If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Page 32 of 40 FirstFirst ... 223031323334 ... LastLast
Results 776 to 800 of 999
  1. #776
    Join Date
    Dec 2001
    tucson, AZ
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: C-ARF Flash Build Thread for All Flash's being built this winter
    It is on the bottom KC, just depends if the model is upside down or right side up in the cradle
    Did you put any protection on your stab against the heat in that area?
    Thanks again,
    Stan
  2. #777
    Join Date
    Apr 2006
    Enterprise, AL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: tucson
    Thanks again,
    Stan
    must be an optical illusion then...........................the only protection i put in the tail was where the servo wires exited the stab next to the pipe, i covered them with an asbestos sleeve and aluminum tape to hold them in place, bottom of rudder servo got the balsa cover with some BVM heat shield + ceramic paint.
    Attached Thumbnails Attached Thumbnails Click image for larger version.
    Morgan Fuels / JetCat / KingTech
  3. #778
    Join Date
    Dec 2001
    tucson, AZ
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    KC your picture overwriting is 100% correct. However, If you turn the airplane 180 degrees on the stand the seam is on the bottom, NO? Just joking with you.
    Stan
  4. #779
    gooseF22's Avatar
    Join Date
    Aug 2006
    Fort Wayne, IN
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    When I mounted my wren, I had to shim the back of the motor up, which is really down in the rear to get it aligned down the center. I didnt think the mount and pipe were perfectly aligned.
    Turn it over... shim the airplane up until a Level will sit in the tailpipe level. then check your motor casing to see if its level... Mine wasnt.. now it is..
    Also, you may need to move your motor forward to let it draw more air down the tailpipe. Post a pic of your motor in place
    Goose
    JetiUSA Flight Team, www.Espritmodel.com www.demonaero.com MKS USA Servos
  5. #780
    Join Date
    Dec 2001
    tucson, AZ
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: gooseF22
    I have a little over 3/4's of an inch between the back of the engine where the nozzle attaches to the start of the pipe. I will try your method of checking the engine level with the pipe.
    Stan
ID:	1520296   Click image for larger version.
  6. #781
    Join Date
    Oct 2004
    Redding, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    got 5 flights on my T-bird Flash now and love how it flies, 6mm crow with about 60 degrees of flap and it settles right in perfect every time. just picked up another Flash ready to fly with a Titan, I had flown this plane previously and it is what cemented my need for a Flash, now I will have 2.
    Kevin
  7. #782
    RCISFUN's Avatar
    Join Date
    Apr 2002
    Erie, PA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Two..your lucky
    I have been flying my Flash with the Rabbit and I thought it was fast enough for my needs (my first higher performance jet) ...now I hate to admit it... I think I want to go to a big block after flying next to an Eagle powered flash, mine looked like it was standing still[X(]
    Rich
    Jeti USA Flight Team - DS-16, Xtreme Arf, Fei Bao Jets, Jet Central: SE Rhino 200, Cheetah, & Super Eagle owner
  8. #783
    Join Date
    Jan 2007
    tampa, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    The rabbit is 18lbs correct? I am a jetcat guy. The p80se is 22lbs. I am planing to do a new ultra flash. How would you think 22lbs will do...pat
  9. #784
    phjoker's Avatar
    Join Date
    Sep 2005
    Vernon, NJ
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: RCISFUN
    Two..your lucky
    Drop in the Cheetah and call it a day!!
    Pete H
    Jet Central Falcon
    Jet Central Rhino
  10. #785
    RCISFUN's Avatar
    Join Date
    Apr 2002
    Erie, PA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: ricardinho
    Rabbit is 19 LBS (Next generation of Jet Central Turbine)
    Falcon is 22 Lbs (Original Series of Turbine, now out of Production)
    Super Eagle is 30 Lbs (Original Series of Turbine, now out of Production)
    Cheetah is 31 LBS and considerably smaller than the super Eagle i.e. is the Next Generation Jet Central Turbine
    22Lbs won't make too much difference, going to 30 LBS makes a difference
    Don't get me wrong when I first started flying my Flash I thought 19 lbs was insane, however now I have become used to it so now I think I am ready to go bigger.
    I would not have ever question going bigger until I tried to keep up with a 30 Lb Turbine... I just couldn't do it!
    Rich
  11. #786
    Join Date
    Jan 2007
    tampa, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    will i be happy with 22lbs ... whats the roll distance with 19lbs...on paved runway...
