If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Page 21 of 22 FirstFirst ... 1119202122 LastLast
Results 501 to 525 of 540
  1. #501
    Join Date
    Jul 2006
    Gelderland, NETHERLANDS
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Skygate Hawk - build (virtual manual)
    Kudo's to MarcS and Ray, the aeroplane looks really nice!
    Are you planning to do some weathering Ali?
    Regards,
    Remco45
  2. #502
    Ali's Avatar
    Join Date
    Apr 2002
    Northamptonshire , UNITED KINGDOM
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Hi Remco,
    No this one is staying super shiny. I have no intention or interest in scale competitions with it, so it will stay just as a nice pretty toy to enjoy
    Regards Al
    Al's Hobbies, Horizon Hobby, Airworld, BVM, Jet Cat, Skymaster, Rc Jet Centre,pull over, Tomahawk, C-ARF, Jet-Teng,Kingtech
  3. #503
    ianober's Avatar
    Join Date
    Aug 2002
    San Mateo, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: Ali
    Hi Remco,
    Regards Al
    Until someone says "Oh, I gotta have that!!!" and slaps down some serious coin for it.
  4. #504
    David Gladwin's Avatar
    Join Date
    Feb 2002
    CookhamBerkshire, UNITED KINGDOM
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    One of the final jobs on my Hawk has been installing the intakes as per Marc's kit. On P12 of this thread he shows the intake retaining system using lite ply formers in the intakes and fuselage. There is a much easier and lighter way and now its finished I know it works. I made the locating pegs which are glued into the fuselage mouldings from CF tube. I cut these off short enough so that when the stubs go into the intake moulding they stop short of the forward face of the moulding by about 1 mm. Using Hysol I glued blind nuts to the "tabs" inside the intake moulding, socket head bolts go through the CF tubes from the fuselage side and pull the fuselage and intake moulding together. A couple of "tabs: in each moulding were a little flexible so I supported them with two small ply triangles either side of the blind nuts. The result is a firm location of the intakes but easily removeable.
    May save you guys some time, and a little weight.
    On another matter, the large tank. Has anyone flown it as I have some concern about fuel "sloshing" in such a large tank as there are no baffles ?
    Regards,
    David.
  5. #505
    Join Date
    Apr 2002
    SANTA ANA, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: David Gladwin
    One of the final jobs on my Hawk has been installing the intakes as per Marc's kit. On P12 of this thread he shows the intake retaining system using lite ply formers in the intakes and fuselage. There is a much easier and lighter way and now its finished I know it works. I made the locating pegs which are glued into the fuselage mouldings from CF tube. I cut these off short enough so that when the stubs go into the intake moulding they stop short of the forward face of the moulding by about 1 mm. Using Hysol I glued blind nuts to the ''tabs'' inside the intake moulding, socket head bolts go through the CF tubes from the fuselage side and pull the fuselage and intake moulding together. A couple of ''tabs: in each moulding were a little flexible so I supported them with two small ply triangles either side of the blind nuts. The result is a firm location of the intakes but easily removeable.
    On another matter, the large tank. Has anyone flown it as I have some concern about fuel ''sloshing'' in such a large tank as there are no baffles ?
    Regards,
    David.
    David,
    I've put several flights on mine with P-200 power, feeding fuel thru a JMP Accumulator, without issue.
    David S
  6. #506
    Join Date
    Jan 2005
    Auckland, NEW ZEALAND
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Hi David,
    My tank is in half again and i'm making up a set of interlocking baffles out of 2mm glass sheet - 2 in both directions, with no glue required.
    Also running the JMP accumulater - nice bit of kit!
    Cheers
  7. #507
    marc s's Avatar
    Join Date
    Jan 2007
    farnborough, , UNITED KINGDOM
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    David, good to hear about your duct mounting method, sounds very secure.
    What I found was that M3 blind nuts actually slid into the ends of the small stainless joining pins supplied, so I glued these in place much like you did with the carbon tube on the fuselage side and the intake side with blind nuts suitably located then located and M3 cap heads secured the ducting in place.
    My concern was not having the prongs of the blind nuts fixed into something that was not going to move, hence the lite ply - I guess in your system the blind nuts are mounted with the flat face on the surface of the duct moulding and rely on the Hysol to grip the prongs?
    Be good to see some pictures of the jets, David S and DG ;-)
    JMP is a great device, here is a picture of the prototype of my new series of CAT's, Composite Air Traps, all being fully tested by Olivier shortly and ideal for all sizes of jets as the fittings are fully optimised for maximum flow. The volumes are 90cc, 150cc and the one in the picture is 275cc.
    Transparent so you can see whats going on inside and the ply mounting plate comes included - will be very keenly priced ;-)
    marcs
    Attached Thumbnails Attached Thumbnails Click image for larger version.
ID:	1611170   Click image for larger version.
ID:	1611171   Click image for larger version.
  8. #508
    Join Date
    Feb 2002
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Thanks very much indeed for the fuel tank, sloshing, advice, guys, flight test rules !
    I will post some pics later Marc. but the ducts are finished, blended etc. look great. All of the securing socket head bolts are accessible even without a long hex driver.
