where to buy G-10?
My Feedback: (31)
where to buy G-10?
tried here...... http://composite-laminates.com/g10-sheets.htm
not feasable to buy here due to minimum quantities....even though it says 1 sheet, when u add it to your cart, it comes in multiples....looking for .031", .063", .094", and some .125".....24 to 35" sheets......anyone know a good source for the thicker sheets...most of the jet places (BVM, DW, FTE) have the smaller thicknesses......
RE: where to buy G-10?
ORIGINAL: F86_SABRE
What is the prefered G10 thickness to make horns?
Reuben
Reuben
I often use 2mm thickness fo varoius parts. I use the caompany next door for CNC milling and I have my own designs like magic :-) With 2mm G10 you can make a M3 thread directky in the plastic and it works very well!
[youtube]http://www.youtube.com/watch?v=c09ubYYvFVI&list=UUkS76rnRPMEStILK5pfawfQ&index=6[/youtube]
Hi Henke,
Thanks for your reply....do you know of a European supplier of G-10? Also is it normal to have black G-10 as it looks like carbon fibre sheet? CNC cutting of G10 is another hurdle that has to be overcome in due course!!
Thanks again.
Reuben
Thanks again.
Reuben
1 Post
Reuben if your after a relatively small amount say a few 24" square sheets then I might have some which I can ship to you direct as keep a small stock for my parts etc.
PM me if you want to discuss.
marcs
marcs
My Feedback: (9)
The GUND Co. in St Louis deals in G-10 & G-11 as well as phenolic laminates -
Schoen insulations in Canton Georgia deals in G10 & G-11 as well as phenolic laminates -
These two companys will supply & cut any thickness you want, eg....I have had 4" thick G-11 cut by GUND Co. they have a killer water jet set-up.