  12. #787
    Join Date
    Apr 2006
    Enterprise, AL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    you'll be happy with the P-80 for a while, a Flash flies great with a lil ole P-70 inside, but you've gotta have 30+ lbs to get full satisfaction out of it. with a Titan inside it will accelerate in the verticals.
  13. #788
    causeitflies's Avatar
    Join Date
    Jan 2003
    EASTERN OHIO
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: RCISFUN
    Two..your lucky
    Rich,
    It didn't look like it was standing still... maybe looked like it was going backwards though
    Mark P
    An Expert has made every mistake - A Master has made every mistake twice
  14. #789
    phjoker's Avatar
    Join Date
    Sep 2005
    Vernon, NJ
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: causeitflies
    ORIGINAL: RCISFUN
    Two..your lucky
    Rich,
    Gotta go 30+ or you could go 36 like I did.. Verticals are out of site.
    Pete H
    Jet Central Falcon
    Jet Central Rhino
  15. #790
    Join Date
    Sep 2003
    Eastvale, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I have a Titan in mine. I did have a P-120 in it, but took that out to use in my Hawk I am putting together. To be honest, I can't really tell the difference between the Titan and P-120.
    Graham
  16. #791
    Join Date
    Apr 2006
    Enterprise, AL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: killerG
    ......................To be honest, I can't really tell the difference between the Titan and P-120.
    You're not holding the left stick in the ON position long enough then........ especially in the vertical
  17. #792
    Join Date
    Sep 2003
    Eastvale, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Ya, KC you are probably correct!!!
    Graham
  18. #793
    phjoker's Avatar
    Join Date
    Sep 2005
    Vernon, NJ
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    My Flash Flying for the year has ended.
    On the 2nd flight I dumb thumbed the landing and need to do some repairs to the nose and the wing. Well I hope Minor.
    See here http://www.rcuniverse.com/forum/m_10089529/tm.htm
    Any help on thread above would be awesome!!!!! Please post it there not in here. I know Rich will have some good input for me here he Loves Fibergalss work
    ON the first flight today I had the plane in the air and noticed I had no more then 1/4 throttle while the stick was at full. Brought it in and noticed a Crap load of air going from the MAP uat to the pump, Hand unit also said pump limit reached????? Thats a first. I took the cap off the uat to see what was going on inside and noticed a lot of brownish crap covering almost my entire filter. I am assuming got Algae in my fuel. Emptied all The fuel, cleand out the MAP Uat filter, switched fuel cans and it started right up no air or problems at all. Until the second landing.
    Not a bad year for the flash I got 57 flights on her and I loved every minute of it I can't get enough of this plane!!!!!
    Now I am just upset because I have to go back to flying the Boomer till next spring[:@]
    Pete H
    Jet Central Falcon
    Jet Central Rhino
  19. #794
    Join Date
    Mar 2006
    Hensley, AR
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    120ft @90F and 500ft field elevation.
  20. #795
    Join Date
    Aug 2004
    Rosenfeld, MB, CANADA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Are you using kero or jet a?
    John
  21. #796
    phjoker's Avatar
    Join Date
    Sep 2005
    Vernon, NJ
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    John
    I have been using Kero. I also like to filter a lot before it hits the plane Maybe I am a little over board butbetter safe then sorry.
    I use the Mr. Filter in case of any water. Then my Funnel has a fine mesh filter in the bottom, Ceramic clunk in the can and 2 filters on the can.
    I looked at my filters on the can and I noticed that the one was real nasty. So I just replaced filters tonight.
    Pete H
    Jet Central Falcon
    Jet Central Rhino
  22. #797
    Join Date
    Oct 2004
    Redding, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    anybody have a stock pipe that they did not use, I know some people have replaced the pipe with Tams lighter version. doing all of the install over in my new flash and the pipe is a little worn, if I had a a few hundred flights I would be tired as well.
    Kevin
  23. #798
    Join Date
    Nov 2003
    Prescott, AZ
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I have one I don't need, new in box.
    Marvin
  24. #799
    Join Date
    Jul 2007
    san jose, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Just got one of these used. It is actually my first jet. Aggressive but I have some help and the deal was good...
    It is the blue angle scheme.
    There have been several comments on the visibility of the rogers. Any comments on the blue angles. This is a concern.
  25. #800
    Join Date
    Apr 2006
    Enterprise, AL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    BA scheme shows up like a shiny new penny to me.
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
