Reload this Page >
Best Smoke Oil?
Best Smoke Oil?
Old 11-06-2009, 11:48 PM
TommyWatson
Default Best Smoke Oil?
I have just started to use the Tams smoke system in my Wren Turboprop. I used Super Dri Aviation Smoke Oil. It was terrific. Huge volumes of brilliant white smoke.
The only problem is the cost.
Here in australia it works out to about A$40 for a US gallon (3.75 litres).
has anyone got a recipe for a good substitute that is a bit cheaper but just as effective?
Also because the Super Dri is clear it does not leave a dirty residue. I have the turboprop in a Carden 35% Extra and any residue will stain the sides and wings of the model.
All suggestions of what you have used welcome. Or is it possible to buy it in larger quantites. I cant imagine the full size guys using it in 1 gallon bottles.
Regards
Old 11-07-2009, 01:34 AM
Xantos
Default RE: Best Smoke Oil?
Tom,
Super Dri is by far the best !
Ive tried all possible homebrews and nothing comes even close to Super Dri.
From my experience straight diesel is equivalent to any homebrew / mix.
For regular Sunday flying I use straight diesel this is by far the cheapest alternative
Xantos
Old 11-07-2009, 01:46 AM
TommyWatson
Hi Xantos,
Thanks, I am beginning to find out exacty that. I guess I will just have to wear the cost. I found a place that sells it here in australia in 19 litre pails. It works out to about A$8 /litre.
I particularly like the clean model after each flight. There are a few droplets on the wing Leading edges and fuse sides. I still have to experiment with the pump. I may be pumping too much oil. The tam pump can be controlled. It sure produces lots of smoke. It is almost like a crop duster!.
Old 11-07-2009, 02:04 AM
Robrow
Robrow's Avatar
Has anyone tried inhibiting oil?
Rob.
Old 11-07-2009, 04:19 AM
AFTERBURNER1
My Feedback: (80)
AFTERBURNER1's Avatar
ORIGINAL: TommyWatson
Regards
This stuff from Fastenal works pretty good....
Fastenal Part No. (SKU) 0207288
Manufacturer Part No. FORM RELEASE 5GAL
UNSPSC 31201606
MSDS View MSDS
Manufacturer UNITEX
Notes Freedom Form Release. High quality, organic based chemical release for concrete forms, prevents bonding of concrete to steel, aluminum, plywood and composite forms. Organic chemicals react with concrete to prevent adhesion and provide a quick and easy release. Highly refined, thin amber liquid that remains fluid at subfreezing temperatures and can be stored indefinitely. Pleasantly scented and FREE of #2 diesel
Old 11-07-2009, 12:32 PM
furloughed ual
My Feedback: (31)
furloughed ual's Avatar
Conosol 260 (mineral seal oil)....we get a 55 gal drum...under $10/gal with freight....my a tailpipes are completely dry using this...no mess (just like Super Dri.....I'm guessing it's the same stuff....I can tell no difference)
ID:	1309353   Click image for larger version
ID:	1309354   Click image for larger version
ID:	1309355   Click image for larger version
Old 11-08-2009, 07:55 PM
Zagzoo
My Feedback: (28)
Zagzoo's Avatar
I use the mold release from Fastenal as well, Paid $45 for 5 gals.. smokes like a champ:
ID:	1310379   Click image for larger version
Old 11-08-2009, 11:29 PM
Molar mender
Molar mender's Avatar
I've been using the Fastenal for a couple of years now. I used to buy it for $24 for 5 gal. The last 5 I bought was up to $37. Good stuff.
Roy
ID:	1310572   Click image for larger version
ID:	1310573   Click image for larger version
ID:	1310574   Click image for larger version
Old 11-09-2009, 09:35 AM
gooseF22
gooseF22's Avatar
some suggestions on where to get fastenal?
Old 11-09-2009, 10:01 AM
furloughed ual
My Feedback: (31)
ORIGINAL: gooseF22
check out post #5 above....Fastenall is the store that carries it....the actual oilis called Freedom Form Release (they use it in concrete construction)....my local Fastenall can get it....make sure u bring in the part # above...the guy I went to took forever to find in the catalogs....got to the Fastenall website and do a store locator search in your area.....
Old 11-09-2009, 10:54 AM
Molar mender
ORIGINAL: gooseF22
You've got two stores in Fort Wayne, one on Independence Dr and the other on Engleton Dr, plus a couple in surrounding areas. I call it the nuts and bolts store. Besides fasteners they handle a lot of construction items. Here is the site for the item. http://www.fastenal.com/web/products...0207288&ucst=t
Because it is oil based, the prices fluctuate like gasoline/diesel. I see that the wholesale price is up to $41.22 for 5 gal.
Hope that helps.
Roy
Old 11-09-2009, 11:17 AM
schroedm
schroedm's Avatar
Powerbox Systems produce a very good smoke oil now.
http://www.powerbox-systems.com/e/po..._max/start.php
Rgds,
Mark
Old 04-05-2015, 05:31 AM
Fly2XS
My Feedback: (65)
Fly2XS's Avatar
It looks like the price for the Fastenal Freedom Form Release has gone up a bit since this thread was started.
