CGRCJets A-10 Build Thread
Reply
Old 04-23-2011, 05:58 PM
  #551
cgrcjet
cgrcjet's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: CGRCJets A-10 Build Thread
Nice job James. Looks to be coming along.
Right now i am building one for a customer that will be using a pair of tj90's. When this is accomplished we can widen the gap even more as far as fan size and create a bit more savings for more budget minded people. We will have to get Tam to make a new mold for the inlets like he did with the tj100. I know how he likes to stay busy, im sure he wouldnt mind a bit more on his plate.
chris
cgrcjet is offline
Old 05-25-2011, 07:50 PM
  #552
cgrcjet
cgrcjet's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Few pix of Dexters A-10 that i have been working on. Was able to talk him into the Spangdahlem panthers scheme. One of my favorites. He will be setting it up with a couple TJ90's.
Any flight report yet James?
chris
ID:	1614607   Click image for larger version
ID:	1614608   Click image for larger version
ID:	1614609   Click image for larger version
cgrcjet is offline
Old 05-25-2011, 08:18 PM
  #553
Shaun Evans
Shaun Evans's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi,
What's your stock like? If someone wanted one, do you have open stock? What items, if any, are backordered?
Shaun Evans is offline
Old 05-25-2011, 08:45 PM
  #554
cgrcjet
cgrcjet's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: YellowAircraft
Hi,
I build to order. On average about 2-4 weeks for a kit and about 6 weeks for an ARF depending on which spectrum the roller coaster is in. I do not have the means or time to keep any open stock around.
thanks
chris
cgrcjet is offline
Old 05-30-2011, 09:08 PM
  #555
cgrcjet
cgrcjet's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hey Dexter. Finished the clearcoat today and the last little bits. Start on the plug for the TJ90 inlet tomorrow. Thought i would post a few finished shots.
chris
ID:	1617263   Click image for larger version
ID:	1617264   Click image for larger version
ID:	1617265   Click image for larger version
cgrcjet is offline
Old 06-03-2011, 07:18 PM
  #556
cgrcjet
cgrcjet's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Finished the plug today and made some inlets for the TJ90.
chris
ID:	1618672   Click image for larger version
cgrcjet is offline
Old 07-18-2011, 09:56 AM
  #557
cgrcjet
cgrcjet's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Video of Mark Browns A10 running 90mm fans.
http://www.youtube.com/watch?v=Db0Pp...re=uploademail
cgrcjet is offline
Old 07-18-2011, 11:29 AM
  #558
wowplanes
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Chris
How many cells are the Midi Fans running on?
Fahim
wowplanes is offline
Old 07-18-2011, 08:43 PM
  #559
cgrcjet
cgrcjet's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi Fahim
I believe it was 9s. Weight came in just under 24 pounds. Dexters will be 4 pounds lighter than Marks running couple tj90's. I lightened the layups and structure on his, so it should be a nice glider.
chris
cgrcjet is offline
Old 08-19-2011, 08:30 AM
  #560
tulz161
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I just found what I'll be using to transport mine when I actually get my hands on one.
tulz161 is offline
Old 04-18-2012, 05:24 AM
  #561
cgrcjet
cgrcjet's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I have started and updated version of the A-10 and you can follow along here. I will be reconfiguring the airframe and adding extra details to make a faster building and more scale kit.
http://www.rcuniverse.com/forum/m_11...m.htm#11046680
Chris
cgrcjet is offline
Old 11-25-2012, 10:41 AM
  #562
J.F
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
In the final stages of finishing mine now, there's flight at the end of the tunnel
Little video of the first synchronised start of the two mw44 kerostarts.
http://vimeo.com/54228030
I think this is going to be plenty of power.
When installing it all, I remembered someone saying that 2 turbines are 4 times as much work. It is very true!! But we'll worth it.
J.F is offline
Old 11-25-2012, 03:35 PM
  #563
cgrcjet
cgrcjet's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Nice James! That thing wants to get in the air. Please make sure cg is correct. An inch out may be a bad thing. Also, did you fix the rear wing incidence on this one?
