Skymaster ARF Plus 1:5 scale F-104G
#102
RE: Skymaster ARF Plus 1:5 scale F-104G
Hi, all
here is Video for the second prototype of F-104 maiden flight, we make strong contruction for the slat , now dry weight 18.5kg included speed brake with all gear doors. Powered by K-170,
http://youtu.be/fysPmb_C9IU
http://youtu.be/fz_QM0WDC60
Best Regards
Anton
Best Regards
Anton
#104
ORIGINAL: jetpilot
Did you not retract the gear?
Why?
Scott
Why?
Scott
yes, retracted the L/G and closed the all gear doors in the sky,
#105
My Feedback: (49)
Anton,
Doesn't it make sense, that if you're going to post videos of aircraft in development, for marketing reasons, that SkyMaster make an investment in a higher quality video camera?! I am very interested in this model, but the quality of the video is very disappointing.
Congrats on the successful flight!
David S
David S
#107
My Feedback: (49)
ORIGINAL: jetpilot
Me as well.
How about less 80mph 2 minute flights and more 200mph 8 minute flights with rolls and loops?
the video quality and test flying style is tiresome.
Scott
Me as well.
Scott
David S
#108
Anton,
How much throttle we're you using during that flight? The ground handling is certainly better now, but it is still sitting too low at the front. Is it possible to get the nose a bit higher?
Could you please post some photo's showing all the hatches you have on the jet - it will be good to know how much working space and also installation space there is.
Thanks for sharing your developments with us, it certainly is a lot more than most other manufacturers will do.
Cheers,
Jan
Cheers,
Jan
#109
Hi, all
Thank you for your suggested,
That poor weather conditions and air pollution seriously I almost lost the F-104, because i can not see it in the sky well, some time i want to guess aircraft posture, Fly less than 200 meters is almost unknown aircraft position even the camera could not capture it,
Flying through the air when I had used the 2/3 to 3/4 thrust,
I will be flying again after the F-104 painted, this time only test the slat for take off and landing,
Best regards
Anton
Best regards
Anton
#110
ORIGINAL: Springbok Flyer
Anton,
Cheers,
Jan
Anton,
Cheers,
Jan
i will post some pictures here, Thank you,
Best regards
Anton
#111
Hello Anton,
Congratulations for your superb F104.Do you have gyros on the flight controls ? are they necessary ?
Best regards and see you at next JetPower.Etienne.
#114
Hi Anton,
Any updates on the production F104 ??
Could we see some more photos, Hatches, Engine bay and Tailplane drive system???
Paul.
Paul.
#115
ORIGINAL: PDR200
Hi Anton,
Paul.
Hi Anton,
Paul.
my F-104 now installing the servos with turbine, here are same pictures....
#116
Anton,
Very nice. But don't you think that you will loose some cooling around the jet pipe with the exhaust setup. Can't see that too well, please take a photo from the back to show us how you are mounting the exhaust nozzle. It will also be good to see th nose section closer.
Regards,
Jan
Regards,
Jan
#117
Anton,
Regards,
Jan
Anton,
Regards,
Jan
we made the super scale detail for the inner of nozzle. and before paint job, i already test flight this F-104 , no problem for the cooling air,, this will make more scale nozzle for F-104,
when i test fly this F-104 again, i will note the temp of tailcone, TKS for suggested.,
#118
i just found the pic of nozzle , i think my paint factory did the wrong color, i want to ask them repaint the nozzle again !![]
#120
Hi, all
my new F-104G finished the paint job, and we made the speed brake and openning canopy,
http://youtu.be/XRVAfxWo8fs
Best regards
Anton
Best regards
Anton
#122
#123
ORIGINAL: PDR200
Hi Anton,
Is there a removable nose cone on the F-104?
I think I can see on the video.
Cheers,
Paul
Hi Anton,
Cheers,
Paul
#124
Great Video Anton!!!!!!
What is the finished weight? and in this video what engine did you use? (how much thrust?)
Cheers,
Paul.
#125
ORIGINAL: PDR200
Cheers,
Paul.
Cheers,
Paul.
