
[youtube]http://www.youtube.com/watch?v=zRiUrIKWfOA[/youtube]
And here is Nessy Gil (owner of the big viper) flying it for the 2nd time (4th flight overall on the machine):
[youtube]http://www.youtube.com/watch?v=IFwlJiDz5sA[/youtube]
Notes from the test flight :
1. CG at 230mm feels great, but will move slightly backwards from now on, i reckon it would be even better.
2. stock throws were fine for basic flight , but a little sluggish for aerobatics, especially on the ailerons. on the rudder we used as much as we got.
3. plane feels solid through flying and basic aerobtics - super predictable on landing too. a joy to fly !
Good job by Skymaster for sure. this one was designed to fly well !
i3dm is offline
Old 01-29-2011, 08:05 AM
  #1632
f106jax
f106jax's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I just finished the turbine installation in my Viper but have not yet installed the intake extension. The fit between the rear of the intake and the front of the extension is so poor that I'd have to use a lot of glue to fill the gap between the lip on the extension and the rear of the intake. So I've been thinking about not installing it. Are you guys using the extension and if so, are you gluing it to the intake or attaching it some other way?
Thanks!
f106jax is offline
Old 01-29-2011, 06:00 PM
  #1633
ViperJet1
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Ok Mike, It simple. I have my Viper no longer since it head firsted into the ground due to stahling it in a loop as I'm sure you have seen the video...(FYI.....don't do that!!!!) hehehe just don't get it t slow and you'll be fine. Now as for your situation with the intake as I assume you mean the "Mid intake"? That fiberglass tube that slides over the rear portion of the intake in the plane....... Are you using the Bypass? I assume you are. You want to get the bypass mounted first and the engine in the bypass at least the top partof it so you can fit or measure the distance of the mid intake. It needs to be cut. And a half square needs to be cut into the front part to able it to slide over the part where the intake in the jet is rooted to the fuse.
You want to cut less than more because you can always cut more but if you cut too much its another 20.00 for the intake and a minimal 3 weeks to get it. the lip of the rear should fit nicely rested on the bypass but its not going to be perfect on the top half because the engine will need to be shimmed to get the NGT of the turbine centered in the tailpipe. Many don't mention this and I went through two tailpipes before I figured it out.
It takes some mind working on the matter but I am sure you will get it. I may have pictures if you need them.
Also I initially used goop Zap goo to install the Mid intake a few dabs so I caould remove it if necessary but after removing it a few times the dried goop seemed to tight fit it so I never replaced it with fresh goo. And as for any gaps you may have where the bypass meets he mid intake that normal. you don't want to glue it there because it will make it harder to service the engine. And a sealed unit is not needed. It will take hot air in from the fuse and send it out the back.
I hope to get another Viper someday but I am going to try my F-18 first and if it goes well then I'll get another Viper.
Over all its the coolest looking plane. Flys great too!!
Gary.
ViperJet1 is offline
Old 01-29-2011, 11:46 PM
  #1634
Duncan
Duncan's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi Mike
I cut my White front extending piece at an angle to fit the bypass correctly. I siliconed it on the intakes and put sticky backed foam about 10mm wide onto the extension so it fitted the bypass with no gaps.
Hope that helps
Duncan
Duncan is offline
Old 01-31-2011, 12:47 AM
  #1635
extra 300
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Photos would be welcomed!!
Thanks, Regards,
extra 300 is offline
Old 01-31-2011, 06:13 AM
  #1636
f106jax
f106jax's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks Gary and Duncan for the replies. I found some good photos back on page 4 from CraigG that helped me out.
Thanks again!
f106jax is offline
Old 03-21-2011, 11:53 AM
  #1637
geh3
geh3's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Just finished decorations and final balance
ready to maiden EXCEPT I'm worried about the
weak sides of the canopy, seems WAYtoo thin to me!!!!
geh3 is offline
Old 03-21-2011, 02:55 PM
  #1638
Matt Chapman
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
GEH3 ....I have a Viper as well.... keep it up the road from you at New Garden Airport. I used BVM canopy hooks mid cockpit and ha e had no issues with 50+ flights. I have extra if you would like a couple. Just let me know. Can meet you there if you would like Wends.
Good luck... you will love the plane.
Matt Chapman
Matt Chapman is offline
Old 03-21-2011, 03:31 PM
  #1639
dubd
dubd's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Here's a recent video of my Viper flying at a fairly small field. Space is constrained by trees on both sides and the runway is 500'. Using a EvoJet Booster 160 for power.
[youtube]http://www.youtube.com/watch?v=DhoSFryFwvw[/youtube]
dubd is offline
Old 03-22-2011, 12:13 AM
  #1640
extra 300
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
dubd,
Congratulations on your maiden. Impressive slow speed on landing. Any idea of total runway used for take off and landing??
Regards,
Old 03-22-2011, 06:56 AM
  #1641
dubd
dubd's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Extra 300, I used up about 250' on take off and landing.
dubd is offline
Old 03-22-2011, 11:25 PM
  #1642
extra 300
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
dubd,
That's great news for me, as our field is quite short, about 400 ft long. One more question, was there any upwind that day to help slow down the plane? The Viperjet seem to slow down quite a bit without any tendancy for stall. This is the first time i watch a video where you can clearly see how slow she is landing.
Thanks, Regards,
Old 03-23-2011, 06:55 AM
  #1643
dubd
dubd's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: extra 300
dubd,
Thanks, Regards,
There was very little wind that day, maybe 2-3 mph.
dubd is offline
Old 03-23-2011, 07:07 AM
  #1644
Selleri
Selleri's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Flight #25 on mine last summer.
[youtube]http://www.youtube.com/watch?v=9aDCbanvDJY[/youtube]
Selleri is offline
Old 03-23-2011, 07:25 AM
  #1645
dubd
dubd's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Sverrir, love the blue scheme.
dubd is offline
Old 03-23-2011, 07:28 AM
  #1646
Selleri
Selleri's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
It is sweet, I'll hopefully buy another one in a not to distant future!
Selleri is offline
Old 03-23-2011, 07:30 AM
  #1647
Duncan
Duncan's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Will i be coming over to put the decals on again Sverrir?
Duncan is offline
  #1648
OttoKranz
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: Selleri
Are you kidding?
This is Ali that can land a wooden nightstand on his left hand while piloting with the other!
I need all my 400ft !!
Alessandro
OttoKranz is offline
Old 03-23-2011, 07:35 AM
  #1649
Selleri
Selleri's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: Duncan
I'm still investigating if your last work compromised the airworthiness of my VJ!
I kid, at your prices I'll even throw in a beer and let you fly something!
Quote:
ORIGINAL: OttoKranz
Are you kidding?
Alessandro
He didn't need much schooling on the VJ!
Selleri is offline
Old 03-23-2011, 07:42 AM
  #1650
OttoKranz
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I've done some calculation, I have 100mt for 328 ft and good brakes But I've always landed on runway and I'm not so experienced on turbines like Ali...[8D]
Reply
Display Modes
