Jet MACH Ultra Sport protoype Build
NC
RE: Jet MACH Ultra Sport protoype Build
got to do a little work today made intakes rounded leading edges hinged some control surfaces took a few more pic at a different angle to let you see the size I'am 5foot 10 tall
#33
NC
after second operation on my eyes finally getting to where I can see a little better . Got to do a little more work on it today . Rudder is framed up with 5/8x3/8 added 1/16 to ether side to give 1/2 clearance inside can run hs85 mg now .I dont like pull pull on nose so i'am going to run this set up.Sanded some on fus starting to look a little better I think I still have about two weeks sanding left.
#35
NC
not really a scoop it will be a hatch for access to nose for battery are what ever yo want to hide.Did you get yours yet
#36
My Feedback: (15)
TN
It is currently being cut out. Bob responds quickly but I think this new bird is going to up his work load considerably when they are seen at the field. I am really excited to get started and especially having seen the quality of the Super Sport kit but, there are always things to organize to get ready such as a large flat place to do the glue ups. I really like the fact that good old wood glue is used extensively. Imagine waiting for glue to dry, it will make me feel like a kid again, no instantly glued together fingers stuck to the parts or developing sensitivity to epoxy and other exotic (e toxic) resins but, their all good in their place and I use them.
When I said “scoop†I meant where did you get the nose steering servo mount? I have never seen it done that way, makes sense, especially after I watched a Euro Fighter drag its nose on the runway because a pull wire got around the nose strut.
Si ya
Charles
Si ya
Charles
#41
MS
k12rc that is an awsome Jetmach! I may try one next.
I am finishing a Turbinator and was wondering how you attached your canopy? Is is glued on? If it is what type of glue did you use?
Thanks for any help.
Looking forward to seeing the finished mega Jetmach.
Hal
Hal
#42
NC
used e6000 then taped it .If you want a flush fit sand edges glue down with e6000 fill sand to match paint .You can get e6000 at wall mart craft section .The jet mach has been glassed and is at a friends house waiting for a decent weather to paint it will post pics very soon
