If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Page 31 of 40 FirstFirst ... 212930313233 ... LastLast
Results 751 to 775 of 999
  1. #751
    gooseF22's Avatar
    Join Date
    Aug 2006
    Fort Wayne, IN
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: C-ARF Flash Build Thread for All Flash's being built this winter
    ORIGINAL: sailing1
    Another 4 perfect flights with my Jet Central Rabbit powered Flash yesterday. Finally made it out to the field with a good radar gun and took some speed pass readings. Was pleasantly surprized by the numbers the little 19 lb thurst over achiever put up. Strait and level passes were between 165-170 mph every time and we were clocking around 190 on diving passes with our best numbers being 193 MPH. I am now pretty sure we could see 199.99 with a decent tail wind.
    I was thinking about putting my new Cheetah in the Flash but being able to fly 8-10 minutes on 75-80 ounces of fuel, decent speed and light landing weights have pretty much made me change my mind on that approach. Hmmm Guess I will be looking for a new airframe for the Cheetah!
    Ultra!!..
    Goose
    JetiUSA Flight Team, www.Espritmodel.com www.demonaero.com MKS USA Servos
  2. #752
    felker14's Avatar
    Join Date
    Feb 2004
    Kansas City, MO
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: Eagle Driver
    just finished this Flash for one of my customers and want to share some pics with you guys ....
    powered by Booster 160 (IQ-Hammer)
    How are you charging battery packs hooked up to DPSI TWIN Mini? Good looking set up. I like Emcotec items they seem to be high quality. How is DPSI TWIN Mini set up, RX switch?
    RC Hobby..... ($100.00 foamie = toy, $20,000.00 jet = toy)
  3. #753
    Eagle Driver's Avatar
    Join Date
    Sep 2008
    Zwartsluis, NL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I charge the batteries over the green MPX connectors on side of the twin mini. it`s a double
    rx setup. always switched to the rx with the best signal.
    Steven - www.Jetisfaction.de - Custom Build Service
  4. #754
    Jim Cattanach's Avatar
    Join Date
    Mar 2003
    Larnaca, , CYPRUS
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Maidened my Flash today. First flight was a bit of a handful. I had 20mm of aileron with 20% expo & not enough expo on the elevator at 30%. It was very twitchy. I cut the aileron to 10mm & upped the aileron expo to 30% & 50% on the elevator. Much smoother to fly. This is really two jets. It is easy & docile to fly slowly, open the (throttle Merlin 140) & it requires a whole lot more attention.
    At full throttle it climbs, so I will dial in some down elevator at full chat.
    I have 6mm crow, but will increase this, as it tends to float on landing (flaps at 50mm).
    Had eight flights & it is a nice relaxing jet to fly, or a tiger by the tail if you want it to be.
    JET FLYING:- Resistance is futile. You will be assimilated.
  5. #755
    ORIGINAL: Jascat100
    Congratulations Jim, and you are so right about the "tiger"
    I have a 160 in mine, and going full throttle is just pure fun
    Good luck with the Flash!
    Carsten Groen
  6. #756
    Join Date
    Apr 2006
    Enterprise, AL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: Carsten Groen
    ..............I have a 160 in mine, and going full throttle is just pure fun
    so much fun in fact, i defiantly recommend you set your timer and USE it, you'd hate to know the number of times i had ran the tanks dry and flamed out with my Titan in the ON position.
    Morgan Fuels / JetCat / KingTech
  7. #757
    Join Date
    Aug 2004
    tulsa, OK
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Yea, but it solves that landing heavy problem!
  8. #758
    Join Date
    Apr 2006
    Enterprise, AL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: sailing1
    landing heavy with a Flash isn't a problem, it lands just as sweet with the tanks full as it does with them empty, i've shot countless touch-n-go's from the beginning of the first lap till she ran dry, it's one of a few jets that IMHO flies better with a little weight.
  9. #759
    Gary Arthur's Avatar
    Join Date
    Jan 2002
    Hamilton, ON, CANADA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: KC36330
    ORIGINAL: sailing1
    Put another 4 flights on today with 30 lbs thrust. Sure is fast...... What a great flying jet...
  10. #760
    ORIGINAL: KC36330
    ORIGINAL: sailing1
    Agree KC, I can't feel much of a difference if I land after 1 minute of fun, or when the tanks are almost empty!
