Gear cycles when radio turned on
FL
I just installed new 12x radio in my King Cat and when I turn the radio on at first, the servos cycle and my gear retracts and then drops. It only happens at first, then I can turn the radio on and off and it wont cycle again. Its a pain to have to lift the plane every time i am going to turn on the radio not knowing if the gear servo will cycle. Any guesses? Thanks, Alex.
My Feedback: (10)
FL
RE: Gear cycles when radio turned on
Alex:
Both LGM and Bevar are correct. Been there and done that. Bill Hatcher looking over my shoulder with a grin on his face. . ."Hey Eric. . .let's rebind with all the switches where you want them" and see if it goes away. He is so kind . . .
Cheers,
Eric
Cheers,
Eric
My Feedback: (21)
I think if you rebind the set up, it won't matter which type of servo is operating your retract valves. i could be wrong but that's my experience with a pair of hitec mini MG on my current project.
ORIGINAL: bevar
Alex,
Also make sure you do not have an analog servo operating the gear valve. If so...it will do that every time. Drop in a digital and it will go away.
Beave
Alex,
Beave
FL
Went home for lunch and rebinded. Problem solved! Yes!!! So easy, thanks Y'All. Spoke with Bill Hatcher, prawley best to change servo to digital also. He also taught me how to bind in fail safe settings too. Coolisimoooo!
My Feedback: (21)
just be sure when using digitals to use an amp meter to make sure its not binding at either end of the throw
ORIGINAL: vetagator
ON, CANADA
I have a new B-25 & the same cycle issue is happening, even after Idid a rebind with the gear in the down position. How do you do the failsafe settings binding with a DX7 & AR6110?
ORIGINAL: Dangaras
I have a new B-25 & the same cycle issue is happening, even after I did a rebind with the gear in the down position.
ORIGINAL: tp777fo
another thing I found is make sure you turn radio off with gear down. If you raise gear then disassemble jet for transportation they will cycle when you reassemble.
that would be another good reason to get the Tam fail safe unit, i always pull my gear up before taking it apart to transport, then after assembly i manually move the valve to put the gear down (even cycle it a couple times by hand to make sure of no leaks), then sit it on the ground and it never cycles the gear when i power the plane on.
My Feedback: (14)
Interesting discussion.
KC .. what's the logic of binding the Tam failsafe with gear up? I think I may be missing something. I fly "F" not "J" but failsafe works similarly even if set differently... I've always set failsafe for gear down, even with the Tam unit (which I agree is really nice).
Dave
Dave
My Feedback: (251)
HI all, when setting up a new airplane with JR, rebind, rebind, rebind every time you make a change in the settings, so when you are finally finished and turn on the TX, their is no movement on the servos. ( thats with JR, not familiar with others)
Rcpete
Rcpete
ORIGINAL: ww2birds
KC .. what's the logic of binding the Tam failsafe with gear up? I think I may be missing something. I fly ''F'' not ''J'' but failsafe works similarly even if set differently... I've always set failsafe for gear down, even with the Tam unit (which I agree is really nice).
Dave
Dave
Dave
the Tam unit has programming so that if it's powered ON with the gear in any position other then gear down (and it must remain there for a few seconds) it will put the gear in the down position and keep it there (this is it's fail safe condition) until it receives the proper gear down signal from the RX for those few seconds. now for the why bind with gear up:
if you bind it with gear down, and you have the gear switch on the TX in the UP position, the Tam unit will see the gear down signal from the RX when it's initializing (this is how you bind and told it to do) and then when it locks and gives the TX control it will see that gear up (you're switch in the wrong position) and the gear will pull up. it is something that I've never done myself but I've seen it happen to people many times, they have their fuel / air tanks full and ready to start a flight, turn everything on and the gear switch is somehow in the UP position and up comes the gear when the RX is turned on []
Hi KC
I have the Tam failsafe and it has never happened to me.
Anyway, I always turn my radio on with my F-16 intalled on the PVC support, and if the gear is up, usually for transportation, when I turn the radio on, no matter in which position is the gear switch on the transmitter, the gear comes down or even keeps down if it is in the down position when transmitter is turned on....
I love this TAM device....If you lose air during a flight, at a preset air pressure, the gear comes down....Just set the pressure above certain value to be sure the nose gear will lock againts tha air stream.
ORIGINAL: Guillermo Ibanez
Hi KC
Hi KC