    I have been using the PST bubble trap with great success on two PST 1300 powered models. It has large bore fittings, is clear, rigid plastic so has been chosen for my Hawk.
    Hoping to have this machine ready for final painting (19 Sqn, Spitfire colours) before leaving for my northern summer in UK, so on return it can be finished.
    Great thread, RCU at its best
    Regards,
    David.
  9. #509
    Join Date
    Jan 2005
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Marc - another great looking product. May ace the JMP for me being able to see fuel level.
    What is the timing on availability?
    Regards
    Craig
  10. #510
    marc s's Avatar
    Join Date
    Jan 2007
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Look forward to the results and finished article.
    marcs
  11. #511
    marc s's Avatar
    Join Date
    Jan 2007
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Craig,
    The fittings all arrive in the next 10-14 days or so, so should be able to supply early June time.
    The small unit is similar to the small Mapp unit in its volume, the mid range slots in with the normal UAT sizes and the large is for those wanting to run larger hopper volumes and P200 + turbines.
    PM me if you want pricing info.
    marcs
  12. #512
    Join Date
    Jul 2008
    Balen, BELGIUM
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    hi ,
    what kind of servos did you use in the hawk?
    regards
    wim
  13. #513
    Join Date
    Jan 2005
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Hey Wim,
    For me the following:
    Rudder: 1 x JR DS8911.
    Elevator: 2 x JR DS6311HV.
    Ailerons: 2 x JR DS8911.
    Nose leg: 1 x JR DS8411.
    Nose Doors: 1 x JR DS8511 on front doors and 1 x JR DS 8411 on small rear door.
    Main Doors: 2 x JR DS8711.
    Are you building a Hawk?
    Cheers Craig
  14. #514
    schroedm's Avatar
    Join Date
    Jul 2002
    SevenoaksKent, UNITED KINGDOM
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Hi Wim,
    For me it was 8711 all round.
    Rgds,
    Mark
  15. #515
    Join Date
    Jan 2005
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Mark - just had my chute arrive. Nice!
  16. #516
    marc s's Avatar
    Join Date
    Jan 2007
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    David G any news or info on the flights, be good to have some feedback, maybe even video - assuming that it you have flown and its all positive news
    marcs
  17. #517
    Join Date
    Feb 2002
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    No Marc, my Hawk is structurally complete and ready for final paint, ( 19 Sqn colours) (with servo specs similar to Tobba's except I am using JR MP80T brushless servos on ailerons with the 6311HVs operating with 6 volts, buy still masses of power for the stab (remember I have moved the stab pivot point forward). 6301s s on flaps.
    I am moving back to the UK early next year (we have a wonderful life in Australia but imminent arrival of another grandson in UK has tipped the balance) so in the middle of packing up all models (13 jets !) at the moment and will finish the Hawk when I get back to London.
    The tank and ducting install went well and if the big Hawk flies as well as my two Airworld machines I will be delighted.
    It might surprise some to learn that despite being a huge country flying sites suitable for jet ops. are very few and very far between with access to hard runways almost impossible without several hours drive, at least the UK is far better on that score. I flew at my local (1.5 hours drive) grass strip last Sunday but its so rough due to excess rain and drought (we get them both !) its almost unflyable, so runways like Wroughton and Abingdon are VERY appealing. The BobCat gear took a real hammering, but survived.
    I also have some ideas to use contacts in UK to try and get some other runways for regular, say monthly, jet meetings.
    Regards,
    David.
  18. #518
    Join Date
    Jul 2008
    Balen, BELGIUM
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    hi,
    thanks for the info but the 8711 has plastic servo arms not in alu
    craig,
    yes but a friend of my is building him
    regards
    wim
  19. #519
    schroedm's Avatar
    Join Date
    Jul 2002
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: wimpel
    hi,
    regards
    wim
    Erm, put metal arms on it as I did??
  20. #520
    Join Date
    Jul 2008
    Balen, BELGIUM
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    marc,
    do you used the arms of carf?
  21. #521
    schroedm's Avatar
    Join Date
    Jul 2002
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Wim,
    No, but there are plenty of options. SWB Mfg, JR's own metal arm, Secraft etc etc
    I tend to always use the JR's metal arm.
    Cheers
    Mark
  22. #522
    Join Date
    Jul 2008
    Balen, BELGIUM
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    but is it an option to take the jr 8811 ? these are standard with metal arms and stronger
    regards
  23. #523
    schroedm's Avatar
    Join Date
    Jul 2002
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Wim,
    The 8711 is 5kg stronger
    Cheers
    Mark
  24. #524
    Join Date
    Jul 2008
    Balen, BELGIUM
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    hi mark,
    then y know enough now thank you verry much
    regards
    wim
  25. #525
    Join Date
    Jun 2004
    , INDIA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Hi Guys,
    Skygate has supplied some lead weight in the kit, looks like its used to balance the horizontal stab. Are you guys using the weights to balance the stab, if yes, do i make a slot in the root leading edge to install the weights.
    Can someone give me the neutral position of the stab.
    Chatty.
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