    And believe me, the timer is set
    Carsten Groen
  11. #761
    Jet Doctor's Avatar
    Join Date
    Sep 2003
    Johannesburg, SOUTH AFRICA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    344 km/h (213 mph) this weekend with Wren 160 @ 123 000 rpm. Will need to crank that sucker up to 126 000 rpm and try again
    Attached Thumbnails Attached Thumbnails Click image for larger version.
    Go Big or Go Home!
  12. #762
    Join Date
    Jan 2007
    tampa, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    was curious to see how the p80se flys the flash. i am on getting ready to purchase the ultra flash. how do you like it.. thanks pat
  13. #763
    Join Date
    Dec 2001
    tucson, AZ
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Hi Guys,
    I ran my P120 today at the field for the first time in the flash. I had put aluminum tape on the stab in the fuse to protect it from the heat. I did notice that the back of the fuse along side the vertical fin got warm. left side a bit warmer then the right side.
    I am wondering what is an acceptable heat to the touch in that area. I ran for 2-3 minutes. I did not maiden it as a pretty heavy cross wind developed before I had a chance to get all the checks finished.
    Stan
  14. #764
    Join Date
    Apr 2006
    Enterprise, AL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    if you can hold your hand on it, it's fine. about 150ΒΊ F the epoxy/glass starts to soften.
  15. #765
    Join Date
    Jan 2002
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: tucson
    Hi Guys,
    Stan
    Did you cut out the duct holes in the bottom, it helps keep things cool...
  16. #766
    Join Date
    Dec 2001
    tucson, AZ
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Maybe the fact that I ran it for 3 or more minutes on the ground caused it to get a pretty warm to the touch.
    I wonder what most guys are doing to keep the heat down?
    KC you are running a 160, is this a problem for you?
    Stan
  17. #767
    Join Date
    Dec 2001
    tucson, AZ
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    [/quote]
    [/quote]
    Yes I did.Just trying to find out what would be considered normal heat in that area.
    Stan
  18. #768
    Join Date
    Apr 2006
    Enterprise, AL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Titan SE and never noticed it even warm but only time it was running and not moving for an extended period was during the initial power on ground run and i don't remember it getting hot then.
    were you able to keep your hand on it or was it too hot to keep it there?
  19. #769
    Join Date
    Dec 2001
    tucson, AZ
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: KC36330
    one side was just warm. the other I could keep my hand on it but it was approaching getting hot.
    This was as I mentioned after a 3 minute run on the ground.
    Could it be that the engine nozzel was not centered?
  20. #770
    Join Date
    Oct 2004
    Redding, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    mine gets a little warm after sitting idle for a few minutes. seems cooler right after landing, so I am assuming its just some radiant heat while not moving.
    Kevin
  21. #771
    Join Date
    Dec 2001
    tucson, AZ
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: seflyer
    Kevin
    Makes sense.I need to check after landing.
    Stan
  22. #772
    Join Date
    Jun 2002
    Watford, UNITED KINGDOM
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Stan
    What gap do you have between the inner tail pipe tube and the outer aluminium "cool wall" tube at the rear?
    Dave
    Motors & Rotors. JetCat, Powerbox, Intairco, Behotec, CARF-models Rep. JR Propo for ever!, Jet 1A, MAP, Airtech Germany, Jet Tronics.
  23. #773
    Join Date
    Apr 2006
    Enterprise, AL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I'm with Dave, check the pipe gap at the rear and make sure you've got enough gap to allow cooling air to be drawn down between the pipes and that the inner pipe is about 10mm inside the outer, after 3 min sitting she shouldn't be hot. as far as centered in the pipe, you should be able to look up the tail and see if the turbine is centered.
  24. #774
    Join Date
    Dec 2001
    tucson, AZ
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: Dave Wilshere
    Stan
    What gap do you have between the inner tail pipe tube and the outer aluminium ''cool wall'' tube at the rear?
    Dave
    Dave and KC
    The distance from where the inner pipe ends to where the outer pipe ends at the rear of the fuse is approx 7 mm.
    The gap between the two pipes at the rear varies between 5-6 mm. I don't see how you can get any more as the outer pipe is up against the outer fiberglass.
    The motor looks centered as best I can tell looking down the tube.
  25. #775
    Join Date
    Apr 2006
    Enterprise, AL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    everything looks fine in the picture to me ............. i don't know that it makes a hill of beans difference one way or the other but i always put the seam to the bottom on my installs.
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
