Skymaster L39 build
You can get them from here:
http://ashtekelectronics.com/shop/connectors-c170.html
You'll need to buy all the crimping tools etc.. but it's worth the effort. I've used them for all sorts of models and wouldn't be without them now.
HTH
Cheers, Alex
Cheers, Alex
Managed a bit more on the L39, busy with other things atm but getting there.
It was obvious early on that this model was going to need some help to get the CG within limits. With this in mind I ordered two 3300NiMH, no point using Lipo's and regulators then adding lead, saves some money too. I wanted the battery's accessible so I made a ply plate that I could slide in and out of the nose. I extended the battery leads and added some EC3 connectors, while the soldering iron was out I finished making up the aileron and flap wiring. A bit of gray paint and it was glued in with hysol
The other little bits I've done are to set the radio up, install the four rx's, protected the wiring that enters the forward fuz with shrink sleeve to stop any possible chaffing more important on prop models but old habits and all that.....
The ends of the control surfaces were all painted as they were just left bare out the box which looks odd when you waggle the sticks. The air system was tested and proved reliable with the Airpower EV5-U multi function valve.
Cheers, Alex
I Alex,
My FEJ L39 arrived the other day, I haven’t had a chance to look at it in detail but at first glance it looks like a quality kit. Judging by the online build manual I think I’ll be relying for the most part on your thread.
Should get something up in the next few days, cockpits required more work than anticipated but then what doesn't in this hobby
Cheers, Alex
I just got my Skymaster L-39 Yesterday and have been busy unpacking all the parts. I am following your thread very closely, your pictures and explanations are very informative. Please continue with the updates if you can.
One of my cockpits came in cracked also. The exhaust tube was missing one of the metal tabs, and with the exception of some small pieces of wood floating in the fuse, there is no other damage.
I did notice that the wing tanks have two small holes on the side that faces the wing. The instructions say to line the pins up with the two matching holes in the wing tip. There are no holes in my wing tips. Was yous the same as mine (no pins and no holes in the wing tips?)
Stan
Hi Stan<o></o>
My tip tanks were the same as yours. I enlarged the holes in the tanks and fitted the pins then made a template out of light ply. All I had to do was mark the end of the wing using the template and drill a few holes. I found doing it this way the tanks fitted perfectly first go. I was undecided about fitting landing lights so I didn’t glue them on initially which was a good move as I'm now sticking some lights in.
I’ve been a bit slack updating the thread, the model is now in a flyable condition but I’ve got loads of little scale extras to do, it also needs a clear coat applied to protect all my weathering.
I’ve just started to make the tooling for pylons and the large drop tanks, I’m also going to make some UB16 rocketpods. There are some very good pylons and tanks commercially available but I want to use the larger Russian tanks that the Hungarian air force use on their L39ZA’s
I’ll update the thread when I get back to the workshop, I’m out and about testing with a customer the next couple of days so should get it done middle of next week.
Glad your finding this build useful.
Cheers, Alex
<o></o>
<o></o>
<o></o>
Are these upgrades needed that BVM has to offer?
I will be picking up my SM -39 next week and plan to start building asap, as I will be building mine scale with many details with the help from details 4 scale.
The only items Details 4 scale has is the drop tanks and the lighting.
What other scale options hae you installed in your L-39
Mark
I am starting to install my rudder servo. I am using a Hitec 7955. I imagine it is about the same size as the 8411. I can install the servo with the servo arm at the top of the servo which would be in the direction of the top of the fin, or I can mount the servo with the servo arm at the bottom of the servo facing down.
If I mount it with the servo arm at the top of the servo the bottom of the servo will stick out the bottom of the verticle fin a bit. I probably will cut a opening in the fuse portion to accommodate that part of the servo. Hope I am making myself clear.
I am wondering which direction most of the guy's have gone with their rudder servos and if it makes a difference.
Stan
I have spent several hours on the rudder servo mount and am getting closer but still having a problem.
Putting the servo in with the servo arm facing down would put the servo high in the fin. Putting the servo in with the servo arm towards the top of the fin puts the servo closer to bottom where it is easier to reach. There have been pictures posted but unfortunately only pictures of the outside of the slot.
Either way I am having a difficult time with it.
The stab and wings are no problem for me.
I am open for any suggestions.
Stan
this will be my 6th jet and this one i want to go all scale, still not sure on the color scheme yet...... I must have looked at hundreds of L-39 photos on airliners.net looking for something different and bright colors......
mark
Hope this helps
Cheers, Alex
The clear carrier films on the decals are currently visible as you can see in the last picture. This will completely disappear once a clear coat has been applied and give that painted on look. The clear coat is essential if your going to use water slides. You could avoid this using rub downs as there not as delicate but I'd still recommend a clear coat especially if the models weathered. Thought I'd mention this as the eagle eyed among you would undoubtedly notice, It doesnt look good until you've given it a spray.