As of this posting its $75 for a 5 gallon pail.
http://www.fastenal.com/web/products...288&searchMode
That's still only $15/gallon which is half to price of Super Dri.
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXAN64
ID:	2086484   Click image for larger version
Name:	Freedom Form Release.jpg
Old 04-05-2015, 05:39 AM
Jetpilot24
My Feedback: (21)
I use the concrete form release oil as well. Makes smoke just as good as super Dry. Here is video of my F-15 with smoke using the form release oil from Fastenal.
https://www.youtube.com/watch?v=iEKASGZTPsE
Joe Lewis
Kingtech K80 and K-140 Owner
Old 04-05-2015, 08:17 AM
luv2flyrc
luv2flyrc's Avatar
Robarts Liquid Sky works just as good as Super Dri and it's $90 vs $125 for a 5 gal pail. With Tower hobbies discounts you can sometimes get it cheaper.
Mike
Old 04-05-2015, 08:43 AM
Fly2XS
My Feedback: (65)
Fly2XS's Avatar
In your pictures I see all this great smoke using the high temperature turbines.
What about in a 95 cc 2-stroke warbird? How about on a Sachs 5.8 with a Brisson muffler?
Will it get hot enough to put out the same level of smoke?
What's your experience?
Old 04-05-2015, 08:54 AM
Fly2XS
My Feedback: (65)
Fly2XS's Avatar
Is the Robart Liqud Sky simply The Freedom Form Release with a private label?
Mike
ID:	2086530   Click image for larger version
Old 04-05-2015, 03:06 PM
jws_aces
My Feedback: (33)
jws_aces's Avatar
I have been using the B&B smoke oil
http://www.bennettbuilt.com/shop/Smo...allonCase.html
shipped to the door for 63.80 a case of 4 gallons. I did buy a gallon of the Robart from DreamWorks at FJets and it seems to be the same thing in looks and smell.
https://www.youtube.com/watch?v=-7hvRmOCalo&index=3&list=PL2tnjbymPD2fLeox_qOcy7Drt-WBgGKze
Old 04-06-2015, 04:38 AM
geonato
geonato's Avatar
Can someone post the Fastenal oil specification to see if I find a similar in my country...thanks
Old 04-06-2015, 09:18 AM
sailing1
My Feedback: (134)
http://aerocumuluscom.ipage.com/
Check out this link. I have been using this smoke oil which is made by a fellow modeler. Works at least as well as Super Dry and costs a lot less.
Old 04-06-2015, 06:01 PM
DiscoWings
My Feedback: (76)
DiscoWings's Avatar
Here are my findings:
Diesel: Cheap but also made fireballs on behotech 180gold and 220, will not use because of fire potential, the smoke was not very thick and had low hang time. IMO not a smoke oil.
Aerocumolus: Expensive, Medium Density, LONG HANG TIME. same as Super Dri, this smoke oil did not make as bright or as puffy clouds as super dri, however, it had a much longer Hang time, meaning the trail lasted longer, I tried all different flow settings, still could not get the same white puffiness or desnsity of super dri, but the hang time was very long, something with the hang time of this and the density of super dri would be the ultimate. I found this oil did not burn fully, regardless of what I set the flow settings to be, lots of left over oil.
B&B oil: Similar to aero cumoulus, but even less hang time, out of all the purpose smoke oils, this one was the most dissapointing, smoke density was medium and hang time was short. It was priced nicely at around 17/gallon.
Robart Liquid Sky: Also very similar to B&B oil, medium density, low hang time.
Fasternal oil: Low density, medium hang time. I'm sorry but this simply does not compete with purpose built oils, you can try it but you will have inferior results. It does smoke, but it doesn't work all that well on piston engines. Not worth the price savings.
conosol 260: Have not found a source for this locally, someone said the fasternal form release is the same.
Super Dri: High Density, Medium Hang time, Good burn. Well I tried them all and if you want the best results, Super Dri is the way to go, yes its expensive and blah blah blah, but it makes the best smoke. The quality of smoke is the thickest out of anything I have tried, it burns the cleanest and has good hang time. I wish they could increase the hang time to match aero cumoulus, without loosing smoke density; but if I had to pick I would take the density over hang time.
All test were done on my 1.45 hawk that has a 37" pipe with tamjet Super -J injector, using a slider for the smoke pump to test different smoke flow ratings.
Old 04-06-2015, 06:02 PM
DiscoWings
My Feedback: (76)
DiscoWings's Avatar
The cost is false, by the time you pay shipping its the same as super dri from tower using 1 of there coupons.
real cost $113/5 gal pail
Old 04-06-2015, 06:12 PM
jws_aces
My Feedback: (33)
jws_aces's Avatar
Disco do you set your injector behind the turbine or end of the pipe? I have mine behind the turbine.
Old 04-06-2015, 07:59 PM
AFTERBURNER1
My Feedback: (80)
Behind the turbine is optimal...
Super Dri is hands down the best.... I've tried them all....
Old 04-06-2015, 08:44 PM
DiscoWings
My Feedback: (76)
DiscoWings's Avatar
behind the turbine,
try super dri jeff, I know it expensive but the results are the best, I think the other mfgs dilute there oil...