Good luck and do post some video!
thanks
chris
cgrcjet is offline
Old 11-26-2012, 12:48 AM
  #564
J.F
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi chris,
This kit was bought from another guy in the uk, who purchased it from Lowell, who said that the incidence had been done. So assume its all ok.
What's the recommened cofg at present? She'll no doubt be nose heavy on take off from all the fuel, then more so when that landing gear goes up/forward.
J
J.F is offline
Old 11-26-2012, 01:07 AM
  #565
Dave Wilshere
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
J
Looking forward to this
D
Dave Wilshere is offline
Old 11-26-2012, 04:12 AM
  #566
J.F
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Glad you are....I'm cr*pping myself!
The pipes the Ilja (Grummania) made are v.good!
J
J.F is offline
Old 11-26-2012, 11:43 AM
  #567
cgrcjet
cgrcjet's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: J.F
Hi chris,
J
Send me a pic of underside of tail section. Good to be sure. Cofg is 4 inches back from leading edge. May want to try little less for first flight to se how it handles. Maybe just 1/4 inch less. I built a second one for john and lowell and john had cg back 1 inch to far and thought it would be fine but lost control after takeoff. Where is fuel located?
Do you have a pic of the new thrust tubes?
chris
cgrcjet is offline
Old 11-26-2012, 02:57 PM
  #568
J.F
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
HI Chris,
if i balance at 4" with wheels down and no fuel then i'll be fine.
i have 3/8 between bottom of fus and underside of tail.
thruist tubes are a scaled down version of the ones Ilja makes for the skymaster A10 - good quality, good price, and fast turnaround.
If all goes well with the maiden I'll be ordering a full set of weapons off you!
ID:	1823746   Click image for larger version
ID:	1823747   Click image for larger version
J.F is offline
Old 11-26-2012, 03:28 PM
  #569
cgrcjet
cgrcjet's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: J.F
HI Chris,
if i balance at 4'' with wheels down and no fuel then i'll be fine.
Just dont get too nose heavy. Depending on where the mains are fixed, it may take a bit to rotate. May want little extra stretch to take off from to be safe.
Rear horizontal stab looks fine.
How much for the thrust tubes?
chris
cgrcjet is offline
Old 11-26-2012, 03:49 PM
  #570
cgrcjet
cgrcjet's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I wish your engine nacelle looked like someone shot it with a shotgun a few times like this one. This is my new unfinished plug for the new version. 4 days just on rivets. The mold is now finished and im actually laying it up as we speak. I will be posting some updates on the new thread soon.
ID:	1823755   Click image for larger version
ID:	1823756   Click image for larger version
cgrcjet is offline
Old 11-28-2012, 10:13 AM
  #571
J.F
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Looks awesome Chris, you have more patience than me!
Not sure on the retail price for the thrust tubes and "cones" from Ilja - prob best to send an email, as don't think he has on his web shop yet.
J.F is offline
Old 11-28-2012, 10:20 AM
  #572
invertmast
invertmast's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Damn chris, those nacelles look great! I get to be a beta tester right
invertmast is offline
Old 11-28-2012, 04:53 PM
  #573
cgrcjet
cgrcjet's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Trust me, i dont have patience. I have to learn to deal with my impatience. I cant wait until this thing is done, but if i do, i know it will turn out a nicer kit.
When do you think you will maiden? Now im getting impatient, lol!
Thomas
Take your vacation and come down for couple weeks. You can stay at my house and you can help me finish up faster. We can make you 2 of them, and you could beta test both of them, i dont care. Could throw in some gas money if you wanted to drive down.
chris
cgrcjet is offline
Old 11-28-2012, 05:08 PM
  #574
invertmast
invertmast's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Chris,
When my vacation comes around i will take you up on that offer! Lol. Ive gotcha some glass cut, i just have to find the time to ship it
Old 11-28-2012, 06:16 PM
  #575
Ron101
Ron101's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
That looks great man!
great work Chris.... can't wait to see it all done
Ron101 is offline
Reply
Display Modes
